应该是可以的吧,但是我配置好之后,程序编译没问题,点击debug后,Peripheral里却没有外设选项,这是因为什么呢?下图是我的Option配置,以及调试出现问题的界面
程序: #include "STM32f10x.h" #include void RCC_Configuration(void); void GPIO_Configuration(void); USART_InitTypeDef USART_InitStructure; int main(void) { u16 F; u8 data='A'; RCC_Configuration(); GPIO_Configuration(); USART_InitStructure.USART_BaudRate = 9600; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; USART_Init(USART1, &USART_InitStructure); USART_Cmd(USART1,ENABLE); for(F=0;F<20;F++) { USART1->DR = data; data++; while((USART1->SR & (1<<6))==0) ; } } void RCC_Configuration(void) { RCC_DeInit(); RCC_HSEConfig(RCC_HSE_ON); while(RCC_GetFlagStatus(RCC_FLAG_HSERDY) == RESET); RCC_HCLKConfig(RCC_SYSCLK_Div1); //HCLK = SYSCLK RCC_PCLK2Config(RCC_HCLK_Div1); //PCLK2 = HCLK RCC_PCLK1Config(RCC_HCLK_Div2); //PCLK1 = HCLK/2 RCC_PLLConfig(RCC_PLLSource_HSE_Div1,RCC_PLLMul_9); //PLLCLK = 8MHZ * 9 =72MHZ RCC_PLLCmd(ENABLE); //Enable PLLCLK while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET); //Wait till PLLCLK is ready RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); //Select PLL as system clock while(RCC_GetSYSCLKSource()!=0x08); //Wait till PLL is used as system clock source RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC,ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE); } void GPIO_Configuration(void) { GPIO_InitTypeDef GPIO_InitStructure; /* Configure USARTx_Tx as alternate function push-pull */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(GPIOA, &GPIO_InitStructure); /* Configure USARTx_Rx as input floating */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOA, &GPIO_InitStructure); }
21个回答
完全支持Jlink
应该是支持的
支持的,可以用
可以吧
可以吧
你可以看一下这个blog.csdn.net/lestrade_/article/details/54784112 |
好像是驱动没有安装正确吧
没有结果,你的程序配置是不是正确
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
2810 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
2420 浏览 1 评论
stm32用fsmc读取ad7606采集数据,数据不变,只有开发版复位才更新数据
2288 浏览 0 评论
2404 浏览 1 评论
1643 浏览 1 评论
/9
GMT+8, 2025-12-2 15:39 , Processed in 1.386234 second(s), Total 110, Slave 91 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2495
