电子发烧友论坛|
[ 0.376215] RTMP_timerListAdd: add timer obj c3c138d8!
[ 0.381401] RTMP_TimerListAdd: add timer obj c3c13908! [ 0.387936] RTMP_TimerListAdd: add timer obj c3c13938! [ 0.393134] RTMP_TimerListAdd: add timer obj c3c138a8! [ 0.399620] RTMP_TimerListAdd: add timer obj c3c13818! [ 0.405719] RTMP_TimerListAdd: add timer obj c3c13848! [ 0.410913] RTMP_TimerListAdd: add timer obj c3bde44c! [ 0.417402] RTMP_TimerListAdd: add timer obj c3bcdc4c! [ 0.422594] RTMP_TimerListAdd: add timer obj c3bcdc84! [ 0.429065] RTMP_TimerListAdd: add timer obj c3bde4f0! [ 0.435176] RTMP_TimerListAdd: add timer obj c3bde3ec! [ 0.440380] RTMP_TimerListAdd: add timer obj c3bde4bc! [ 0.449333] -->RTUSBVenderReset [ 0.452727] <--RTUSBVenderReset [ 1.192825] Key1Str is Invalid key length(0) or Type(0) [ 1.199453] Key2Str is Invalid key length(0) or Type(0) [ 1.206087] Key3Str is Invalid key length(0) or Type(0) [ 1.211798] Key4Str is Invalid key length(0) or Type(0) [ 1.225719] 1. Phy Mode = 5 [ 1.228547] 2. Phy Mode = 5 [ 1.231361] NVM is Efuse and its size =2d[2d0-2fc] [ 1.314044] phy mode> Error! The chip does not support 5G band 5! [ 1.321886] RTMPSetPhyMode: channel is out of range, use first channel=1 [ 1.336610] (Efuse for 3062/3562/3572) Size=0x2d [2d0-2fc] [ 1.376465] 3. Phy Mode = 9 [ 1.383144] AntCfgInit: primary/secondary ant 0/1 [ 1.383173] MCS Set = ff 00 00 00 01 [ 1.520072] <==== rt28xx_init, Status=0 [ 1.527365] 0x1300 = 00064300 [ 2.762386] Warning IOCTL's cmd = 0x00008b03 [ 2.768966] Warning IOCTL's cmd = 0x00008b2d [ 2.776044] Warning IOCTL's cmd = 0x00008b27 [ 2.782588] Warning IOCTL's cmd = 0x00008b09 [ 2.788673] Warning IOCTL's cmd = 0x00008b29 [ 8.596005] Warning IOCTL's cmd = 0x00008b03 [ 8.600702] Warning IOCTL's cmd = 0x00008b2d [ 8.607528] Warning IOCTL's cmd = 0x00008b27 [ 8.613102] Warning IOCTL's cmd = 0x00008b09 [ 8.620801] Warning IOCTL's cmd = 0x00008b29 [ 13.937857] SYNC - AP changed B/G protection to 1 [ 14.504399] Warning IOCTL's cmd = 0x00008b0c [ 14.508709] IOCTL::unknown IOCTL's cmd = 0x00008b0c [ 16.803074] ===>rt_ioctl_giwscan. 26(26) BSS returned, data->length = 3960 [ 16.836661] ==>rt_ioctl_siwfreq::SIOCSIWFREQ(Channel=11) [ 19.622697] ===>rt_ioctl_giwscan. 28(28) BSS returned, data->length = 4238 [ 20.388858] SYNC - AP changed B/G protection to 1 [ 23.583618] SYNC - AP changed B/G protection to 0 [ 24.484882] SYNC - AP changed B/G protection to 1 [ 32.134807] RTMP_TimerListAdd: add timer obj c3c42064! [ 34.665825] BulkIn IRP Pending!!! [ 36.824372] Warning IOCTL's cmd = 0x00008b0c [ 36.828681] IOCTL::unknown IOCTL's cmd = 0x00008b0c [ 37.715915] BulkIn IRP Pending!!! [ 39.035863] ===>rt_ioctl_giwscan. 28(28) BSS returned, data->length = 4367 [ 39.068078] ==>rt_ioctl_siwfreq::SIOCSIWFREQ(Channel=11) [ 41.532452] Warning IOCTL's cmd = 0x00008b03 [ 41.544554] Warning IOCTL's cmd = 0x00008b2d [ 41.549030] Warning IOCTL's cmd = 0x00008b27 [ 41.563679] Warning IOCTL's cmd = 0x00008b09 [ 41.569442] Warning IOCTL's cmd = 0x00008b29 [ 41.726408] BulkIn IRP Pending!!! [ 42.065164] ===>rt_ioctl_giwscan. 25(25) BSS returned, data->length = 4070 [ 44.725964] BulkIn IRP Pending!!! [ 47.047671] ===>rt_ioctl_giwscan. 17(17) BSS returned, data->length = 2839 [ 48.746014] BulkIn IRP Pending!!! [ 50.104437] Warning IOCTL's cmd = 0x00008b0c [ 50.109641] IOCTL::unknown IOCTL's cmd = 0x00008b0c [ 51.765929] BulkIn IRP Pending!!! [ 51.960301] BIRIdx(3): RXDMALen not multiple of 4.[257], BulkInBufLen = 14072) [ 52.145979] ===>rt_ioctl_giwscan. 17(17) BSS returned, data->length = 2896 [ 52.172694] ==>rt_ioctl_siwfreq::SIOCSIWFREQ(Channel=11) [ 54.925949] BulkIn IRP Pending!!! [ 55.120601] BIRIdx(5): RXDMALen not multiple of 4.[44047], BulkInBufLen = 14872) [ 55.365838] ERROR!!! RTMPSetTimer failed, Halt in Progress! [ 59.461654] (Efuse for 3062/3562/3572) Size=0x2d [2d0-2fc] [ 59.862124] RTMP_TimerListAdd: add timer obj c3c138d8! [ 59.868259] RTMP_TimerListAdd: add timer obj c3c13908! [ 59.873449] RTMP_TimerListAdd: add timer obj c3c13938! [ 59.879943] RTMP_TimerListAdd: add timer obj c3c138a8! [ 59.886072] RTMP_TimerListAdd: add timer obj c3c13818! [ 59.891261] RTMP_TimerListAdd: add timer obj c3c13848! [ 59.897751] RTMP_TimerListAdd: add timer obj c3bde44c! [ 59.903429] RTMP_TimerListAdd: add timer obj c3bcdc4c! [ 59.909935] RTMP_TimerListAdd: add timer obj c3bcdc84! [ 59.916034] RTMP_TimerListA[ 128.950164] BulkIn IRP Pending!!! dd: add timer obj c3bde4f0! [ 59.921236] RTMP_TimerListAdd: add timer obj c3bde3ec! [ 59.927730] RTMP_TimerListAdd: add timer obj c3bde4bc! [ 59.936343] -->RTUSBVenderReset [ 59.939738] <--RTUSBVenderReset [ 60.675740] Key1Str is Invalid key length(0) or Type(0) [ 60.681439] Key2Str is Invalid key length(0) or Type(0) [ 60.688434] Key3Str is Invalid key length(0) or Type(0) [ 60.695073] Key4Str is Invalid key length(0) or Type(0) [ 60.708680] 1. Phy Mode = 5 [ 60.711510] 2. Phy Mode = 5 [ 60.715604] NVM is Efuse and its size =2d[2d0-2fc] [ 60.805182] phy mode> Error! The chip does not support 5G band 5! [ 60.813026] RTMPSetPhyMode: channel is out of range, use first channel=1 [ 60.827129] (Efuse for 3062/3562/3572) Size=0x2d [2d0-2fc] [ 60.867673] 3. Phy Mode = 9 [ 60.875397] AntCfgInit: primary/secondary ant 0/1 [ 60.875425] MCS Set = ff 00 00 00 01 [ 61.006079] <==== rt28xx_init, Status=0 [ 61.012392] 0x1300 = 00064300 [ 61.023523] Warning IOCTL's cmd = 0x00008b0c [ 61.039119] IOCTL::unknown IOCTL's cmd = 0x00008b0c [ 63.214435] Warning IOCTL's cmd = 0x00008b0c [ 63.218746] IOCTL::unknown IOCTL's cmd = 0x00008b0c [ 63.312948] ===>rt_ioctl_giwscan. 22(22) BSS returned, data->length = 3270 [ 63.339238] ==>rt_ioctl_siwfreq::SIOCSIWFREQ(Channel=11) [ 66.011350] ===>rt_ioctl_giwscan. 27(27) BSS returned, data->length = 4061 [ 66.774761] SYNC - AP changed B/G protection to 1 [ 67.404296] RTMP_TimerListAdd: add timer obj c3c42064! [ 67.412219] Rcv Wcid(1) AddBAReq [ 67.417751] Start Seq = 00000002 [ 67.422320] RTMP_TimerListAdd: add timer obj c3c44074! [ 84.182222] SYNC - AP changed B/G protection to 0 [ 87.459121] SYNC - AP changed B/G protection to 1 [ 104.353591] SYNC - AP changed B/G protection to 0 [ 178.066208] BulkIn IRP Pending!!! [ 0.267970] Warning IOCTL's cmd = 0x00008b0c [ 0.272281] IOCTL::unknown IOCTL's cmd = 0x00008b0c [ 1.159589] BulkIn IRP Pending!!! [ 2.503729] ===>rt_ioctl_giwscan. 23(23) BSS returned, data->length = 3541 [ 3.159344] BulkIn IRP Pending!!! [ 5.503812] ===>rt_ioctl_giwscan. 15(15) BSS returned, data->length = 2266 [ 7.527954] Warning IOCTL's cmd = 0x00008b0c [ 7.532265] IOCTL::unknown IOCTL's cmd = 0x00008b0c [ 8.179513] BulkIn IRP Pending!!! [ 8.468570] ===>rt_ioctl_giwscan. 16(16) BSS returned, data->length = 2559 [ 8.490333] ==>rt_ioctl_siwfreq::SIOCSI[ 129.167123] BIRIdx(3): RXDMALen not multiple of 4.[32767], BulkInBufLen = 16336) WFREQ(Channel=11) [ 11.189554] BulkIn IRP Pending!!! [ 11.476026] ===>rt_ioctl_giwscan. 14(14) BSS returned, data->length = 2203 [ 14.189346] BulkIn IRP Pending!!! [ 16.506185] ===>rt_ioctl_giwscan. 15(15) BSS returned, data->length = 2479 [ 19.199425] BulkIn IRP Pending!!! [ 19.528065] Warning IOCTL's cmd = 0x00008b0c [ 19.532377] IOCTL::unknown IOCTL's cmd = 0x00008b0c [ 21.516139] ===>rt_ioctl_giwscan. 13(13) BSS returned, data->length = 2217 [ 21.541440] ==>rt_ioctl_siwfreq::SIOCSIWFREQ(Channel=11) [ 24.219534] BulkIn IRP Pending!!! [ 24.505651] ===>rt_ioctl_giwscan. 20(20) BSS returned, data->length = 3260 [ 28.229604] BulkIn IRP Pending!!! [ 29.525995] ===>rt_ioctl_giwscan. 19(19) BSS returned, data->length = 3247 [ 31.229504] BulkIn IRP Pending!!! [ 32.578145] Warning IOCTL's cmd = 0x00008b0c [ 32.582455] IOCTL::unknown IOCTL's cmd = 0x00008b0c [ 34.239608] BulkIn IRP Pending!!! [ 34.433330] GetPacketFromRxRing():pRxWIMPDUtotalByteCount(3840) large than RxDMALen(768) [ 34.546115] ===>rt_ioctl_giwscan. 19(19) BSS returned, data->length = 3112 [ 34.572994] ==>rt_ioctl_siwfreq::SIOCSIWFREQ(Channel=11) [ 37.249610] BulkIn IRP Pending!!! [ 37.535712] ===>rt_ioctl_giwscan. 18(18) BSS returned, data->length = 3015 [ 40.249607] BulkIn IRP Pending!!! [ 42.566340] ===>rt_ioctl_giwscan. 16(16) BSS returned, data->length = 2615 [ 44.269416] BulkIn IRP Pending!!! [ 45.618178] Warning IOCTL's cmd = 0x00008b0c [ 45.622488] IOCTL::unknown IOCTL's cmd = 0x00008b0c [ 47.279655] BulkIn IRP Pending!!! [ 47.586686] ===>rt_ioctl_giwscan. 20(20) BSS returned, data->length = 3234 [ 47.615319] ==>rt_ioctl_siwfreq::SIOCSIWFREQ(Channel=11) [ 50.289634] BulkIn IRP Pending!!! [ 50.483285] BIRIdx(1): RXDMALen not multiple of 4.[3658], BulkInBufLen = 13856) [ 50.666420] ===>rt_ioctl_giwscan. 20(20) BSS returned, data->length = 3175 [ 53.439545] BulkIn IRP Pending!!! [ 53.641843] BIRIdx(3): RXDMALen not multiple of 4.[10171], BulkInBufLen = 16236) [ 55.905807] ===>rt_ioctl_giwscan. 19(19) BSS returned, data->length = 3061 [ 57.589617] BulkIn IRP Pending!!! [ 57.761693] BIRIdx(5): RXDMALen not multiple of 4.[65307], BulkInBufLen = 14256) [ 58.658195] Warning IOCTL's cmd = 0x00008b0c [ 58.662506] IOCTL::unknown IOCTL's cmd = 0x00008b0c [ 60.709731] BulkIn IRP Pending!!! [ 60.903689] BIRIdx(7): RXDMALen not multiple of 4.[37853], BulkInBufLen = 17288) [ 61.088819] ===>rt_ioctl_giwscan. 21(21) BSS returned, data->length = 3385 [ 61.115181] ==>rt_ioctl_siwfreq::SIOCSIWFREQ(Channel=11) [ 63.869691] BulkIn IRP Pending!!! [ 64.155504] ===>rt_ioctl_giwscan. 22(22) BSS returned, data->length = 3547 [ 66.869616] BulkIn IRP Pending!!! [ 67.082398] Err;FC.ToDs [ 67.084907] BIRIdx(3): RXDMALen not multiple of 4.[18182], BulkInBufLen = 15656) [ 69.335178] ===>rt_ioctl_giwscan. 21(21) BSS returned, data->length = 3409 [ 70.939612] BulkIn IRP Pending!!! [ 71.112303] BIRIdx(5): RXDMALen not multiple of 4.[255], BulkInBufLen = 15352) [ 72.278414] Warning IOCTL's cmd = 0x00008b0c [ 72.282725] IOCTL::unknown IOCTL's cmd = 0x00008b0c [ 74.069835] BulkIn IRP Pending!!! [ 74.365562] ===>rt_ioctl_giwscan. 21(21) BSS returned, data->length = 3405 [ 74.393842] ==>rt_ioctl_siwfreq::SIOCSIWFREQ(Channel=11) [ 77.079830] BulkIn IRP Pending!!! [ 77.273475] GetPacketFromRxRing():pRxWIMPDUtotalByteCount(1536) large than RxDMALen(512) [ 77.367377] ===>rt_ioctl_giwscan. 21(21) BSS returned, data->length = 3364 [ 80.079686] BulkIn IRP Pending!!! [ 82.397376] ===>rt_ioctl_giwscan. 21(21) BSS returned, data->length = 3391 [ 84.089614] BulkIn IRP Pending!!! [ 85.438354] Warning IOCTL's cmd = 0x00008b0c [ 85.442663] IOCTL::unknown IOCTL's cmd = 0x00008b0c [ 87.099845] BulkIn IRP Pending!!! [ 87.293824] BIRIdx(7): RXDMALen not multiple of 4.[94], BulkInBufLen = 16412) [ 87.478728] ===>rt_ioctl_giwscan. 20(20) BSS returned, data->length = 3300 [ 87.502865] ==>rt_ioctl_siwfreq::SIOCSIWFREQ(Channel=11) [ 90.259881] BulkIn IRP Pending!!! [ 90.545504] ===>rt_ioctl_giwscan. 19(19) BSS returned, data->length = 3240 [ 94.269894] BulkIn IRP Pending!!! [ 95.556614] ===>rt_ioctl_giwscan. 17(17) BSS returned, data->length = 2936 [ 98.269831] BulkIn IRP Pending!!! [ 98.471357] BIRIdx(5): RXDMALen not multiple of 4.[20763], BulkInBufLen = 15840) [ 98.626479] Warning IOCTL's cmd = 0x00008b0c [ 98.632745] IOCTL::unknown IOCTL's cmd = 0x00008b0c [ 100.746377] ===>rt_ioctl_giwscan. 14(14) BSS returned, data->length = 2512 [ 100.772253] ==>rt_ioctl_siwfreq::SIOCSIWFREQ(Channel=11) [ 103.439922] BulkIn IRP Pending!!! [ 103.634013] BIRIdx(7): RXDMALen not multiple of 4.[10727], BulkInBufLen = 17168) [ 103.818953] ===>rt_ioctl_giwscan. 15(15) BSS returned, data->length = 2588 [ 107.599928] BulkIn IRP Pending!!! [ 108.886483] ===>rt_ioctl_giwscan. 18(18) BSS returned, data->length = 3135 [ 111.599728] BulkIn IRP Pending!!! [ 111.803124] GetPacketFromRxRing():pRxWIMPDUtotalByteCount(3379) large than RxDMALen(2560) [ 111.813029] Warning IOCTL's cmd = 0x00008b0c [ 111.817339] IOCTL::unknown IOCTL's cmd = 0x00008b0c [ 113.935966] ===>rt_ioctl_giwscan. 20(20) BSS returned, data->length = 3400 [ 113.962884] ==>rt_ioctl_siwfreq::SIOCSIWFREQ(Channel=11) [ 115.629956] BulkIn IRP Pending!!! [ 115.824453] BIRIdx(5): RXDMALen not multiple of 4.[5133], BulkInBufLen = 16848) [ 116.966393] ===>rt_ioctl_giwscan. 17(17) BSS returned, data->length = 2829 [ 119.779845] BulkIn IRP Pending!!! [ 119.981895] BIRIdx(7): RXDMALen not multiple of 4.[8933], BulkInBufLen = 18008) [ 122.246291] ===>rt_ioctl_giwscan. 21(21) BSS returned, data->length = 3571 [ 124.929920] BulkIn IRP Pending!!! [ 125.008492] Warning IOCTL's cmd = 0x00008b0c [ 125.012799] IOCTL::unknown IOCTL's cmd = 0x00008b0c [ 127.266582] ===>rt_ioctl_giwscan. 20(20) BSS returned, data->length = 3220 [ 127.295226] ==>rt_ioctl_siwfreq::SIOCSIWFREQ(Channel=11) root@192:/# [ 130.316124] ===>rt_ioctl_giwscan. 21(21) BSS returned, data->length = 3376 [ 134.030043] BulkIn IRP Pending!!! [ 135.316492] ===>rt_ioctl_giwscan. 20(20) BSS returned, data->length = 3284 [ 137.029863] BulkIn IRP Pending!!! [ 137.201203] BIRIdx(7): RXDMALen not multiple of 4.[65], BulkInBufLen = 15732) [ 138.368543] Warning IOCTL's cmd = 0x00008b0c [ 138.372850] IOCTL::unknown IOCTL's cmd = 0x00008b0c [ 140.150073] BulkIn IRP Pending!!! [ 140.446897] ===>rt_ioctl_giwscan. 22(22) BSS returned, data->length = 3649 [ 140.474463] ==>rt_ioctl_siwfreq::SIOCSIWFREQ(Channel=11) 用的RDK是Appro_IPNC_RDK_DM36x_v5.0.0.tar.gz, 内核是2.6.37的,ping通一段时间后面会报错,查了很久还是不知道什么原因,不知道有谁可以帮忙看下,谢谢 |
4个回答
怀疑是dm365 u*** dma驱动方面是不是有问题呢
你好,我是怀疑是不是dm365的u*** dma host方面是不是有问题呢 |
可到达芬奇论坛咨询专家。 http://www.deyisupport.com/question_answer/dsp_arm/davinci_digital_media_processors/f/39.aspx |
只有小组成员才能发言,加入小组>>
554 浏览 0 评论
1617 浏览 0 评论
2049 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1516 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1343 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1766浏览 29评论
2791浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1730浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1643浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1655浏览 13评论
/9
GMT+8, 2025-12-3 20:06 , Processed in 0.769004 second(s), Total 81, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1870
