尊敬的先生/女士,
我想在FPGA上实现Zigbee收发器系统。 是否可以在Spartan 3E入门套件上实施? 需要什么其他硬件设备 与FPGA接口? 我无法理解如何 继续这个项目(我是否也必须设计 协议栈)。 Plz很快回答我。 以上来自于谷歌翻译 以下为原文 Dear Sir/Madam, I want to implement Zigbee Transceiver system on FPGA. Whether it is possible to implemnt on Spartan 3E Starter kit? What are the other hardware equipments required for interfacing with FPGA ? I could not able to understand how to proceed for this project(whether i have to also design for protocol stack ). Plz answer me soon. |
2个回答
你可以购买带有uart接口的zigbee收发器,即收发器和同一封装/板上的一些基带控制器,这样你只需将uart连接到fpga,这几乎是微不足道的。
寻找适合aurdino的zigbee模块。 对于fpgas来说它们也应该很容易。 - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 you can buy zigbee transceivers with a uart interface, ie a transceiver and some baseband controller in the same package/board so you only have to connect a uart to the fpga which is almost trivial. look for zigbee modules suitable for aurdino. they should be very easy for fpgas too.- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented.View solution in original post |
寻找适合aurdino的zigbee模块。 对于fpgas来说它们也应该很容易。 - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。 以上来自于谷歌翻译 以下为原文 you can buy zigbee transceivers with a uart interface, ie a transceiver and some baseband controller in the same package/board so you only have to connect a uart to the fpga which is almost trivial. look for zigbee modules suitable for aurdino. they should be very easy for fpgas too.- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. |
只有小组成员才能发言,加入小组>>
2178 浏览 7 评论
2615 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2084 浏览 9 评论
3156 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2207 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
445浏览 1评论
1539浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2183浏览 0评论
515浏览 0评论
1657浏览 0评论
GMT+8, 2024-5-10 03:41 , Processed in 3.039360 second(s), Total 48, Slave 42 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
