赛灵思
直播中
张建军
7年用户 174经验值
私信 关注
[问答]
将VCO锁定为1mhz参考信号可以在斯巴达6芯片上使用内部PLL完成?
你好
我有一个设计,我需要将VCO锁定为1mhz参考信号。
VCO的输出需要为16,8,2和1MHZ。
我想知道是否有人知道这是否可以在斯巴达6芯片上使用内部PLL完成?
数据表指出最小clkin频率为19MHz,但是我认为可以将参考值与DCM ??相乘。
以上来自于谷歌翻译
以下为原文
Hi
I have a design where i need to to lock a VCO to a 1mhz reference signal. The output of the VCO needs to be 16, 8, 2 and 1MHZ.
I was wondering if anyone knows if this could be done using the internal  PLL's on a spartan 6 chip?. The datasheet states that the minimum clkin frequency is 19MHz, however im thinking it might be possible to multiply the reference up with a DCM??.
回帖(2)
范潇潇
2019-5-21 12:42:26
嘿Jkovac,
只有PLL才能做到这一点。
您注意到PLL的最小输入为1Mhz。
您可以尝试使用DCM选项,但是执行此操作时,您的抖动会有问题,然后将其传递给PLL。
PLL可能无法锁定。
你必须彻底测试这个。
老实说,我没有那么自信。
最好的办法是在电路板上安装一个快速振荡器。
它比你的/更容易划分你的时钟。
/ K
以上来自于谷歌翻译
以下为原文
Hey Jkovac,
There isnt a way to do this with just the PLL. The PLL as you noted has a minimum input of 1Mhz. You could try the DCM option, but your jitter will be questionable doing this multiple and then passing it to the PLL. The PLL may not lock. You would have to test this throughly.
Honestly I dont have confidence in that approach. The best thing to do would be to get a fast oscillator on your board. Its easier to divide your clock down than up/.
/k
举报
辛文斌
2019-5-21 13:00:16
为这个建议欢呼。
是的,我对这种方法没有多少信心,这也就是为什么我想在投入时间之前问问哈哈。
谢谢
杰西
以上来自于谷歌翻译
以下为原文
cheers for that advice. yeah i don't have much confidence in that approach either which is why i thought id ask before investing the time haha.
Thanks
Jesse
举报
更多回帖
