赛灵思
直播中
廉雁捷
7年用户 263经验值
私信 关注
[问答]
MAP致命错误
嗨,
我正在使用planAhead 14.4,在映射过程中我收到以下错误:
FATAL_ERROR:Map:mapbafragmast.c:1981:1.68  -  INITSTATE 0的长度不是4的倍数。
流程将终止。
有关此问题的技术支持,请通过http://www.xilinx.com/support连接此项目打开WebCase。
我不知道这是什么意思。
谁能告诉我这是什么以及如何解决这个问题?
我认为它可能与我设置的一些MAP标志有关。
谢谢,
--Rudy
以上来自于谷歌翻译
以下为原文
Hi,
I am using planAhead 14.4, and during the map process I get the following error:
FATAL_ERROR:Map:mapbafragmast.c:1981:1.68 - The length of INITSTATE 0 is not a
multiple of four. Process will terminate. For technical support on this
issue, please open a WebCase with this project attached at
http://www.xilinx.com/support.
I have no idea what does this mean. Can someone tell me what this is and how to get around this?
I think it might be related to some of the MAP flags that I set.
Thanks,
--Rudy
回帖(3)
李华
2019-3-13 06:40:53
嗨,你能分享实施日志吗?问候,Achutha
-------------------------------------------请注意 - 请标记答案
如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------
以上来自于谷歌翻译
以下为原文
Hi ,
Can you share the implementation log?
Regards,
Achutha---------------------------------------------------------------------------------------------
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.
Give Kudos to a post which you think is helpful and reply oriented.
举报
李裕伦
2019-3-13 06:49:19
嗨鲁迪,
同一消息几乎没有致命错误,这些错误在最新版本中得到修复。
它与RAM256X1S相关,具有未填充的INITSTATE = 0属性,该属性应由工具自动设置。
你能检查一下你的设计中是否有分布式RAM吗?
作为一个工作,您可以专门设置INIT值或尝试最新版本?
以上来自于谷歌翻译
以下为原文
Hi Rudy,
There were few fatal errors with the same message and these were fixed in latest version.
It was related to a RAM256X1S with an unpadded INITSTATE = 0 property which should automatically  be set by tools.
Can you check if there are any distributed RAMs in your design? As a workaorund, you could specifically set the INIT values or try a latest version?
举报
步雅芸
2019-3-13 07:03:46
嗨,
你能告诉我如何设置INIT值吗?
谢谢,
--Rudy
以上来自于谷歌翻译
以下为原文
Hi,
Would you please tell me how to set the INIT values ?
Thanks,
--Rudy
举报
更多回帖
