是德科技
直播中
李青
8年用户 405经验值
私信 关注
[问答]
N9923A上哪里安装了选项010的TDR工具?
我有一个N9923A,它有所有选项,所以包括010(时域分析)和305(电缆和天线分析仪)。
我的N9923A附带的纸质手册根本没有提到TDR选项,虽然我在网上找到了后来的PDF,并解释了如何使用它。
它说:*如何在变换设置表上进行设置* **按Meas Setup 4. * **然后变换* **然后变换设置。* **按下一页和上一页查看所有设置。*问题
是,如果按下键4,则没有“变换”菜单。
只有*设置*校准*输出功率*端口扩展,所以我看不到如何使用TDR。
查看系统/许可部分,它显示已安装010,因此应该可以使用此功能。
(有一些时域分析作为CAT选项的一部分,但这不是完整的TDR功能。)我没有TDR的一个可能原因是我已将固件从A.06.02降级到A5。
51,因为A.06.02不适用于Data Link。
我没有办法测试降级是否是原因,因为当我降级时,仪器没有备份A.06.02,A06.02已从安捷伦网站上撤下。
所以我无法将其升级到出厂版本。
有任何想法吗?
DaveEdited:drkirkby于2012年10月11日上午8:18
以上来自于谷歌翻译
     以下为原文
  I've got an N9923A which has all options, so includes 010 (time domain analysis) and 305 (Cable and Antenna Analyzer).
The paper manual which came with my N9923A does not mention the TDR option at all, although a later PDF I found on the web does, and explains how to use it. It says:
*How to make settings on the Transform settings table*
** Press Meas Setup 4.*
** Then Transform*
** Then Transform Settings.*
** Press Next Page and Previous Page to view all settings.*
The problem is, if I press key 4, there is no "Transform" menu. There is only
* Settings
* Calibration
* Output power
* Port extensions
so I can't see how to use the TDR. Looking on the System/Licensing section, it shows 010 is installed, so this functionality should be available. (There is some time-domain analysis as part of CAT option, but that is not the full TDR functionality.)
One possible reason I don't have the TDR, is the fact I have downgraded the firmware from  A.06.02 to A5.51, as the  A.06.02 does not work with Data Link. I've got no way to test if the downgrade is the cause, since the instrument did not make a backup of the A.06.02 when I downgraded, and A06.02 has been pulled from the Agilent web site. So I can't upgrade it to the version shipped.
Any ideas?
Dave
Edited by: drkirkby on Oct 11, 2012 8:18 AM
回帖(4)
h1654155275.5614
2019-7-12 07:38:13
您需要一个A.06.xx固件来加载选项010和311,但遗憾的是我们必须提取A.06.xx(临时问题)。
官方版本将在几周后在我们的网站上备份,但与此同时,我将为您提供临时解决方案。
看到我的私信。
Afsi Moaveni
以上来自于谷歌翻译
     以下为原文
  You need an A.06.xx firmware for options 010 and 311 to load, but regrettably we had to pull A.06.xx (temporary problem). The official version will be back up on our website in a few weeks, but in the mean time, I'll provide you with an interim solution. See my private message.
Afsi Moaveni
举报
李青
2019-7-12 07:54:30
看到我的私信。
> {quote:title = am95405写道:} {quote}>你需要一个A.06.xx固件来加载选项010和311,但遗憾的是我们不得不拉A.06.xx(临时问题)。
看到我的私信。
>> Afsi Moaveni谢谢你Afsi。
选项311是否适用于N9923A?
我不能把它列为一个选项。
我看到了对免费功率计升级的参考,它为某些仪器添加了选项311。
我有选项302(USB功率计),但还没有功率传感器。
但功率计似乎负载 - 但表示没有连接传感器。
我没有看到你的私信 - 最后一段时间是关于不可能将频率降低到2 MHz以下。
戴夫
以上来自于谷歌翻译
     以下为原文
  > {quote:title=am95405 wrote:}{quote}
> Afsi Moaveni
Thank you Afsi. Is option 311 applicable to the N9923A? I can't see it listed as an option. I see references to a free power meter upgrade, which adds option 311 to some instruments. I have option 302 (USB power meter), but as yet no power sensor. But the power meter appears to load - but says there is no sensor attached.
I don't see an private message from you - the last was some time back about the impossibility of lowering the frequency below 2 MHz.
Dave
举报
h1654155275.5614
2019-7-12 08:14:29
看到我的私信。
抱歉。
311不适用于N9923A。
我错误地把它包括在你案件的答复中。
311,与010一样,需要更新的固件,但仅适用于N9923A的姊妹N9912A。
311,内置功率计或通道功率计是基于频谱分析仪,而N9912A可以包括SA,而N9923A则不能。
你现在应该有下午。
是的,功率传感器选项要求您购买安捷伦的USB功率传感器之一。
此致,Afsi Moaveni
以上来自于谷歌翻译
     以下为原文
  Sorry. 311 is not available for N9923A. My mistake for including it in the reply to your case.
311, like 010, requires the newer firmware, but is only available for N9923A's sister, the N9912A. 311, built-in-power meter or channel power meter is based on the spectrum analyzer, and N9912A can include a SA, whereas N9923A cannot.
You should have the pm now.
Yes, the power sensor option requries you to buy one of Agilent's USB power sensors.
Regards,
Afsi Moaveni
举报
李青
2019-7-12 08:22:39
> {quote:title = am95405写道:} {quote}>抱歉。
311不适用于N9923A。
我错误地把它包括在你案件的答复中。
没问题。
>你现在应该有下午。
是的,我得到了它并回复了几次。
你看到有人在没有真正检查你的收件箱的情况下向你发送了PM吗?
对于大多数具有私人消息设施的服务器,如果有人向我发送PM,我会收到一封电子邮件。
但这不是我在这里发生的事情,所以有时PM会被忽视。
戴夫
以上来自于谷歌翻译
     以下为原文
No problem.
Yes, I got it and replied a couple of times. Do you see if someone sends you a PM without actually checking your inbox on here? With most servers which have a private message facility I get an email if someone sends me a PM. But this is not happening to me on here, so sometimes a PM will go unnoticed.
Dave
举报
更多回帖
