我已经下载了发行版,现在当我从下载并解压缩的文件夹执行./setup时,没有任何反应!
我也尝试直接从bin / lin文件夹执行它。同样的事情没有任何反应,安装没有启动..任何想法? 谢谢! 以上来自于谷歌翻译 以下为原文 I have downloaded the distribution, now when i execute ./setup from the downloaded and extracted folder nothing happens! I also tried to execute it directly from bin/lin folder.. same thing nothing happens, installation does not start.. any ideas? thanks! |
4个回答
伙计们,需要帮助!
我也是,尝试在Linux上安装ISE 12.2时遇到同样的问题 - 我的Linux是Fedora 13 32位。 我下载了文件“Xilinx_ISE_DS_Lin_12.2_M.63c.1.1.tar”,解压缩并在源文件夹中以root用户键入“./xsetup”。 结果是 - 没有任何反应 - 没有消息,没有警告,没有。 有什么建议么 ? 以上来自于谷歌翻译 以下为原文 Guys, help needed! Me too, I have the same problem when trying to install ISE 12.2 on Linux - my Linux is Fedora 13 32-bit. I downloaded the file "Xilinx_ISE_DS_Lin_12.2_M.63c.1.1.tar", unpacked and typed "./xsetup" as root user in the source folder. The result is - nothing happens - no message, no warning, nothing. Any suggestions ? |
我差点解决了这个问题......
在我之前的帖子中,我忘了提到我试图在Linux上安装ISE,在VirtualBox上工作。 当然我无法理解为什么ISE不能在VirtualBox下运行的操作系统下安装 - 我没有理由这样做。 也许Xilinx应更新其安装脚本以正确检测操作系统并向用户显示一些消息。 其次,我在正常的64位Fedora 8(不再是VirtualBox)下安装了ISE WebPack 12.2。 现在我想问一下 - 我应该将哪些权限/权限设置为ISE文件和文件夹才能正常使用许可证管理器(和ISE)? 我已经将软件安装为“root”用户,并且许可证管理器无法从GUI中启动 - 既不以“root”身份运行,也不能以普通用户身份运行! 为什么? 如果我从控制台运行管理器它可以工作,甚至似乎在适当的地方复制“.lic”文件。 问题是我每次都必须以“root”用户身份启动软件才能接受许可证 - 否则会显示警告消息。 以上来自于谷歌翻译 以下为原文 I have almost solved the problem... In my previous post I had forgot to mention that I tried to install ISE on Linux working on VirtualBox. Of course I could not understand why ISE cannot be installed under an OS working under VirtualBox - I see no reason for this. Maybe Xilinx should update their install script to properly detect OSs and display some message to the user. Secondly, I have installed ISE WebPack 12.2 under normal 64-bit Fedora 8 (no VirtualBox anymore). Now I want to ask - what rights/permissions should I set to ISE files and folders to be able to use normally the License Manager (and the ISE)??? I have installed the software as "root" user and the License Manager was not able to start from whithin the GUI - neither running as "root" or normal user! Why? If I run the manager from a console it works and even seems to copy the ".lic" file in the proper place. The problem is that I have to start the software as "root" user each time for the license to be accepted - otherwise a warning message is displayed. |
根据我的经验,
- 在linux中使用tar -xf而不是windows来保留文件权限 - 不需要使用“root”安装。 - 如果发生权限问题,请使用chmod -R 777作为安装文件。 顺便说一下,我看到人们在vmware中使用ISE。 以上来自于谷歌翻译 以下为原文 From my experience, - tar -xf in linux rather than windows to keep the file permission - don't need to install using "root". - If permission problem happens, use chmod -R 777 for the installation files. BTW, I have seen people use ISE in vmware. |
当SeLinux不处于Permissive模式时,我在Fedora上看到过这种行为。
当SeLinux通常阻止ISE安装时,症状是xsetup在调用时似乎什么都不做。 以上来自于谷歌翻译 以下为原文 I've seen this behavior on Fedora when SeLinux is not in Permissive mode. When SeLinux blocks the ISE installation, which it typically does, the symptom is that xsetup seems to do nothing when invoked. |
只有小组成员才能发言,加入小组>>
2164 浏览 7 评论
2607 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2080 浏览 9 评论
3152 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2196 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
425浏览 1评论
1526浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2178浏览 0评论
511浏览 0评论
1644浏览 0评论
GMT+8, 2024-4-26 10:26 , Processed in 1.053140 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
