我将你的代码数据放到我们的EVM板上测试,发现你的PLL与Divider设置有问题。
这个系数是你们需要的吗?并且没有power
on divider。
还有就是你们的配置时序也有点问题。建议参考如下顺序:
page 0 is selected
w
30 00 00
reg[ 0][ 1] = 0x01 ; Initialize the device through software reset
01
page 1 is selected
w
30 00 01
reg[ 1][ 1] = 0x08 ; Disable weak AVDD to DVDD connection
08
reg[ 1][ 2] = 0x00 ; Enable Master Analog Power Control
00
reg[ 1][ 71] = 0x32 ; Set the input power-up time to 3.1ms
w
30 47 32
reg[ 1][123] = 0x05 ; Force REF charging time to 40ms
w
30 7b 05
page 0 is selected
w
30 00 00
reg[ 0][ 5] = 0x91 ; P=1, R=1, J=24
w
30 05 91
reg[ 0][ 6] = 0x18 ; P=1, R=1, J=24
18
reg[ 0][ 7] = 0x00 ; D=0000 (MSB)
00
reg[ 0][ 8] = 0x00 ; D=0000 (LSB)
00
reg[ 0][ 4] = 0x03 ; PLL_clkin = MCLK, codec_clkin = PLL_CLK, PLL on
w
30 04 03
reg[ 0][254] = 0x0a ; Delay 10ms for PLL to lock
w
30 fe 0a
reg[ 0][ 12] = 0x88 ; MDAC = 8, divider powered on
w
30 0c 88
reg[ 0][ 13] = 0x03 ; DOSR = 768 (MSB)
03
reg[ 0][ 14] = 0x00 ; DOSR = 768 (LSB)
00
reg[ 0][ 18] = 0x02 ; NADC = 2, divider powered off
w
30 12 02
reg[ 0][ 19] = 0xb0 ; MADC = 48, divider powered on
b0
reg[ 0][ 20] = 0x80 ; AOSR = 128
80
reg[ 0][ 11] = 0x82 ; NDAC = 2, divider powered on
w
30 0b 82
on divider。
page 0 is selected
w
30 00 00
01
page 1 is selected
w
30 00 01
08
00
w
30 47 32
w
30 7b 05
page 0 is selected
w
30 00 00
w
30 05 91
18
00
00
w
30 04 03
w
30 fe 0a
w
30 0c 88
03
00
w
30 12 02
b0
80
w
30 0b 82
