扫一扫,分享给好友
我精通电脑和电子产品,但我是34970A的新手。
我已经阅读了有关在Windows操作系统中使用RS-232的通知,并在本论坛,手册以及有关34970A和Benchlink Data Logger 3软件的其他方面进行了搜索和阅读。 从我所看到的,似乎可以将所有这些设备一起操作 - 我只需要一些帮助来完成这个项目。 此时,Connection Expert识别出34970A在COM3上,但是发出警告“某些设备信息与之前的设置不匹配”,我不知道这意味着什么或如何继续前进。 我目前安装了以下内容:Data Logger 3 v4.2.00 IO Library Suite 16_2_15823当我运行Benchlink Data Logger并在“添加仪器”和“查找”下搜索34970A时,在“查找仪器状态”窗口中返回一条消息 '5。 与'和'沟通6。 在与地址处的仪器交互期间发生错误:ASRL3 :: INSTR原因(发生通信错误。)'。 虽然在以前的安装中采取相同的操作,但我会收到一个超时错误,但是我安装了一些其他驱动程序(IVISharedComponents和VisaSharedComponents),我已经删除了这些驱动程序以便开始新的并且完全了解所需的内容 得到这个东西,因为到目前为止还没那么直截了当。 因此,我假设我需要首先解决Connection Expert中的连接故障,以便让笔记本电脑识别34970A。 我如何前进?编辑:jrevefel于2012年4月25日下午1:28 以上来自于谷歌翻译 以下为原文 I am proficient with computers and electronics but I am new to the 34970A. I've read the notice about using RS-232 with a Windows OS and searched and read and much as possible on this forum, the manuals, and otherwise about the 34970A and the Benchlink Data Logger 3 software. From what I've read, it certainly seems possible to operate all of this equipment together - I just need some help getting through this proecess. At this point, the Connection Expert recognizes that the 34970A is on COM3, but throws a warning that 'Some of the device information did not match the previous setting' which I have no idea what this means or how to move forward. I have currently installed the following: Data Logger 3 v4.2.00 IO Library Suite 16_2_15823 When I currently run Benchlink Data Logger and search for the 34970A under 'Add Instruments' and 'Find' a message is returned in the 'Find Instrument Status' window that '5. Communicating with ' and '6. Error occurred during interaction with instrument at address: ASRL3::INSTR reason in (Communication error occurred.)'. While taking the same action in a previous installation, I would receive a time-out error but I had some other drivers (IVISharedComponents and VisaSharedComponents) installed that I have since deleted in order to start out fresh and have a complete understanding of what's required to get this thing to work since it has not been so straight-forward thus far. So, I assume that I need to begin by trouble-shooting the connection within Connection Expert in order to get the laptop to recognize the 34970A. How do I move forward? Edited by: jrevefel on Apr 25, 2012 1:28 PM 附件
10个回答
我之前没有看到过“有些设备信息与以前的设置不匹配”,但听起来好像34970A设置为在断电之前的最后状态启动而不是所有相同的卡
已安装。 在任何情况下,都应设置为在默认复位条件下上电。 您可以从前面板设置,按Shift> Utility,按下Utility 3次,您会看到“POWER ON LAST”。 旋转旋钮更改LAST ro RESET,然后再次按Utility键。 仪器和计算机RS-232设置不匹配可能导致通信错误,或者可能是附件中所述的笔记本电脑RS-232硬件实现。 我希望不是那样的。 ACE有一点问题,你必须以管理员的身份运行才能使RS-232设置的更改生效。 转到c: program Agilent中的Agilent connection Expert,打开属性并检查以管理员身份运行。 以上来自于谷歌翻译 以下为原文 I've not seen this 'Some of the device information did not match the previous setting' before, but it sounds like the 34970A is set to power up in the last state it was in before it was powered down and not all the same cards are installed. In any case, it should be set to power up in the default reset condition. You can set that from the front panel, by pressing Shift > Utility, press the Utility 3 times and you should see "POWER ON LAST". Rotate the knob to change LAST ro RESET and press the Utility key again. The communication error could be cause by the instrument and the computer RS-232 settings not matching or it could possibly be the Laptop RS-232 hardware implementation as described in the attached file. I hope it's not that. There's a bit of a gotcha with ACE in that you have to run it as an administrator to make changes in the RS-232 settings take effect. Go to Agilent connection Expert in c:programAgilent, and open properties and check for run as administrator. 附件
lanziji 发表于 2019-9-16 13:32 > {quote:title = tomc写道:} {quote}>我之前没有看到过“有些设备信息与以前的设置不匹配”,但听起来好像34970A设置为在最后状态下启动 在电源关闭之前就已经安装了,并没有安装所有相同的卡。 在任何情况下,都应设置为在默认复位条件下上电。 您可以从前面板设置,按Shift> Utility,按下Utility 3次,您会看到“POWER ON LAST”。 旋转旋钮更改LAST ro RESET,然后再次按Utility键。 >>通信错误可能是仪器和计算机RS-232设置不匹配造成的,或者可能是附件中所述的笔记本电脑RS-232硬件实现。 我希望不是那样的。 ACE有一点问题,你必须以管理员的身份运行才能使RS-232设置的更改生效。 转到c: program Agilent中的Agilent connection Expert,打开属性并检查以管理员身份运行。 确实,数据记录器设置为POWER ON LAST,现在已设置为POWER ON RESET,但是没有更改Connection Expert的响应。 我已经联系了我们的IT部门,获取了笔记本电脑的管理员权限,我将以管理员的身份再次安装所有软件并报告回来。 以上来自于谷歌翻译 以下为原文 > {quote:title=tomc wrote:}{quote} > I've not seen this 'Some of the device information did not match the previous setting' before, but it sounds like the 34970A is set to power up in the last state it was in before it was powered down and not all the same cards are installed. In any case, it should be set to power up in the default reset condition. You can set that from the front panel, by pressing Shift > Utility, press the Utility 3 times and you should see "POWER ON LAST". Rotate the knob to change LAST ro RESET and press the Utility key again. > > The communication error could be cause by the instrument and the computer RS-232 settings not matching or it could possibly be the Laptop RS-232 hardware implementation as described in the attached file. I hope it's not that. There's a bit of a gotcha with ACE in that you have to run it as an administrator to make changes in the RS-232 settings take effect. Go to Agilent connection Expert in c:programAgilent, and open properties and check for run as administrator. It's true that the data logger was set to POWER ON LAST and it has now been set to POWER ON RESET but that has not changed the response from the Connection Expert. I have contacted our IT department about getting administrator rights to the laptop and I am going to do another clean install of all software as administrator and report back. |
Hognala,1)你是对的,我们的34970A连接到COM1而不是COM3。
我最初认为它与COM3连接的原因是因为当我通过Connection Expert添加它时,COM3实际上显示了一个连接的仪器,但有一个警告,而COM1显示完整的错误。 所以,我错误地怀疑它位于COM3上。 2)一旦我们建立了COM1上的所有内容,我们确实验证了笔记本电脑/程序和34970A之间的所有设置都是相同的。 3)我们尝试了另一台运行Win98的笔记本电脑,并且已经安装了Data Logger软件。 有了这个,我们也没有运气的RS-232电缆。 因此,我们从其他一个部门引进了另一个34970A并且也没有运气。 我们的IT大师已经有了一些使用其他WinXP笔记本电脑成功设置硬件和软件的经验,所以我们在放弃之前已经坚持了很长时间。 然而,我们很幸运,我们的其他部门确实有一个82357B USB / GPIB接口电缆试用,它立即工作。 因此,我们假设我们的是已发布的标准Windows / RS-232问题。 我们也很幸运,因为我们的其他部门没有使用这种电缆进行任何工作(好像他们只使用他们的34970A进行读数)所以,现在,我们的问题已经解决了。 我们无法解决最初的RS-232问题,但昨晚在我们的系统中进行了测试,现在我们已经开始运行了。 感谢大家的投入,祝您工作顺利! 编辑:jrevefel于2012年4月12日上午6:34编辑:jrevefel于2012年6月22日上午8:55 以上来自于谷歌翻译 以下为原文 Hognala, 1) You are correct that our 34970A was connected to COM1 and not COM3. The reason why I was originally lead to believe that it was connected to COM3 was because when I added it through the Connection Expert, COM3 actually showed an instrument connected, but with a warning, while COM1 showed a complete error. So, I incorrectly suspected that it was located on COM3. 2) Once we had everything on COM1 established, we did verify that all settings were the same between the laptop / program and the 34970A. 3) We did try another laptop which was running Win98 and already had the Data Logger software already installed. With this one we also had no luck with the RS-232 cable. So, we brought in another 34970A used from one of our other divisions and had no luck with it, either. Our IT guru has had some experience setting this hardware and software up with other WinXP laptops with success so we stuck with it for quite some time before giving up. However, we were fortunate in that our other division did have an 82357B USB / GPIB interface cable to try and it worked right away. So, we are assuming that ours was the standard Windows / RS-232 issue as published. We are also fortunate in that our other division does not use this cable for any of their work (seems as though they only use their 34970A for read-outs) so, for now, our problem has been solved. We were not able to trouble-shoot the original RS-232 issue but tested our system overnight last night and we are now off and running. Thank you to all for your input and wishing you success with your work! Edited by: jrevefel on Apr 12, 2012 6:34 AM Edited by: jrevefel on Jun 22, 2012 8:55 AM |
几年前安捷伦承认这是错误的!
[http://www.home.agilent.com/agilent/editorial.jspx?ckey=131609&id=131609&nid=-536897164.536881544.02&lc=eng&cc=CA]您需要的 以上来自于谷歌翻译 以下为原文 Agilent admitted it's fault years ago! [http://www.home.agilent.com/agilent/editorial.jspx?ckey=131609&id=131609&nid=-536897164.536881544.02&lc=eng&cc=CA] You need |
我的计算机上有一个Windows 7 Ultimate OS。
以上来自于谷歌翻译 以下为原文 I have a Windows 7 Ultimate OS on my computer. |
嗨,我遇到了和你一样的问题。
唯一的区别是我的PC是WIN 7专业版。 你能帮忙建议你如何解决这个问题吗? 谢谢。 IO库capture.PNG73.2 KB 以上来自于谷歌翻译 以下为原文 Hi, I suffered the same problem as you did. The only difference is my PC is WIN 7 professional. can you help to advice how you figure it out? Thanks. 附件
嗨Cliff,你发送的Connection Expert屏幕截图中的一切看起来都很好。 扫描仪器时,它会查看所有接口。 如果您没有打开电源并连接到GPIB或其扫描的任何其他接口,它会报告错误,但您可以忽略它们。 单击“将命令发送到此仪器”。 这将打开一个带有默认“* IDN?”的SCPI命令窗口。 准备好出发。 点击“发送和读取”,您将获得34970A ID字符串。 然后单击SYST:ERR? 上面的按钮,它将返回它找到的任何错误代码和消息。 重复该步骤直到+0,返回“No Error”。 使用34970A / 72A chm文件命令参考来查找您想要执行的任何操作的SCPI命令。 如果在插槽1中安装了多路复用器模块,请尝试以下顺序:CONF:VOLT:DC(@ 101:105)>发送ROUT:SCAN(@ 101:105)>发送READ>发送& 如果仍有问题,请阅读联系客户支持。 有关支持联系信息,请参见Keysight产品网页。 如果您使用USB转RS232转换器,其中一些有问题。 我们祝EasySYNC单位好运。 以上来自于谷歌翻译 以下为原文 Hi Cliff, Everything looks fine in the Connection Expert screen shots you sent. When you scan for instruments, it looks at all interfaces. If you don't have anything powered up and connected to GPIB or any other interface it scans, it reports errors, but you can ignore them. Click on "Send Commands To This Instrument". This will bring up a SCPI command window with the default "*IDN?" ready to go. Click on "Send & Read" and you will get the 34970A ID string. Then click on the SYST:ERR? button above and it will return any error codes and messages it finds. Repeat that step until +0, "No Error" is returned. Use the 34970A/72A chm file Command Reference to find the SCPI commands for whatever you want to do. If you have a Multiplexer module installed in slot 1, try the following sequence: CONF:VOLT:DC (@101:105) > Send ROUT:SCAN (@101:105) > Send READ > Send & Read Contact customer support if you still problems. See the Keysight Product web page for the support contact info. If you are using a USB to RS232 converter, some of those have problems. We have had good luck with the EasySYNC unit. 附件 |
lanziji 发表于 2019-9-16 14:53 嗨Tomc,你是如此有帮助,超过官方的支持。 谢谢。 我试过你说的话。 虽然我没有成功发送表扬,因为我不熟悉它。 但是在获得+0后,通过多次单击系统错误返回“无错误”,Benchlink数据记录器3终于找到了它。 非常感谢。 最好的祝福。 克利福德。 以上来自于谷歌翻译 以下为原文 Hi Tomc, You are so helpful, more than the official support. Thank you. I tried what you said. Though I didn't successfully send the commend because I am not familiar with it. But after getting +0, "No Error" returned by click System Error several times , the Benchlink data logger 3 finally found it. Thanks very much. Best regards. Clifford. |
我们的Dell Precision M90笔记本电脑运行Windows 7 Professional,32位,Intel Centrino Duo和USB串行端口。
我们的目标是通过RS-232转USB适配器将笔记本电脑连接到Agilent 34970A,我读到了“使用运行任何Microsoft OS的笔记本电脑在安捷伦仪器上使用RS-232的问题”。 我没有看到帖子中提到的Windows 7,所以我希望这会起作用。 以上来自于谷歌翻译 以下为原文 We have a Dell Precision M90 laptop running Windows 7 Professional, 32 bit, Intel Centrino Duo, and USB serial ports. Our goal is to connect the laptop to the Agilent 34970A with an RS-232 to USB adapter for <$30. I read the article "Problems Using RS-232 on Agilent Instruments with Laptop PCs running any Microsoft OS". I didn't see Windows 7 mentioned in the post, so I'm holding out hope that this will work. |
mikee 发表于 2019-9-16 15:07 Windows 7不太可能产生任何影响。 这就是问题所在的RS-232接口的PC硬件/固件实现。 Benchlink Datalogger软件非常IO密集,非常不容忍任何IO故障。 另一方面,使用我的HP EliteBook 8440p笔记本电脑及其扩展坞,我很少看到任何RS-232问题。 以上来自于谷歌翻译 以下为原文 It's not likely that Windows 7 will make any difference. It's the PC hardware/firmware implementation of the RS-232 interface that's the problem. The Benchlink Datalogger software is very IO intensive very intolerant of any IO glitches. On the other hand with my HP EliteBook 8440p laptop and its docking station, I very rarely see any RS-232 problems. |
只有小组成员才能发言,加入小组>>
2109 浏览 1 评论
1871 浏览 1 评论
1727 浏览 5 评论
2598 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1570 浏览 4 评论
517浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
373浏览 0评论
1430浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
285浏览 0评论
2266浏览 0评论
GMT+8, 2024-5-12 11:25 , Processed in 1.228060 second(s), Total 67, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
