是德科技
直播中
许超丽
8年用户 198经验值
私信 关注
[问答]
如何通过SCPI的PNA-X IMD调平配置功率?
你好PNA-X用户,我在PNA-X上运行A.09.42.16并尝试通过SCPI配置功率调整模式。
GUI为我提供了4个选项:1设置输入功率2设置输入功率,接收器调平3设置输入功率,输出4等音调设置输出功率,接收器调平帮助文件文件:sense:imd:tpower:equalize:state sense
:imd:tpower:设置我认为后一个命令,将允许我设置状态1和4.但是,如果我想配置情况2(在输入端设置功率,但使用接收器调平),是一个无证的IMD
我可以设置的命令。
或者我是否必须开始编程接收器调平系统(在这种情况下,我怀疑我将必须管理我配置调平的源 - 而不是让固件团队进行艰苦的工作!)如果有人能够阐明
配置IMD测量这方面的最佳方法,我将非常感激。
谢谢安迪
以上来自于谷歌翻译
     以下为原文
  Hello PNA-X users,
I am running A.09.42.16 on a PNA-X and trying to configure the power leveling mode via SCPI.
The GUI provides me with 4 options:
1 Set input power
2 Set input power, receiver leveling
3 Set input power, equal tones at output
4 Set output power, receiver leveling
The help file documents:
sense:imd:tpower:set
I think the latter command, will allow me to set states 1 and 4.  However, if I want to configure for case 2 (set power at the input, but use receiver leveling), is the an undocumented IMD command that I can set.  Or do I have to start programming the receiver leveling system (in which case I suspect I will have to manage which sources I configure the leveling for - rather than letting the firmware team do the hard work!)
If anyone can shed some light on the best way to config this aspect of an IMD measurement, I would be very grateful.
Thanks
Andy
回帖(1)
许超丽
2019-10-8 14:45:56
好的,一些实验表明我可以用这两个SCPI命令的正确组合来覆盖案例2-4。
我的问题是如何回到案例1?
TSET INPUT命令似乎将你设置为案例2/3 - 我似乎无法回到案例1 .... :(谢谢你和
以上来自于谷歌翻译
     以下为原文
  Okay, a little experimentation suggests that I can cover cases 2-4 with the correct combination of these two SCPI commands.  The question I have is how do I get back to case 1?  The TSET INPUT command seems to set you to case 2/3 - I cannot seem to get back to case 1.... :(
Thanks
andy
举报
更多回帖
