电子发烧友论坛扫一扫,分享给好友
DTS :
dcdc2_reg: regulator@1 [ /* VDD_MPU voltage limits 0.95V - 1.325V with +/-4% tolerance */ regulator-name = "vdd_mpu"; regulator-min-microvolt = <925000>; regulator-max-microvolt = <1378000>; regulator-boot-on; regulator-always-on; ]; regulator-min-microvolt = <1250000>; regulator-max-microvolt = <1280000>; 修改最大电压为1.28V 系统运行后,电压确实1.28V 但系统打印会报错,不知道是什么原因?求指点!谢谢了 [ 1.723441] remoteproc0: Direct firmware load failed with error -2 [ 1.730025] remoteproc0: Falling back to user helper [ 1.735785] cpu cpu0: of_pm_voltdm_notifier_register: Fail calculating voltage latency[950000<->1325000]:-22 [ 1.746651] vdd_mpu: unsupportable voltage range: 1325000-1275000uV [ 1.753254] vdd_mpu: unsupportable voltage range: 1298500-1275000uV [ 1.759835] cpu cpu0: clk_voltdm_notifier_handler: Failed to scale voltage(1325000): -22 [ 1.768302] clk_set_rate: failed to set dpll_mpu_ck rate [ 1.775052] cpufreq_cpu0: failed to set clock rate: -16 [ 1.780545] cpufreq: __cpufreq_driver_target: Failed to change cpu frequency: -16 [ 1.839120] vdd_mpu: unsupportable voltage range: 1325000-1275000uV [ 1.845678] vdd_mpu: unsupportable voltage range: 1298500-1275000uV [ 1.852251] cpu cpu0: clk_voltdm_notifier_handler: Failed to scale voltage(1325000): -22 [ 1.860725] clk_set_rate: failed to set dpll_mpu_ck rate [ 1.867494] cpufreq_cpu0: failed to set clock rate: -16 [ 1.872972] cpufreq: __cpufreq_driver_target: Failed to change cpu frequency: -16 [ 1.939125] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6 |
4个回答
为啥要改这个数值?这个是针对我们的MPU的电压进行设置的值,因为目前MPU支持从300M到1G的频率。这个值在1G的时候必须要是在1.325V +/- 4%,否则是有问题的,你把他改到了1.28V的原因是什么呢?
且不说driver内部的逻辑对应关系,当这个值需要设置为max的时候,应该就是他被设置为1G的频率的时候,这时候1.28V是支持不了AM335x跑在这个频率点的。 |
hwjj940056201 发表于 2018-5-15 07:16 如果你的系统不需要动态调频,直接在DTS里把这部分去掉就好了 |
hwjj940056201 发表于 2018-5-15 07:16 因为芯片是在800M左右跑,不用系统调压,就是1.33V 有点高了,看 数据手册建议1.26V ,,而系统的自动调压变频,有时候电压到0.95V ,导致GPU挂了几次·,,所以还是用固定电压1.28 比1.26V 高点,会稳定点。 |
huzp_123 发表于 2018-5-15 07:30 U-boot下应该会根据芯片的主频设定好VDD_MPU值,然后kernel中去掉DVFS功能,电压就应该稳定在1.26V不变化了。 |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1757浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 06:38 , Processed in 0.467693 second(s), Total 49, Slave 42 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3592
