赛灵思
直播中
孙宇
8年用户 145经验值
私信 关注
[问答]
在设计中在ILA1中有10个探针怎么办
大家好,
如果我在设计中在ILA1中有10个探针怎么办,
但是,让我们说我只想从probe1和probe2获取数据并保存到.csv中
ILA中的整个数据在.csv中成功捕获,但我想知道我可以在ILA中选择一些完整的探针。
我用过“write_hw_ila_data -csv_file xxx”
当我在tcl控制台中输入“write_hw_ila_data -help”时,似乎没有选择我想要捕获的探针。
如果有人知道如何选择探针,请帮助我
谢谢
以上来自于谷歌翻译
以下为原文
Hi all,
What if I have 10 probes in ILA1 in my design,
But, Lets say that I want to get data only from probe1 and probe2 and save into .csv
The whole data in ILA was succesfully captured in .csv, but I was wondering whetere i can select some of whole probes in ILA.
I used "write_hw_ila_data -csv_file xxx"
When I type "write_hw_ila_data -help" in tcl console, it seems like there is no option for selecting probes that I watn to capture.
if someone knows how to select probes, please help me
Thank you
回帖(3)
王文霞
2019-4-11 14:31:47
嗨,我认为只能选择几个探针并将它们导入excel是不可能的。一旦将所有数据导入csv格式,你需要过滤掉所需的数据-Shreyas
--------------------------------------------尝试搜索你的答案
在发布新帖子之前在论坛或xilinx用户指南中发出问题。请注意 - 如果提供的信息解决了您的问题,请将答案标记为“接受为解决方案”。给予您认为有用的帖子给予荣誉(右边提供的星号)
并回复.----------------------------------------------
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
Hi,
I don't think this is possible to only select few probes and import them to excel.
you need to filter out the data you require once all the data is imported to csv format
-Shreyas----------------------------------------------------------------------------------------------
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
----------------------------------------------------------------------------------------------View solution in original post
举报
王文霞
2019-4-11 14:41:33
以上来自于谷歌翻译
以下为原文
Hi,
举报
励黎
2019-4-11 14:51:00
谢谢@ aher
似乎VIVADO没有其他选择可供我关注。
好的,我将使用其他工具来选择我想要保留的列数据。
再次感谢你
以上来自于谷歌翻译
以下为原文
Thank you @aher
it seems like there is no other option in VIVADO for my concern.
Ok, I will use other tools to select the column data that i want to keep.
Thank you again
举报
更多回帖
