赛灵思
直播中
贾虎世
8年用户 1802经验值
私信 关注
[问答]
如何解释ODFS2的OFFSET OUT约束结果
大家好,
我正在开发源同步串行接口。
当我输出串行数据时,我陷入了OFFSET OUT timing。
我正在使用IOB寄存器来获取数据,并使用ODDR2(180度相移)作为时钟。
使用MMCM生成为ODDR2提供时钟的时钟。
我尝试了不同的OFFSET OUT约束,但总是会忽略约束。
但是,我遇到了这个答案,并根据答案记录对我的约束进行了建模。
http://www.xilinx.com/support/answers/34294.htm
以下是我的细读限制。
NET“up_clk”TNM_NET = up_clk; TIMESPEC TS_up_clk = PERIOD“up_clk”12.531 ns HIGH 50%;
NET“dn_d”TNM = downlink_data_clk; NET“dn_clk”TNM = downlink_data_clk;
INST“downlink_head / serial_tx / o_ser_data”TNM = downlink_data_clk_reg; INST“downlink_head / serial_tx / serial_clock”TNM = downlink_data_clk_reg;
TIMEGRP“downlink_data_clk”OFFSET = OUT在“up_clk”之后REFERENCE_PIN“dn_clk”TIMEGRP“downlink_data_clk_reg”;
约束不再被忽略。
但是,我不确定如何解释结果。
您能否向我解释或指出任何解释结果的文件。
报告的结果如下:
以上来自于谷歌翻译
以下为原文
Hello All,
I am working on a source synchronous serial interface. As I am outputing serial data, I am intersted in the OFFSET OUT Timing. I am using a IOB register for data and a ODDR2 (180 degree phase shifted) for the clock. The clock that clocks the ODDR2 is generated using a MMCM.
I tried different OFFSET OUT constraints but the constraint would always be ignored. However, I came across this answer and modelled my constraints based on the answer record.
Here are my constraints for your perusal.
NET "up_clk" TNM_NET = up_clk;
TIMESPEC TS_up_clk = PERIOD "up_clk" 12.531 ns HIGH 50%;
NET "dn_d" TNM = downlink_data_clk;
NET "dn_clk" TNM = downlink_data_clk;
INST "downlink_head/serial_tx/o_ser_data" TNM = downlink_data_clk_reg;
INST "downlink_head/serial_tx/serial_clock" TNM = downlink_data_clk_reg;
TIMEGRP "downlink_data_clk" OFFSET = OUT AFTER "up_clk" REFERENCE_PIN "dn_clk" TIMEGRP "downlink_data_clk_reg";
The constraints are not ignored anymore. However, I am not sure how to interpret the results. Can you please explain or point me to any documentation that explains the results.
The results as reported is below:
更多回帖
