瑞芯微Rockchip开发者社区
直播中
殷谷光
7年用户 1074经验值
擅长:控制/MCU
私信 关注
[问答]
新手求助怎样在RK1808上配置编译Zbar源码呢
新手求助怎样在RK1808上配置编译Zbar源码呢?有哪些常见的错误?如何去解决?
回帖(1)
陈荣锦
2022-2-16 10:23:27
1 下载
Zbar源码:
注意git上的源码无配置配置文件,
解压缩:
tar -jxvf zbar- 0.10.tar.bz2
2 配置文件
创建输出目录
cd zbar-0.10
mkdir output
配置编译ZBar库:
./configure --help
打印帮助信息,其中配置选项如下:
Optional Packages:
  --with-PACKAGE[=ARG]    use PACKAGE [ARG=yes]
  --without-PACKAGE       do not use PACKAGE (same as --with-PACKAGE=no)
  --with-pic              try to use only PIC/non-PIC objects [default=use
                          both]
  --with-gnu-ld           assume the C compiler uses GNU ld [default=no]
  --with-gnu-ld           assume the C compiler uses GNU ld default=no
  --with-libiconv-prefix[=DIR]  search for libiconv in DIR/include and DIR/lib
  --without-libiconv-prefix     don't search for libiconv in includedir and libdir
  --with-x                use the X Window System
  --without-xshm          disable support for X shared memory extension
  --without-xv            disable support for XVideo extension
  --without-jpeg          disable support for JPEG image conversions
  --without-imagemagick   disable support for scanning images using
                          ImageMagick
  --with-npapi            enable support for Firefox/Mozilla/OpenOffice NPAPI
                          plugin
  --without-gtk           disable support for GTK+ widget
  --without-python        disable support for Python bindings
  --without-qt            disable support for Qt4 widget
配置文件:
./configure --prefix=$PWD/output/ --without-gtk --without-qt --without-imagemagick --without-python --disable-video
打印显示:
please verify that the detected configuration matches your expectations:
X                 --with-x=yes
pthreads          --enable-pthread=yes
v4l               --enable-video=no
        => zbarcam video scanner will *NOT* be built
jpeg              --with-jpeg=yes
Magick++          --with-imagemagick=no
        => the zbarimg file scanner will *NOT* be built
Python            --with-python=no
GTK+              --with-gtk=no
        => the GTK+ widget will *NOT* be built
Qt4               --with-qt=no
        => the Qt4 widget will *NOT* be built
3 常见错误
我的错误1:
如果,这里是说你后面需要配置文件出错;请参考如下:
获取相关文件支持
1. $ sudo apt-get install libqt4-dev  //qt相关
2. $ sudo apt-get install libv4l-dev
3. $ sudo ln -s /usr/include/libv4l1-videodev.h /usr/include/linux/videodev.h
4. $ sudo apt-get install python-gtk2-dev
5. $ sudo apt-get install imagemagick libmagickwand-dev/
例如
我想用jpeg,但是怎么配置都没有,这里就安装的包可以
sudo apt-get install imagemagick libmagickwand-dev 我的错误2:编译ZBar时,./configure之后make时提示如下错误。
usr/include/x86_64-linux-gnu/bits/stdio2.h:140:1: error: expected
identifier or ‘(’ before ‘{’ token In file included from
/usr/include/stdio.h:937:0, from zbar/debug.h:60, from
zbar/scanner.c:34: /usr/include/x86_64-linux-gnu/bits/stdio2.h:140:1:
error: expected identifier or ‘(’ before ‘{’ token
解决方法:
export CFLAGS="" //将CFLAGS环境变量置为空
然后重新 ./configure ***
此时再make,则会成功。
4. 结束
在output中 生成编译的zbar库 ;
举报
更多回帖
