千兆网输入与输出模块的设计
gbit_top模块:
`timescale 1ns / 1ps
// Project Name : OSXXXX
// Author : zhangningning
// Email : nnzhang1996@foxmail.com
// Website :
// Module Name : gbit_top.v
// Create Time : 2020-03-17 09:43:00
// Editor : sublime text3, tab size (4)
// CopyRight(c) : All Rights Reserved
// Modification History:
// Date By Version Change Description
// XXXX zhangningning 1.0 Original
module gbit_top(
//System Interfaces
input sclk ,
input rst_n ,
//Gigbit Interfaces
output reg phy_rst_n ,
input [ 3:0] rx_data ,
input rx_ctrl ,
input rx_clk
//**************Define Parameter and Internal Signals**********************************
reg [20:0] phy_rst_cnt ;
wire rx_clk_90 ;
//iddr_ctrl_inst
wire [ 7:0] gb_rx_data ;
wire gb_rx_data_en ;
wire gb_rx_data_err ;
//************** Main Code **********************************
clk_wiz_0 clk_wiz_0_inst(
// Clock out ports
.clk_out1 (rx_clk_90 ), // output clk_out1
// Clock in ports
.clk_in1 (rx_clk )
iddr_ctrl iddr_ctrl_inst(
//System Interfaces
.rst_n (rst_n ),
//Gigabit Interfaces
.rx_data (rx_data ),
.rx_ctrl (rx_ctrl ),
.rx_clk (rx_clk_90 ),
//Communication Interfaces
.gb_rx_data (gb_rx_data ),
.gb_rx_data_en (gb_rx_data_en ),
.gb_rx_data_err (gb_rx_data_err )
always @(posedge sclk or negedge rst_n)
if(rst_n == 1‘b0)
phy_rst_cnt 《= 21’d0;
else if(phy_rst_cnt[20] == 1‘b0)
phy_rst_cnt 《= phy_rst_cnt + 1’b1;
else
phy_rst_cnt 《= phy_rst_cnt;
if(rst_n == 1‘b0)
phy_rst_n 《= 1’b0;
else if(phy_rst_cnt[20] == 1‘b1)
phy_rst_n 《= 1’b1;
else
phy_rst_n 《= phy_rst_n;
endmodule
1234567891011121314151617181920212223242526272829303132333435363738394041424344454647484950515253545556575859606162636465666768697071727374757677787980818283
iddr_ctrl模块
// Website :
// Module Name : iddr_ctrl.v
// Create Time : 2020-03-17 09:21:20
module iddr_ctrl(
//System Interfaces
input rst_n ,
input rx_ctrl ,
input rx_clk ,
output reg [ 7:0] gb_rx_data ,
output reg gb_rx_data_en ,
output reg gb_rx_data_err
wire [ 7:0] data ;
wire data_en ;
wire data_err ;
IDDR #(
.DDR_CLK_EDGE (“OPPOSITE_EDGE” ), // “OPPOSITE_EDGE”, “SAME_EDGE”
// or “SAME_EDGE_PIPELINED”
.INIT_Q1 (1‘b0 ), // Initial value of Q1: 1’b0 or 1‘b1
.INIT_Q2 (1’b0 ), // Initial value of Q2: 1‘b0 or 1’b1
.SRTYPE (“SYNC” ) // Set/Reset type: “SYNC” or “ASYNC”
) IDDR_ctrl (
.Q1 (data_en ), // 1-bit output for positive edge of clock
.Q2 (data_err ), // 1-bit output for negative edge of clock
.C (rx_clk ), // 1-bit clock input
.CE (1‘b1 ), // 1-bit clock enable input
.D (rx_ctrl ), // 1-bit DDR data input
.R (~rst_n ), // 1-bit reset
.S (1’b0 ) // 1-bit set
genvar i;
generate
for (i = 0; i 《 4; i = i+1) begin
IDDR #(
) IDDR_ctrl (
.Q1 (data[i] ), // 1-bit output for positive edge of clock
.Q2 (data[4+i] ), // 1-bit output for negative edge of clock
.D (rx_data[i] ), // 1-bit DDR data input
end
endgenerate
always @(posedge rx_clk or negedge rst_n)
if(rst_n == 1‘b0)
gb_rx_data 《= 8’d0;
else
gb_rx_data 《= data;
if(rst_n == 1‘b0)
gb_rx_data_err 《= 1’b0;
else
gb_rx_data_err 《= data_err;
if(rst_n == 1‘b0)
gb_rx_data_en 《= 1’b0;
else
gb_rx_data_en 《= data_en;
endmodule
123456789101112131415161718192021222324252627282930313233343536373839404142434445464748495051525354555657585960616263646566676869707172737475767778798081828384858687888990919293949596979899100
oddr_ctrl模块
// Website :
// Module Name : oddr_ctrl.v
// Create Time : 2020-03-17 09:56:53
module oddr_ctrl(
//System Interfaces
input rst_n ,
//Gigbit Interfaces
output wire [ 3:0] tx_data ,
output wire tx_data_ctrl ,
output wire tx_clk ,
input [ 7:0] gb_tx_data ,
input gb_tx_data_en ,
input gb_tx_data_err ,
input gb_tx_clk
ODDR #(
.DDR_CLK_EDGE (“SAME_EDGE” ), // “OPPOSITE_EDGE” or “SAME_EDGE”
.INIT (1‘b0 ), // Initial value of Q: 1’b0 or 1‘b1
) ODDR_ctrl (
.Q (tx_data_ctrl ), // 1-bit DDR output
.C (gb_tx_clk ), // 1-bit clock input
.CE (1’b1 ), // 1-bit clock enable input
.D1 (gb_tx_data_en ), // 1-bit data input (positive edge)
.D2 (gb_tx_data_err ), // 1-bit data input (negative edge)
.S (1‘b0 ) // 1-bit set
ODDR #(
.INIT (1’b0 ), // Initial value of Q: 1‘b0 or 1’b1
) ODDR_clk (
.Q (tx_clk ), // 1-bit DDR output
.D1 (1’b1 ), // 1-bit data input (positive edge)
.D2 (1‘b0 ), // 1-bit data input (negative edge)
genvar i;
generate
ODDR #(
) ODDR_data (
.Q (tx_data[i] ), // 1-bit DDR output
.D1 (gb_tx_data[i] ), // 1-bit data input (positive edge)
.D2 (gb_tx_data[4+i] ), // 1-bit data input (negative edge)
end
endgenerate
endmodule
千兆网输入与输出模块的设计
gbit_top模块:
// Website :
module gbit_top(
//System Interfaces
input sclk ,
input rst_n ,
//Gigbit Interfaces
input rx_ctrl ,
input rx_clk
wire rx_clk_90 ;
//iddr_ctrl_inst
// Clock out ports
// Clock in ports
.clk_in1 (rx_clk )
//System Interfaces
.rst_n (rst_n ),
if(rst_n == 1‘b0)
else
if(rst_n == 1‘b0)
phy_rst_n 《= 1’b0;
phy_rst_n 《= 1’b1;
else
endmodule
iddr_ctrl模块
// Website :
module iddr_ctrl(
//System Interfaces
input rst_n ,
input rx_ctrl ,
input rx_clk ,
wire [ 7:0] data ;
wire data_en ;
wire data_err ;
IDDR #(
) IDDR_ctrl (
genvar i;
generate
IDDR #(
) IDDR_ctrl (
end
endgenerate
if(rst_n == 1‘b0)
gb_rx_data 《= 8’d0;
else
gb_rx_data 《= data;
if(rst_n == 1‘b0)
else
if(rst_n == 1‘b0)
else
endmodule
oddr_ctrl模块
// Website :
module oddr_ctrl(
//System Interfaces
input rst_n ,
//Gigbit Interfaces
input gb_tx_clk
ODDR #(
) ODDR_ctrl (
ODDR #(
) ODDR_clk (
genvar i;
generate
ODDR #(
) ODDR_data (
end
endgenerate
endmodule
举报
