STM32
直播中
fejlkel
9年用户 1127经验值
擅长:制造/封装
私信 关注
[问答]
STM32F030R8电机驱动函数中电机位置数值跳变的原因?
//motor.c
#define m0_xc_max 1050   //250*5
#define m1_xc_max 375     //150*5/2
#define m2_xc_max 0
#define m3_xc_max 500    //100*5//可能需要修改
#define m4_xc_max 1650   //330*5
#define m0_xc_min 0
#define m1_xc_min -375   //-(150*5/2)
#define m2_xc_min -1000   //-200*5
#define m3_xc_min 0
#define m4_xc_min 0
//电机初始状态
#define m0_re_state 0
#define m1_re_state 0
#define m2_re_state 0
#define m3_re_state 0
#define m4_re_state 0
#define m5_re_state 0
//电机驱动的宏定义
#define motor00_stop HAL_GPIO_WritePin(M0__GPIO_Port,M0__Pin ,GPIO_PIN_RESET);HAL_GPIO_WritePin (MO__GPIO_Port ,MO__Pin,GPIO_PIN_RESET)
#define motor00_zhengzhuan HAL_GPIO_WritePin (M0__GPIO_Port ,M0__Pin ,GPIO_PIN_SET);HAL_GPIO_WritePin (MO__GPIO_Port ,MO__Pin ,GPIO_PIN_RESET)
#define motor00_fanzhuan HAL_GPIO_WritePin (M0__GPIO_Port ,M0__Pin ,GPIO_PIN_RESET);HAL_GPIO_WritePin (MO__GPIO_Port ,MO__Pin ,GPIO_PIN_SET)
#define motor01_stop HAL_GPIO_WritePin (M1__GPIO_Port ,M1__Pin ,GPIO_PIN_RESET);HAL_GPIO_WritePin (M1_F5_GPIO_Port  ,M1_F5_Pin  ,GPIO_PIN_RESET)
#define motor01_zhengzhuan HAL_GPIO_WritePin (M1__GPIO_Port ,M1__Pin ,GPIO_PIN_SET);HAL_GPIO_WritePin (M1_F5_GPIO_Port  ,M1_F5_Pin  ,GPIO_PIN_RESET)
#define motor01_fanzhuan HAL_GPIO_WritePin (M1__GPIO_Port ,M1__Pin ,GPIO_PIN_RESET);HAL_GPIO_WritePin (M1_F5_GPIO_Port  ,M1_F5_Pin  ,GPIO_PIN_SET)
#define motor02_stop HAL_GPIO_WritePin (M2__GPIO_Port ,M2__Pin ,GPIO_PIN_RESET);HAL_GPIO_WritePin (M2_B10_GPIO_Port  ,M2_B10_Pin  ,GPIO_PIN_RESET)
#define motor02_zhengzhuan HAL_GPIO_WritePin (M2__GPIO_Port ,M2__Pin ,GPIO_PIN_RESET);HAL_GPIO_WritePin (M2_B10_GPIO_Port  ,M2_B10_Pin  ,GPIO_PIN_SET)
#define motor02_fanzhuan HAL_GPIO_WritePin (M2__GPIO_Port ,M2__Pin ,GPIO_PIN_SET);HAL_GPIO_WritePin (M2_B10_GPIO_Port  ,M2_B10_Pin  ,GPIO_PIN_RESET)
#define motor03_stop HAL_GPIO_WritePin(M3__GPIO_Port ,M3__Pin ,GPIO_PIN_SET);HAL_GPIO_WritePin (M3_C9_GPIO_Port,M3_C9_Pin,GPIO_PIN_RESET)
#define motor03_zhengzhuan HAL_GPIO_WritePin(M3__GPIO_Port ,M3__Pin ,GPIO_PIN_SET);HAL_GPIO_WritePin (M3_C9_GPIO_Port  ,M3_C9_Pin  ,GPIO_PIN_RESET)
#define motor03_fanzhuan HAL_GPIO_WritePin (M3__GPIO_Port ,M3__Pin ,GPIO_PIN_RESET);HAL_GPIO_WritePin (M3_C9_GPIO_Port  ,M3_C9_Pin  ,GPIO_PIN_SET)
#define motor04_stop HAL_GPIO_WritePin (M4__GPIO_Port ,M4__Pin ,GPIO_PIN_RESET);HAL_GPIO_WritePin (M4_C14_GPIO_Port ,M4_C14_Pin  ,GPIO_PIN_RESET)
#define motor04_zhengzhuan HAL_GPIO_WritePin (M4__GPIO_Port ,M4__Pin ,GPIO_PIN_SET);HAL_GPIO_WritePin (M4_C14_GPIO_Port ,M4_C14_Pin  ,GPIO_PIN_RESET)
#define motor04_fanzhuan HAL_GPIO_WritePin (M4__GPIO_Port ,M4__Pin ,GPIO_PIN_RESET);HAL_GPIO_WritePin (M4_C14_GPIO_Port ,M4_C14_Pin  ,GPIO_PIN_SET)
//motor0_x:电机名称,position:电机的位置,mode:电机模式,0停止,1电机正转,2电机反转
void motor_control(int motor0_x,int *position,int mode)
        int xc_max,xc_min;
        switch(motor0_x)
                case 0:
                        xc_max=m0_xc_max;
                        xc_min=m0_xc_min;
                        switch(mode)
                                case 1:
                                        if(*position==xc_max)
                                                motor00_stop;
                                        else if(*positionxc_min)
                                                motor00_fanzhuan;
                                                *position -=1;
                                }break;
                                default :
                                        motor00_stop;
                }break;
                case 1:
                        xc_max=m1_xc_max;
                        xc_min=m1_xc_min;
                        switch(mode)
                                case 1:
                                                motor01_stop;
                                                motor01_fanzhuan;
                                                *position -=1;
                                }break;
                                default :
                                        motor01_stop;
                }break;
                case 2:
                        xc_max=m2_xc_max;
                        xc_min=m2_xc_min;
                        switch(mode)
                                case 1:
                                                motor02_stop;
                                                motor02_fanzhuan;
                                                *position -=1;
                                }break;
                                default :
                                        motor02_stop;
                }break;
                case 3:
                        xc_max=m3_xc_max;
                        xc_min=m3_xc_min;
                        switch(mode)
                                case 1:
                                                motor03_stop;
                                                motor03_fanzhuan;
                                                *position -=1;
                                }break;
                                default :
                                        motor03_stop;
                }break;
                case 4:
                        xc_max=m4_xc_max;
                        xc_min=m4_xc_min;
                        switch(mode)
                                case 1:
                                                motor04_stop;
                                                motor04_fanzhuan;
                                                *position -=1;
                                }break;
                                default :
                                        motor04_stop;
                }break;
                default :;
}//main.c
//IO定义
static void MX_GPIO_Init(void)
  GPIO_InitTypeDef GPIO_InitStruct;
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOC_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
  __HAL_RCC_GPIOF_CLK_ENABLE();
  __HAL_RCC_GPIOB_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(GPIOC, M4__Pin|M4_C14_Pin|M5__Pin|M3__Pin
                          |M3_C9_Pin, GPIO_PIN_RESET);
  HAL_GPIO_WritePin(GPIOA, M0__Pin|MO__Pin, GPIO_PIN_RESET);
  HAL_GPIO_WritePin(GPIOF, M1__Pin|M1_F5_Pin, GPIO_PIN_RESET);
  HAL_GPIO_WritePin(GPIOB, M2__Pin|M2_B10_Pin, GPIO_PIN_RESET);
  /*Configure GPIO pins : M4__Pin M4_C14_Pin M5__Pin */
  GPIO_InitStruct.Pin = M4__Pin|M4_C14_Pin|M5__Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  HAL_GPIO_Init(GPIOC,  GPIO_InitStruct);
  /*Configure GPIO pins : M0__Pin MO__Pin */
  GPIO_InitStruct.Pin = M0__Pin|MO__Pin;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
  HAL_GPIO_Init(GPIOA,  GPIO_InitStruct);
  /*Configure GPIO pins : M1__Pin M1_F5_Pin */
  GPIO_InitStruct.Pin = M1__Pin|M1_F5_Pin;
  HAL_GPIO_Init(GPIOF,  GPIO_InitStruct);
  /*Configure GPIO pins : M2__Pin M2_B10_Pin */
  GPIO_InitStruct.Pin = M2__Pin|M2_B10_Pin;
  HAL_GPIO_Init(GPIOB,  GPIO_InitStruct);
  /*Configure GPIO pins : M3__Pin M3_C9_Pin */
  GPIO_InitStruct.Pin = M3__Pin|M3_C9_Pin;
/* USART1 init function */
static void MX_USART1_UART_Init(void)
  huart1.Instance = USART1;
  huart1.Init.BaudRate = 115200;
  huart1.Init.WordLength = UART_WORDLENGTH_8B;
  huart1.Init.StopBits = UART_STOPBITS_1;
  huart1.Init.Parity = UART_PARITY_NONE;
  huart1.Init.Mode = UART_MODE_TX_RX;
  huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart1.Init.OverSampling = UART_OVERSAMPLING_16;
  huart1.Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE;
  huart1.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
  if (HAL_UART_Init( huart1) != HAL_OK)
    _Error_Handler(__FILE__, __LINE__);
//将接受过来的信息进行处理,其中case11,12复位
void xinxichuli(uint8_t x)
        switch(x)
                case 1:
                        motor_control (0, m0_position,1);
                }break;
                case 2:
                        motor_control(0, m0_position,2);
                }break;
                case 3:
                        motor_control(1, m1_position,1);
                }break;
                case 4:
                        motor_control(1, m1_position,2);
                }break;
                case 5:
                        motor_control(2, m2_position,2);
                }break;
                case 6:
                        motor_control(2, m2_position,1);
                }break;
                case 7://需要修改
                        while(1)
                                if(m1_position ==m1_re_state )
                                        do
                                        }while(m1_position !=m1_xc_max);
                                else if(m1_position ==m1_xc_max )
                                        do
                                                motor_control(M1, m1_position,2);
                                        }while(m1_position !=m1_re_state );
                                else if (m1_position ==m1_xc_min )
                                        do
                                                motor_control(M1, m1_position,1);
                                        motor_control(M1, m1_position,0);
                                for(int w=0;wm1_re_state )
                                for(int qqe=m1_position ;qqe>m1_re_state ;qqe--)
                                if(m1_position==m1_re_state)
                        else if(m1_position m1_re_state ;qqew--)
                //                        motor1 (2);
                                        motor_control (M1, m1_position ,2);
                        else if(m0_position >m0_re_state )
                                while(m0_position>m0_re_state )
                                        motor_control(M0, m0_position,2);
                                motor_control(M0, m0_position,0);
                        else if(m0_position m2_re_state )
                                while(m2_position>m2_re_state )
                                        motor_control(M2, m2_position,2);
                                motor_control(M2, m2_position,0);
                        else if(m2_position m1_re_state)
                        for (int qqe = m1_position; qqe>m1_re_state; qqe--)
                        if (m1_position == m1_re_state)
                else if (m1_position m1_re_state; qqew--)
                else if (m0_position >m0_re_state)
                        while (m0_position>m0_re_state)
                else if (m0_position m2_re_state)
                        while (m2_position>m2_re_state)
                else if (m2_position m1_re_state)
                                        do
                                        } while (m1_position != m1_re_state);
                                else if (m1_position < m1_re_state)
                                        do
                        else if (m2_position != m2_re_state)
                                if (m2_position > m2_re_state)
                                        do
                                        } while (m2_position != m2_re_state);
                                        if (m2_position == m2_re_state)
                                else if (m2_position < m2_re_state)
                                        do
                                                motor_control(M2, m2_position,1);
                        else if (m0_position != m0_re_state)
                                if (m0_position > m0_re_state)
                                        do
                                        } while (m0_position != m0_re_state);
                                else if (m0_position < m0_re_state)
                                        do
                                                motor_control(M0, m0_position,1);
               }break;              case 31:                {
                        //motor0 (0);
                }break;
                case 32:
        //                motor0 (0);
                }break;
                case 33:
                }break;
                case 34:
                }break;
                case 35:
                }break;
                case 36:
                }break;
//int main()中的WHILE
  while (1)
  /* USER CODE END WHILE */
  /* USER CODE BEGIN 3 */
        do
                R_stauts =HAL_UART_Receive_IT( huart1,rec,1);
        }while(R_stauts != HAL_OK );//接受遥控发送过来的数据
        //根据主板状态的不同,处理遥控的数据
        xinxichuli (rec[0]);
从上位机接受到信息1~6电机会进行相应的动作,在电机运行的时候电机的位置也在进行相应的累加或者累减, 在电机M0正转后 (即时接受到信息1),我发送复位信息11,或者12进行复位。在下位机接收到11的时候电机的复位没有动作,但是电机位置信息值变动成初始值,而接受到复位信息12的时候电机M0有反转,但是达到最小行程的电机的继电器还在耦合没有释放,而电机位置信息值同样变动成初始值。求大佬告知原因
回帖(1)
而无返还
2024-4-30 16:57:52
在STM32F030R8电机驱动函数中,电机位置数值跳变的原因可能有以下几点:
1. 采样频率不足:如果采样频率较低,可能导致电机位置的测量不准确,从而产生跳变。提高采样频率可以提高测量精度。
2. 滤波器设置不当:如果滤波器的参数设置不合适,可能会导致电机位置的跳变。调整滤波器参数,如滤波器类型、截止频率等,可以减少跳变。
3. 编码器精度问题:如果编码器的精度不高,可能会导致测量到的电机位置数值出现跳变。提高编码器的精度可以减少跳变。
4. 电机驱动器性能问题:电机驱动器的性能不佳可能导致电机位置的跳变。检查电机驱动器的性能,如电流、电压等,确保其工作在合适的范围内。
5. 机械结构问题:电机与负载之间的连接可能存在间隙或摩擦,导致电机位置的跳变。检查机械结构,确保连接紧密且无间隙。
6. 软件算法问题:如果软件算法存在问题,可能会导致电机位置的跳变。检查算法,确保其正确处理电机位置数据。
7. 干扰问题:电机驱动系统可能受到外部电磁干扰,导致电机位置的跳变。检查系统周围的电磁环境,采取措施减少干扰。
8. 电源问题:不稳定的电源可能导致电机驱动器工作不稳定,从而产生电机位置的跳变。确保电源稳定,可以使用稳压器或滤波器来提高电源质量。
针对您提供的代码片段,我注意到有一些可能的问题:
- 您定义了一些电机的最大和最小位置值,但是没有看到实际的电机驱动函数。请确保在驱动函数中正确使用了这些值。
- 代码中的`#define m1_xc_min -375`后面有一个空格,这可能是一个打字错误。请检查代码中的其他可能的打字错误。
建议您检查以上几点,找出导致电机位置数值跳变的原因,并进行相应的调整。
举报
更多回帖
