`资料摘自国外XX网站。我很喜欢(其实很喜欢板子排布风格)·~-~。所以分享给喜欢折腾的盆友 哈哈 其实本来想翻译来着 但是看原理图什么都有而且量太大(主要懒) 想着大家肯定都能领悟哈。所以PDF里面的用户从手册大家自行领悟,以及里面的代码解释什么乱七八杂的慢慢看吧 全当锻炼英文水平了 祝大家国庆快乐。单身狗可以做做装个逼自我娱乐下哈哈 大神勿喷!!!(*^__^*) …… 仅供娱乐学习 切勿用于商业用途, 代码: /* Rotary_Encoder_LED_Ring_Example www.mayhewlabs.com/products/rotary-encoder-led-ring Copyright (c) 2011 Mayhew Labs. Written by Mark Mayhew This example shows 3 sequences that are possible on the ring of LEDs around the encoder based on rotation of an encoder. The 3 sequences are selected by entering 1, 2, or 3 in the serial command prompt. The serial window shows the current rotary encoder count. As the encoder is turned, the serial display shows a raw count of the rotary encoder's value and the LEDs show a scaled version of the value. If the button on the rotary encoder is pushed, the bottom LED will come on. Each section of code below discusses the process required to do this. A note on setting the output sequence:Think of each LED as a single bit in a 16-bit long binary string. If a bit is 1, the LED is on, if a bit is 0, the LED is off. By making a string of ones and zeros, we choose which LEDs to have on and off, and then send this string to the shift register to display it.For example 1000000000000001 binary (0x8001 in hex) will have the fist and last LEDs on, the rest off. CREDIT:Reading the rotary encoder is performed with Oleg's example code:ahttp://www.circuitsathome.com/mcu/reading-rotary-encoder-on-arduino*///These are the pins that will talk to the shift register through SPI#define SDI 2 //Data#define CLK 3 //Clock#define LE 4 //Latch//These are the rotary encoder pins A, B, and switch#define ENC_A 8#define ENC_B 9#define ENC_SW 10#define ENC_PORT PINB //The port that the rotary encoder is on (see http://www.arduino.cc/en/Reference/PortManipulation)// Global variablesint scaledCounter = 0; //The LED output is based on a scaled veryson of the rotary encoder counterint sequenceNumber=0; //The output sequence for the LEDsint incomingByte = 0; //Serial input to select LED output sequence/*This is a 2 dimensional array with 3 LED sequences. The outer array is the sequence; the inner arrays are the values to output at each step of each sequence. The output values are 16 bit hex values (hex math is actually easier here!). An LED will be on if its corresponding binary bit is a one, for example: 0x7 = 0000000000000111 and the first 3 LEDs will be on. The data type must be 'unsigned int' if the sequence uses the bottom LED since it's value is 0x8000 (out of range for signed int).*/unsigned int sequence[3][16] = {{0x0,0x1,0x2,0x4,0x8,0x10,0x20,0x40,0x80,0x100,0x200,0x400,0x800,0x1000,0x2000,0x4000}, {0x0,0x1,0x3,0x7,0xf,0x1f,0x3f,0x7f,0xff,0x1ff,0x3ff,0x7ff,0xfff,0x1fff,0x3fff,0x7fff}, {0x0,0x7fff,0x3ffe,0x1ffc,0xff8,0x7f0,0x3e0,0x1c0,0x80,0x1c0,0x3e0,0x7f0,0xff8,0x1ffC,0x3ffe,0x7fff}, };void setup(){ //Set SPI pins to output pinMode(SDI, OUTPUT); pinMode(CLK, OUTPUT); pinMode(LE,OUTPUT); //Set encoder pins to input, turn internal pull-ups on pinMode(ENC_A, INPUT); digitalWrite(ENC_A, HIGH); pinMode(ENC_B, INPUT); digitalWrite(ENC_B, HIGH); pinMode(ENC_SW, INPUT); digitalWrite(ENC_SW, HIGH); //Set serial rate, prompt for desired sequence Serial.begin(115200); Serial.println("Enter 1, 2, or 3 to change the LED sequence");}void loop(){ //Local Variables static uint8_t counter = 0; //this variable will be changed by encoder input int8_t tmpdata; //Get any serial input if (Serial.available() > 0) { incomingByte = Serial.read(); } //if the serial input is valid, set the LED output sequence appropriately if (incomingByte == '1') sequenceNumber=0; if (incomingByte == '2') sequenceNumber=1; if (incomingByte == '3') sequenceNumber=2; //Call read_encoder() function tmpdata = read_encoder(); //if the encoder has moved if(tmpdata) { //Print out the counter value Serial.print("Counter value: "); Serial.println(counter, DEC); //Set the new counter value of the encoder counter += tmpdata; //Scale the counter value for referencing the LED sequence //***NOTE: Change the map() function to suit the limits of your rotary encoder application. // The first two numbers are the lower, upper limit of the rotary encoder, the // second two numbers 0 and 14 are limits of LED sequence arrays. This is done // so that the LEDs can use a different scaling than the encoder value. scaledCounter = map(counter,0,100,0,15); //Send the LED output to the shift register digitalWrite(LE,LOW); shiftOut(SDI,CLK,MSBFIRST,(sequence[sequenceNumber][scaledCounter] >> 8)); //High byte first shiftOut(SDI,CLK,MSBFIRST,sequence[sequenceNumber][scaledCounter]); //Low byte second digitalWrite(LE,HIGH); } //If the encoder switch is pushed, this will turn on the bottom LED. The bottom LED is turned //on by 'OR-ing' the current display with 0x8000 (1000000000000000 in binary) if (!digitalRead(ENC_SW)) { digitalWrite(LE,LOW); shiftOut(SDI,CLK,MSBFIRST,((sequence[sequenceNumber][scaledCounter]|0x8000) >> 8)); shiftOut(SDI,CLK,MSBFIRST,sequence[sequenceNumber][scaledCounter]); digitalWrite(LE,HIGH); }}/************************************************************************** read_encoder() function as provided by Oleg: ** http://www.circuitsathome.com/mcu/reading-rotary-encoder-on-arduino ** ** Returns change in encoder state (-1,0,1) ************************************************************************* */int8_t read_encoder(){ int8_t enc_states[] = {0,-1,1,0,1,0,0,-1,-1,0,0,1,0,1,-1,0}; static uint8_t old_AB = 0; /**/ old_AB <<= 2; //remember previous state old_AB |= ( ENC_PORT & 0x03 ); //add current state return ( enc_states[( old_AB & 0x0f )]);} `
Rotary Encoder LED Ring User Guide.pdf
(447.16 KB, 下载次数: 0
tlc5925.pdf
(1.21 MB, 下载次数: 0
好吧 代码出乎我意料的乱 从新打上传
WIO Terminal +MCP2515 实现车辆OBD的速度监控
10379 浏览 0 评论
60659 浏览 77 评论
5967 浏览 3 评论
一块扩展板完成Arduino的10类37项实验(代码+图形+仿真)
36180 浏览 219 评论
10030 浏览 0 评论
496浏览 1评论
请教:esp32中用u8g2显示shtc3传感器数据到i2c液晶屏,显示不稳定的问题
1264浏览 1评论
1404浏览 1评论
612浏览 0评论
731浏览 0评论
GMT+8, 2024-12-1 10:20 , Processed in 0.561247 second(s), Total 76, Slave 57 queries .
