电子发烧友论坛扫一扫,分享给好友
Booting from nand ...NAND read: device 0 offset 0x80000, size 0x40000 262144 bytes read: OKNAND read: device 0 offset 0x200000, size 0x800000 8388608 bytes read: OKKernel image @ 0x82000000 [ 0x000000 - 0x3d3a00 ]## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Loading Device Tree to 8fff3000, end 8ffff8d7 ... OKStarting kernel ...[ 0.000000] Booting Linux on physical CPU 0x0[ 0.000000] Linux version 3.14.26 (star@star-VirtualBox) (gcc version 4.9.3 20150113 (prerelease) (Linaro GCC 4.9-2015.01-3) ) #3 Thu Nov 12 10:18:25 CST 2015[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache[ 0.000000] Machine model: TI AM335x EVM[ 0.000000] cma: CMA: reserved 16 MiB at 9e800000[ 0.000000] Memory policy: Data cache writeback[ 0.000000] CPU: All CPU(s) started in SVC mode.[ 0.000000] AM335X ES2.1 (neon )[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129792[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=ubi0:rootfs rw ubi.mtd=9,2048 rootfstype=ubifs rootwait=1[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)[ 0.000000] Memory: 488604K/523264K available (5306K kernel code, 420K rwdata, 2028K rodata, 302K init, 5490K bss, 34660K reserved, 0K highmem)[ 0.000000] Virtual kernel memory layout:[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)[ 0.000000] .text : 0xc0008000 - 0xc0731bec (7335 kB)[ 0.000000] .init : 0xc0732000 - 0xc077db44 ( 303 kB)[ 0.000000] .data : 0xc077e000 - 0xc07e7130 ( 421 kB)[ 0.000000] .bss : 0xc07e7130 - 0xc0d43c20 (5491 kB)[ 0.000000] NR_IRQS:16 nr_irqs:16 16[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts[ 0.000000] Total of 128 interrupts on 1 active controller[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz[ 0.000014] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956969942ns[ 0.000064] OMAP clocksource: timer1 at 24000000 Hz[ 0.000859] Console: colour dummy device 80x30[ 0.000919] Lock dependency validator: Copyright (c) 2006 Red Hat, Inc., Ingo Molnar[ 0.000928] ... MAX_LOCKDEP_SUBCLASSES: 8[ 0.000935] ... MAX_LOCK_DEPTH: 48[ 0.000942] ... MAX_LOCKDEP_KEYS: 8191[ 0.000949] ... CLASSHASH_SIZE: 4096[ 0.000956] ... MAX_LOCKDEP_ENTRIES: 16384[ 0.000963] ... MAX_LOCKDEP_CHAINS: 32768[ 0.000970] ... CHAINHASH_SIZE: 16384[ 0.000977] memory used by lock dependency info: 3695 kB[ 0.000985] per task-struct memory footprint: 1152 bytes[ 0.001030] Calibrating delay loop... 795.44 BogoMIPS (lpj=3977216)[ 0.078877] pid_max: default: 32768 minimum: 301[ 0.079153] Security Framework initialized[ 0.079250] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)[ 0.079263] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)[ 0.104531] CPU: Testing write buffer coherency: ok[ 0.105901] Setting up static identity map for 0x80510078 - 0x805100e8[ 0.110661] devtmpfs: initialized[ 0.114858] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3[ 0.156547] omap_hwmod: tptc0 using broken dt data from edma[ 0.156950] omap_hwmod: tptc1 using broken dt data from edma[ 0.157339] omap_hwmod: tptc2 using broken dt data from edma[ 0.166038] omap_hwmod: debugss: _wait_target_disable failed[ 0.226349] pinctrl core: initialized pinctrl subsystem[ 0.231282] regulator-dummy: no parameters[ 0.234932] NET: Registered protocol family 16[ 0.241201] DMA: preallocated 256 KiB pool for atomic coherent allocations[ 0.247483] cpuidle: using governor ladder[ 0.247511] cpuidle: using governor menu[ 0.258280] syscon 44e10000.control_module: regmap [mem 0x44e10000-0x44e107fb] registered[ 0.262403] platform 49000000.edma: alias fck already exists[ 0.262439] platform 49000000.edma: alias fck already exists[ 0.262460] platform 49000000.edma: alias fck already exists[ 0.266990] OMAP GPIO hardware version 0.1[ 0.297689] omap-gpmc 50000000.gpmc: could not find pctldev for node /pinmux@44e10800/nandflash_pins_default, deferring probe[ 0.297741] platform 50000000.gpmc: Driver omap-gpmc requests probe deferral[ 0.308517] No ATAGs?[ 0.308541] hw-breakpoint: debug architecture 0x4 unsupported.[ 0.363507] bio: create slab
使用nand ubi文件系统时遇到的问题,请帮忙分析一下。 |
10个回答
no free eraseblocks請問有先處理這部分嗎?mkfs.ubifs時的參數有對應到你的flash嗎?將區塊清空後掛載起來的訊息是?
60user100 发表于 2018-5-15 09:43 你好,chang,我又在uboot下直接挂载ubifs时会提示如下信息: NAND write: device 0 offset 0x60000, size 0x8f300 586496 bytes written: OK(sanway@star1.1)U-Boot SPL 2014.07-00107-gd28f2b9-dirty (Nov 16 2015 - 15:27:36)reading argsspl_load_image_fat_os: error reading image args, err - -1reading u-boot.imgreading u-boot.imgU-Boot 2014.07-00107-gd28f2b9-dirty (Nov 16 2015 - 15:27:36)I2C: readyDRAM: 512 MiBNAND: 1024 MiBMMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1*** Warning - bad CRC, using default environmentNet: error -22为参数错误 请问我这样子操作有问题吗? |
S_A_Lucky 发表于 2018-5-15 09:58 請問您是參照TI給的Wiki去做嗎? 具體製作ubifs的步驟與參數是? Prebuilt buifs有試過嗎? |
建议核查三部分: 1. NAND的驱动,是否已经在kernel里面进行了配置,一定要核查这一点。 2. 烧录的地址空间,一定要确认正确。 3. 你本身的UBIFS的制作,参考:http://www.deyisupport.com/question_answer/dsp_arm/sitara_arm/f/25/t/59921.aspx |
hwjj940056201 发表于 2018-5-15 10:29 谢谢刘工关注,这篇文档在一年前就认真看过了,制作的ubi镜像是没问题的,以前用的3.2的内核都能正常启用,内核配置和烧录地址都有确认过。 我现在换了ti-processor-sdk-linux-am335x-evm-02.00.00.00-Linux-x86-Install.bin,内核4.1.6,已经可以正确识别启动了,但还是没找到问题在哪儿。 感觉还是3.14的内核配置哪里忽略了。 |
S_A_Lucky 发表于 2018-5-15 10:47 等于3.2的和4.1的内核都可以启动,但是3.14的不行?有没有对照过内核配置选项的不同? |
也有对照过,使用的都是omap2plus_defconfig配置文件来修改的。 nand配置那块没什么太大差别。 |
都是同一个ubifs镜像文件么?检查下内核对文件系统的支持这部分配置有什么不同。 |
你好,ZHOU and LIU, 这两天有回头研究了一下这问题,发现是gpmc_wen这个信号引起的,我们用这个信号在我们自己的底板上接了cpld,如下图 |
S_A_Lucky 发表于 2018-5-15 11:26 你现在cpld里面有程序吗? 可以先初始化一下cpld试试 |
只有小组成员才能发言,加入小组>>
600 浏览 0 评论
1653 浏览 0 评论
2095 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1542 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1385 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1794浏览 29评论
2820浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1748浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1666浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1680浏览 13评论
/9
GMT+8, 2025-12-14 10:22 , Processed in 1.106347 second(s), Total 93, Slave 76 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
368
