JS早已进化出可以控制笔记本电脑蓝牙设备的能力,所以编写一个HTML就可以完成BLE点灯工作。
示例中有一个BLE从机程序
CH585EVT\EVT\EXAM\BLE\Peripheral
在此基础上添加点灯部分
初始化PA0:
GPIOA_ModeCfg(GPIO_Pin_0, GPIO_ModeOut_PP_5mA);
在peripheral.C中,第一个特征值SIMPLEPROFILE_CHAR1写入事件发生时,增加判断,如果输入为0x20则点亮PA0,否则熄灭PA0
static void simpleProfileChangeCB(uint8_t paramID, uint8_t *pValue, uint16_t len)
switch(paramID)
case SIMPLEPROFILE_CHAR1:
uint8_t newValue[SIMPLEPROFILE_CHAR1_LEN];
tmos_memcpy(newValue, pValue, len);
PRINT("profile ChangeCB CHAR1.. \n");
if(newValue[0]==0x20)
GPIOA_ResetBits(GPIO_Pin_0);
}else {
GPIOA_SetBits(GPIO_Pin_0);
break;
<!DOCTYPE html>
<html lang="zh-CN">
<head>
<meta charset="UTF-8">
<meta name="viewport" content="width=device-width, initial-scale=1.0">
<title>智能灯控制面板</title>
<style>
body {
font-family: 'Arial', sans-serif;
background-color: #f5f5f5;
display: flex;
justify-content: center;
align-items: center;
height: 100vh;
margin: 0;
.control-panel {
background: white;
border-radius: 20px;
box-shadow: 0 10px 30px rgba(0,0,0,0.1);
padding: 30px;
width: 300px;
text-align: center;
h1 {
color: #333;
margin-bottom: 30px;
.btn {
background: #4285f4;
color: white;
border: none;
border-radius: 50px;
padding: 15px 30px;
margin: 10px;
font-size: 18px;
cursor: pointer;
width: 80%;
transition: all 0.3s;
box-shadow: 0 4px 6px rgba(0,0,0,0.1);
.btn:hover {
transform: translateY(-2px);
box-shadow: 0 6px 10px rgba(0,0,0,0.15);
.btn:active {
transform: translateY(0);
.btn.on {
background: #34a853;
.btn.off {
background: #ea4335;
.connection-status {
margin: 20px 0;
font-weight: bold;
.connected {
color: #34a853;
.disconnected {
color: #ea4335;
.advanced-toggle {
color: #4285f4;
text-decoration: underline;
cursor: pointer;
margin-top: 20px;
display: inline-block;
.advanced-settings {
display: none;
margin-top: 20px;
text-align: left;
</style>
</head>
<body>
<div class="control-panel">
<h1>智能灯控制</h1>
<div class="connection-status disconnected" id="connection-status">设备未连接</div>
<button class="btn connect" id="connect-btn">连接设备</button>
<div id="control-buttons" style="display:none;">
<button class="btn on" id="on-btn">开灯</button>
<button class="btn off" id="off-btn">关灯</button>
<button class="btn" id="disconnect-btn">断开连接</button>
</div>
<div class="advanced-toggle" id="advanced-toggle">显示高级设置</div>
<div class="advanced-settings" id="advanced-settings">
<h3>高级设置</h3>
<div>
<label>服务UUID: <input type="text" id="service-uuid" value="0000ffe0-0000-1000-8000-00805f9b34fb"></label>
</div>
<div>
<label>特征值UUID: <input type="text" id="characteristic-uuid" value="0000ffe1-0000-1000-8000-00805f9b34fb"></label>
</div>
<div>
<label>开灯指令: <input type="text" id="on-command" value="20"></label>
</div>
<div>
<label>关灯指令: <input type="text" id="off-command" value="10"></label>
</div>
</div>
</div>
<script>
// 设备配置 (可以在后台预设)
const defaultConfig = {
serviceUUID: '0000ffe0-0000-1000-8000-00805f9b34fb',
characteristicUUID: '0000ffe1-0000-1000-8000-00805f9b34fb',
onCommand: '20',
offCommand: '10'
// DOM元素
const connectBtn = document.getElementById('connect-btn');
const onBtn = document.getElementById('on-btn');
const offBtn = document.getElementById('off-btn');
const disconnectBtn = document.getElementById('disconnect-btn');
const connectionStatus = document.getElementById('connection-status');
const controlButtons = document.getElementById('control-buttons');
const advancedToggle = document.getElementById('advanced-toggle');
const advancedSettings = document.getElementById('advanced-settings');
// 设备变量
let device = null;
let characteristic = null;
let isConnected = false;
// 初始化UI
document.getElementById('service-uuid').value = defaultConfig.serviceUUID;
document.getElementById('characteristic-uuid').value = defaultConfig.characteristicUUID;
document.getElementById('on-command').value = defaultConfig.onCommand;
document.getElementById('off-command').value = defaultConfig.offCommand;
// 连接设备
connectBtn.addEventListener('click', async () => {
try {
connectionStatus.textContent = "正在连接...";
device = await navigator.bluetooth.requestDevice({
acceptAllDevices: true,
//optionalServices: ['generic_access'] // 默认包含的服务
optionalServices: ['0000ffe0-0000-1000-8000-00805f9b34fb']
//filters: [
//{ namePrefix: 'simple' }
const server = await device.gatt.connect();
const service = await server.getPrimaryService(defaultConfig.serviceUUID);
characteristic = await service.getCharacteristic(defaultConfig.characteristicUUID);
device.addEventListener('gattserverdisconnected', onDisconnected);
isConnected = true;
connectionStatus.textContent = "设备已连接";
connectionStatus.className = "connection-status connected";
connectBtn.style.display = "none";
controlButtons.style.display = "block";
} catch (error) {
console.error("连接失败:", error);
connectionStatus.textContent = "连接失败";
connectionStatus.className = "connection-status disconnected";
// 断开连接
disconnectBtn.addEventListener('click', () => {
if (device && isConnected) {
device.gatt.disconnect();
// 断开连接处理
function onDisconnected() {
device = null;
connectionStatus.textContent = "设备未连接";
connectBtn.style.display = "block";
controlButtons.style.display = "none";
// 开灯
onBtn.addEventListener('click', async () => {
if (!isConnected) return;
try {
const command = document.getElementById('on-command').value.trim();
const data = hexStringToArrayBuffer(command);
await characteristic.writeValue(data);
console.log("开灯指令发送成功");
} catch (error) {
console.error("发送开灯指令失败:", error);
// 关灯
offBtn.addEventListener('click', async () => {
try {
const command = document.getElementById('off-command').value.trim();
console.log("关灯指令发送成功");
} catch (error) {
console.error("发送关灯指令失败:", error);
// 切换高级设置
advancedToggle.addEventListener('click', () => {
if (advancedSettings.style.display === 'none') {
advancedSettings.style.display = 'block';
advancedToggle.textContent = '隐藏高级设置';
} else {
advancedSettings.style.display = 'none';
advancedToggle.textContent = '显示高级设置';
// 辅助函数: 十六进制字符串转ArrayBuffer
function hexStringToArrayBuffer(hexString) {
hexString = hexString.replace(/\s/g, '');
if (hexString.length % 2 !== 0) {
throw new Error('十六进制字符串长度必须为偶数');
const bytes = new Uint8Array(hexString.length / 2);
for (let i = 0; i < hexString.length; i += 2) {
bytes[i/2] = parseInt(hexString.substr(i, 2), 16);
return bytes.buffer;
</script>
</body>
</html>
执行HTML
为了体现卓然不同的气质,起了一个非常中二的名称"智能灯控制"
更多回帖
