扫一扫,分享给好友
代码如下:
/* 模拟十字路***通信号灯的工作过程,设计要求如下: (1)交通灯从绿变红时,有4s黄灯亮的间隔时间; (2)交通灯从红变绿是直接进行的,没有间隔时间; (3)主干道的绿灯时间为20s,支干道的绿灯时间为10s; (4)每个状态要求有倒计时显示; */ module TRAFFIC( //---------------------- //--输入端口 CLK_50M,RST_N, //---------------------- //--输出端口 SGSEL, SG, LED, ); //----------------------- //--外部端口声明 input CLK_50M,RST_N; output [2:0] SGSEL; //数码管位选信号,前两个显示主路倒计时,后两个显示支路倒计时 output [6:0] SG; //数码管段选信号 output [7:0] LED; //8个LED灯,前3个表示主路的红黄绿,后3个表示支路的红黄绿 reg [2:0] SGSEL_n; reg [6:0] SG_n; reg [2:0] SGSEL; reg [6:0] SG; reg [7:0] LED; //------------------------ //--内部端口声明 reg [6:0] SG_n0,SG_n1,SG_n2,SG_n3,SG_n4,SG_n5,SG_n6,SG_n7; reg [25:0] cnt_time_1s,cnt_time_1s_n; //脉冲计数值 reg [3:0] state,next_state; //交通灯现态和次态 reg [13:0] cnt_time_2ms,cnt_time_2ms_n; //2ms计数值 reg [2:0] cnt_SGSEL,cnt_SGSEL_n; //计数扫描 //------------------------ //--参数定义 parameter IDLE = 4'b0000, S0 = 4'b0001, S1 = 4'b0010, S2 = 4'b0100, S3 = 4'b1000; //--S0指主绿支红,S1指主黄支红,S2指主红支绿,S3指主红支黄 parameter Num_zero = 7'b1111_110,Num_one = 7'b0110_000, Num_three = 7'b1111_001,Num_four = 7'b0110_011, Num_five = 7'b1011_011,Num_six = 7'b1011_111, Num_seven = 7'b1110_000,Num_eight = 7'b1111_111, Num_nine = 7'b1111_011,Num_two = 7'b1101_101; //------------------------ //--1s计数器 always @(posedge CLK_50M or negedge RST_N) begin if(!RST_N) begin cnt_time_1s <= 26'd0; end else begin cnt_time_1s <= cnt_time_1s_n; end end always @(*) begin if(cnt_time_1s == 26'd50_000_000) begin cnt_time_1s_n = 26'd0; end else begin cnt_time_1s_n = cnt_time_1s+1; end end //------------------------- //倒计时的计算 reg [4:0] time_down,time_down_n; //倒计时 reg [4:0] time_max; //时间上限 //倒计时 always @(posedge CLK_50M or negedge RST_N) begin if(!RST_N) begin time_down <= 5'd0; end else begin time_down <= time_down_n; end end always @(*) begin if(cnt_time_1s == 26'd50_000_000) begin time_down_n = time_down-1; end else if(time_down == 5'd0) begin time_down_n = time_max; end else begin time_down_n = time_down; end end //------------------------- //--状态机的编写 //状态转换 always @(posedge CLK_50M or negedge RST_N) begin if(!RST_N) begin state <= IDLE; end else begin state <= next_state; end end //下一状态的计算 always @(*) begin case(state) IDLE: begin time_max = 5'd20; next_state = S0; end S0: begin time_max = 5'd4; if(time_down == 5'd0) begin next_state = S1; end else begin next_state = S0; end end S1: begin time_max = 5'd10; if(time_down == 5'd0) begin next_state = S2; end else begin next_state = S1; end end S2: begin time_max = 5'd4; if(time_down == 5'd0) begin next_state = S3; end else begin next_state = S2; end end S3: begin time_max = 5'd20; if(time_down == 5'd0) begin next_state = S0; end else begin next_state = S3; end end default: begin time_max = 5'bxxxxx; next_state = 4'bxxxx; end endcase end //输出逻辑的处理 always @(*) begin case(state) IDLE: LED = 8'b0000_0000; S0: LED = 8'b0010_0100; S1: LED = 8'b0100_0100; S2: LED = 8'b1000_0001; S3: LED = 8'b1000_0010; default: LED = 8'b0000_0000; endcase end //------------------------------ //--数码管显示倒计时 //每2ms扫描一次数码管 //2ms计数器 always @(posedge CLK_50M or negedge RST_N) begin if(!RST_N) begin cnt_time_2ms <= 14'd0; end else begin cnt_time_2ms <= cnt_time_2ms_n; end end always @(*) begin if(cnt_time_2ms == 14'd10_000) begin cnt_time_2ms_n = 14'd0; end else begin cnt_time_2ms_n = cnt_time_2ms+1; end end always @(posedge CLK_50M or negedge RST_N) begin if(!RST_N) begin cnt_SGSEL <= 3'd0; end else begin cnt_SGSEL <= cnt_SGSEL_n; end end always @(*) begin if(cnt_time_2ms == 14'd10_000) begin cnt_SGSEL_n = cnt_SGSEL+1; end else begin cnt_SGSEL_n = cnt_SGSEL; end end //数码管扫描译码 always @(*) begin case(cnt_SGSEL) 3'd0: begin SGSEL = 3'b000; SG = SG_n0; end 3'd1: begin SGSEL = 3'b001; SG = SG_n1; end 3'd2: begin SGSEL = 3'b010; SG = 7'd0; end 3'd3: begin SGSEL = 3'b011; SG = 7'd0; end 3'd4: begin SGSEL = 3'b100; SG = 7'd0; end 3'd5: begin SGSEL = 3'b101; SG = 7'd0; end 3'd6: begin SGSEL = 3'b110; SG = SG_n6; end 3'd7: begin SGSEL = 3'b111; SG = SG_n7; end default: begin SGSEL = 3'bxxx; SG = 7'bxxxx_xxx; end endcase end always @(*) begin case(time_down) 5'd0: begin SG_n0 = Num_zero; SG_n1 = Num_zero; SG_n6 = Num_zero; SG_n7 = Num_zero; end 5'd1: begin SG_n0 = Num_one; SG_n1 = Num_zero; SG_n6 = Num_one; SG_n7 = Num_zero; end 5'd2: begin SG_n0 = Num_two; SG_n1 = Num_zero; SG_n6 = Num_two; SG_n7 = Num_zero; end 5'd3: begin SG_n0 = Num_three; SG_n1 = Num_zero; SG_n6 = Num_three; SG_n7 = Num_zero; end 5'd4: begin SG_n0 = Num_four; SG_n1 = Num_zero; SG_n6 = Num_four; SG_n7 = Num_zero; end 5'd5: begin SG_n0 = Num_five; SG_n1 = Num_zero; SG_n6 = Num_five; SG_n7 = Num_zero; end 5'd6: begin SG_n0 = Num_six; SG_n1 = Num_zero; SG_n6 = Num_six; SG_n7 = Num_zero; end 5'd7: begin SG_n0 = Num_seven; SG_n1 = Num_zero; SG_n6 = Num_seven; SG_n7 = Num_zero; end 5'd8: begin SG_n0 = Num_eight; SG_n1 = Num_zero; SG_n6 = Num_eight; SG_n7 = Num_zero; end 5'd9: begin SG_n0 = Num_nine; SG_n1 = Num_zero; SG_n6 = Num_nine; SG_n7 = Num_zero; end 5'd10: begin SG_n0 = Num_zero; SG_n1 = Num_one; SG_n6 = Num_zero; SG_n7 = Num_one; end 5'd11: begin SG_n0 = Num_one; SG_n1 = Num_one; SG_n6 = Num_one; SG_n7 = Num_one; end 5'd12: begin SG_n0 = Num_two; SG_n1 = Num_one; SG_n6 = Num_two; SG_n7 = Num_one; end 5'd13: begin SG_n0 = Num_three; SG_n1 = Num_one; SG_n6 = Num_three; SG_n7 = Num_one; end 5'd14: begin SG_n0 = Num_four; SG_n1 = Num_one; SG_n6 = Num_four; SG_n7 = Num_one; end 5'd15: begin SG_n0 = Num_five; SG_n1 = Num_one; SG_n6 = Num_five; SG_n7 = Num_one; end 5'd16: begin SG_n0 = Num_six; SG_n1 = Num_one; SG_n6 = Num_six; SG_n7 = Num_one; end 5'd17: begin SG_n0 = Num_seven; SG_n1 = Num_one; SG_n6 = Num_seven; SG_n7 = Num_one; end 5'd18: begin SG_n0 = Num_eight; SG_n1 = Num_one; SG_n6 = Num_eight; SG_n7 = Num_one; end 5'd19: begin SG_n0 = Num_nine; SG_n1 = Num_one; SG_n6 = Num_nine; SG_n7 = Num_one; end 5'd20: begin SG_n0 = Num_zero; SG_n1 = Num_two; SG_n6 = Num_zero; SG_n7 = Num_two; end default: begin SG_n0 = 7'd0; SG_n1 = 7'd0; SG_n6 = 7'd0; SG_n7 = 7'd0; end endcase end endmodule |
7个回答
仅看图说话:LED[7:0]中某一位或某些位始终为0。
最佳答案
代码很简单,前一部分是十字路口红绿灯的状态转换,LED代表红黄绿灯,后一部分是倒计时显示,在数码管显示。
中间两个状态一直亮3个灯,我很烦恼。。。 求大神解释 谢谢啦~ |
这是什么语言呀 没有接触过
谢谢! 按照提示,我把LED的8位改成六位,这样原本保持为0的两位就不存在了,LED接地确实消失了。神了! 但是,S2状态时,LED[6]居然亮了。。LED[7]和LED[6]的引脚我都没有接上,数码管的小数点也亮了,我根本就没接上啊。 求大神解释~ |
justbetter 发表于 2016-11-15 20:40 虽然不知道原因,但LED接地已经消失。至于LED[6]和小数点莫名其妙地亮了,发现是板子的设计问题。 非常感谢你的回答~ |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
792 浏览 0 评论
NVMe over Fabrics 国产 IP:高性能网络存储解决方案
750 浏览 0 评论
130 浏览 0 评论
NVMe高速传输之摆脱XDMA设计54:如何测试队列管理功能2
437 浏览 0 评论
NVMe高速传输之摆脱XDMA设计53:如何测试队列管理功能
769 浏览 0 评论
4574 浏览 64 评论
浏览过的版块 |
/9
GMT+8, 2025-12-15 07:35 , Processed in 3.608183 second(s), Total 55, Slave 47 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4849
