无论驱动程序版本如何,戴上笔记本电脑都无法启动此卡。
我试过20.50到20.80。 他们都没有工作。 该卡被Windows 10识别。戴尔服务代表建议回滚到Windows 4月更新。 安装了更新,仍然遇到同样的问题。 我想知道是否应该更换卡。 任何人都可以给我一些指针来解决问题吗? 以上来自于谷歌翻译 以下为原文 This card came with the Dell laptop will not start regardless of the driver version. I have tried 20.50 to 20.80. None of them worked. The card is recognized by Windows 10. Dell service rep suggested rolling back to Windows April update. Installed the update and still experience the same issue. I am wondering if the card should be replaced. Any one can give me some pointer to remedy the issue? |
3个回答
既然你拿到了笔记本电脑就行不通,我会戴尔更换卡或笔记本电脑。
文件 以上来自于谷歌翻译 以下为原文 Since this has not worked since you got the laptop, I would have Dell replace the card or the laptop. Doc |
我不想发送机器,因为我将不得不创建一个需要几天的备份。 他们不想发送替换卡,因为它不是客户可更换部件。 任何人都有解决方案的相同问题? 该卡工作正常,直到最近我更新了BIOS和windows ... 以上来自于谷歌翻译 以下为原文 I do not want to send the machine in because I will have to create a backup which would take days. They do not want to send a replacement card because it's not a customer replaceable part. Anyone had the same issue with a solution? The card was working fine until recently I updated the bios and windows... |
jerry181855 发表于 2018-10-19 10:04 您好esoworld,感谢您加入此英特尔社区。请尝试清理安装系统制造商提供的无线驱动程序,以防驱动程序/设置损坏。清除安装无线驱动程序如果这些步骤无法解决此问题,请运行 英特尔®系统支持实用程序并将报告附加到此线程.1。下载英特尔®系统支持实用程序并将应用程序保存到您的系统.https://downloadcenter.intel.com/download/25293/Intel-System-Support- Utility-for-Windows-?product = 916002.打开应用程序,然后单击扫描以查看系统和设备信息。 英特尔®系统支持实用程序默认为扫描后输出屏幕上的摘要视图。 单击其中显示摘要的菜单以更改为详细视图.3。要保存扫描,请单击“下一步”,然后单击“保存”。 您可以将文件保存到计算机上任何可访问的位置。要附加文件,必须单击响应框右上角的“使用高级编辑器”,然后右下角会出现“附加”选项 响应框的一角.Wanner G.Intel客户支持技术人员与英特尔公司签订合同 以上来自于谷歌翻译 以下为原文 Hello esoworld, Thank you for joining this Intel Community. Please try a clean install of the wireless driver provided by the system manufacturer in case of corrupted driver/settings. Clean install of the wireless driver If these steps do not fix this issue, please run the Intel® System Support Utility and attach the report to this thread. 1.Download the Intel® System Support Utility and save the application to your system. https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600 2.Open the application and click Scan to see system and device information. The Intel® System Support Utility defaults to the Summary View on the output screen following the scan. Click the menu where it says summary to change to Detailed View. 3.To save your scan, click Next and click Save. You can save the file to any accessible location on your computer. To attach a file, you must click “Use Advanced Editor” on the upper right hand corner of the response box, then the “attach” option will appear on the bottom right hand corner of the response box. Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation |
只有小组成员才能发言,加入小组>>
260浏览 0评论
GMT+8, 2024-5-9 15:04 , Processed in 1.013498 second(s), Total 80, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
