扫一扫,分享给好友
大家好~ 我想在zstack 2530 2.3.0-1.4.0的end device 用time3 控制P1.3输出一个PWM波形。在裸机上已经实现功能,但是在协议栈里加入同样的代码后就不行了,困惑了好几天~ 希望大家能帮下~ 谢谢~ |
6个回答
方便把代码贴出来吗?这里贴一份使用timer 3控制p1.4的代码:
PERCFG &= (~(0x20)); // Select Timer 3 Alternative 1 location P2SEL |=0x20; P2DIR |= 0xC0; // Give priority to Timer 1 channel2-3 P1SEL |= BV(4); // Set P1_0 to peripheral, Timer 1,channel 2 P1DIR |= BV(4); T3CTL &= ~0x10; // Stop timer 3 (if it was running) T3CTL |= 0x04; // Clear timer 3 T3CTL &= ~0x08; // Disable Timer 3 overflow interrupts T3CTL |= 0x03; // Timer 3 mode = 3 - Up/Down T3CCTL1 &= ~0x40; // Disable channel 0 interrupts T3CCTL1 |= 0x04; // Ch0 mode = compare T3CCTL1 |= 0x10; // Ch0 output compare mode = toggle on compare T3CTL &= ~0xE0; // Clear Prescaler divider value T3CTL |= 0xA0; //Set Prescaler divider value = Tick frequency /32 T3CC0 = 128; //Set ticks = 128 // Start timer T3CTL |= 0x10; |
bctwerwer 发表于 2018-5-22 05:38 谢谢回复,已经可以了~不过最终还是参照ZLL里Timer1 的控制,再加自己修改,才实现的。下面的ZLL里的timer1初始化代码 T1CCTL0 = 0; /* Make sure interrupts are disabled */ T1CCTL1 = 0; /* Make sure interrupts are disabled */ T1CCTL2 = 0; /* Make sure interrupts are disabled */ T1CCTL3 = 0; /* Make sure interrupts are disabled */ T1CCTL4 = 0; /* Make sure interrupts are disabled */ /* Setup prescale & clock for timer0 */ halTimerRecord[HW_TIMER_1].prescale = HAL_TIMER1_16_PRESCALE; halTimerRecord[HW_TIMER_1].clock = HAL_TIMER_32MHZ; halTimerRecord[HW_TIMER_1].prescaleVal = HAL_TIMER1_16_PRESCALE_VAL; /* Setup Timer1 Channel structure */ halTimer1Channel[0].TxCCTL = TCHN_T1CCTL; halTimer1Channel[0].TxCCL = TCHN_T1CCL; halTimer1Channel[0].TxCCH = TCHN_T1CCH; halTimerRecord[HW_TIMER_1].configured = TRUE; halTimerRecord[HW_TIMER_1].opMode = HAL_TIMER1_OPMODE_UPDOWN; halTimerRecord[HW_TIMER_1].channel = 0; halTimerRecord[HW_TIMER_1].channelMode = 0; halTimerRecord[HW_TIMER_1].intEnable = FALSE; halTimerRecord[HW_TIMER_1].callBackFunc = cBack; Timer1MaxCount = halTimer1SetPeriod (4292); // 233Hz halTimerSetPrescale (HW_TIMER_1, halTimerRecord[HW_TIMER_1].prescale); halTimerSetChannelMode (HW_TIMER_1, halTimerRecord[HW_TIMER_1].channelMode); halTimer1SetChannelCCTL(HAL_T1_CH0, 0, 1, HAL_TIMER1_CH0_CMP_MODE_SET_ON_COMP, 1, HAL_TIMER1_CH_CAP_MODE_NO); halTimer1SetChannelCCTL(HAL_T1_CH1, 0, 1, HAL_TIMER1_CHn_CMP_MODE_CLR_ON_COMP_SET_ON_0, 1, HAL_TIMER1_CH_CAP_MODE_NO); halTimer1SetChannelCCTL(HAL_T1_CH2, 0, 1, HAL_TIMER1_CHn_CMP_MODE_CLR_ON_COMP_SET_ON_0, 1, HAL_TIMER1_CH_CAP_MODE_NO); halTimer1SetChannelCCTL(HAL_T1_CH3, 0, 1, HAL_TIMER1_CHn_CMP_MODE_CLR_ON_COMP_SET_ON_0, 1, HAL_TIMER1_CH_CAP_MODE_NO); halTimer1SetChannelCCTL(HAL_T1_CH4, 0, 1, HAL_TIMER1_CHn_CMP_MODE_CLR_ON_COMP_SET_ON_0, 1, HAL_TIMER1_CH_CAP_MODE_NO); halTimer1SetChannelDuty (HAL_T1_CH1, 0); halTimer1SetChannelDuty (HAL_T1_CH2, 0); halTimer1SetChannelDuty (HAL_T1_CH3, 0); halTimer1SetChannelDuty (HAL_T1_CH4, 0); /* set timer 1 operating mode */ T1CTL &= ~(HAL_TIMER1_OPMODE_BITS); T1CTL |= HAL_TIMER1_OPMODE_UPDOWN; |
gaozhu123 发表于 2018-5-22 05:50 祝贺~感谢分享代码 |
gaozhu123 发表于 2018-5-22 05:50 你好,我正在学习zigbee,准备在z-stack中添加Timer1定时中断,采样ADC数据,但是参考hal_timer.c中的函数,还是没有实现进入timer1的回调函数。请问这个ZLL中是如何实现timer1操作的?能否将代码给我发一份:675412313@qq.com,谢谢啦! |
gaozhu123 发表于 2018-5-22 05:50 能分享一下ZLL的例程吗?有些东西还是没看懂。很感谢了!1456448770@qq.com |
wyywerw2 发表于 2018-5-22 06:21 To michael XU 如果你用了协议栈,那么建议用osal的定时函数来完成这个工作,不需要在硬件层操作定时器 osal_start_timerEx( ) |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1723浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 00:27 , Processed in 0.888251 second(s), Total 83, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
6305
