我不想干涉9和奥斯汀之间的交流。
以下问题的答案可能有助于奥斯汀帮助您。
9的问题:
280MHz时钟如何接收并分配到8个输入数据通道?
所有8个输入通道都在Spartan-6设备的同一边缘吗?
所有8个输入通道是否都在Spartan-6设备的同一半边缘?
所有8个输入通道是否共享公共BITSLIP逻辑,还是每个数据输入通道都有独立的BITSLIP状态机?
相位检测(使用IDELAY)是用于输入数据通道,还是使用固定延迟(使用IDELAY)?
是否测量了8个数据通道之间的板载时序偏差?
如果是,那么FPGA输入端的8个数据通道的时序如何匹配?
- 鲍勃埃尔金德
签名:新手的自述文件在这里:http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369总结:1。
阅读手册或用户指南。
你读过手册了吗?
你能找到手册吗?2。
搜索论坛(并搜索网页)以寻找类似的主题。
不要在多个论坛上发布相同的问题。
不要在别人的主题上发布新主题或问题,开始新的主题!5。
学生:复制代码与学习设计不同.6“它不起作用”不是一个可以回答的问题。
提供有用的详细信息(请与网页,数据表链接).7。
您的代码中的评论不需要支付额外费用。
我没有支付论坛帖子的费用。
如果我写一篇好文章,那么我一无所获。
以上来自于谷歌翻译
以下为原文
I do not want to interfere in the exchange between 9 and Austin. The answers to the following questions might help Austin to help you.
Questions for 9:
- How is the 280MHz clock received and distributed to the 8 input data channels?
- Are all 8 input channels on the same edge of the Spartan-6 device?
- Are all 8 input channels on the same half-edge of the Spartan-6 device?
- Do all 8 input channels share common BITSLIP logic, or is there independent BITSLIP state machine for each data input channel?
- Is phase detection (with IDELAY) used for input data channels, or is fixed delay (with IDELAY) used?
- Has on-board timing skew between the 8 data channels been measured? If yes, how well matched are the timings of the 8 data channels at the input to the FPGA?
-- Bob Elkind
SIGNATURE:
README for newbies is here: http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369
Summary:
1. Read the manual or user guide. Have you read the manual? Can you find the manual?
2. Search the forums (and search the web) for similar topics.
3. Do not post the same question on multiple forums.
4. Do not post a new topic or question on someone else's thread, start a new thread!
5. Students: Copying code is not the same as learning to design.
6 "It does not work" is not a question which can be answered. Provide useful details (with webpage, datasheet links, please).
7. You are not charged extra fees for comments in your code.
8. I am not paid for forum posts. If I write a good post, then I have been good for nothing.
我不想干涉9和奥斯汀之间的交流。
以下问题的答案可能有助于奥斯汀帮助您。
9的问题:
- 鲍勃埃尔金德
阅读手册或用户指南。
你读过手册了吗?
你能找到手册吗?2。
不要在多个论坛上发布相同的问题。
您的代码中的评论不需要支付额外费用。
我没有支付论坛帖子的费用。
如果我写一篇好文章,那么我一无所获。
以上来自于谷歌翻译
以下为原文
Questions for 9:
-- Bob Elkind
SIGNATURE:
Summary:
举报
