抱歉延迟了答复,但我已经离职了。我使用Windows 7 64位。我的电脑是最新的,它的核心是i76950x,16GB的RAM和一些其他的花式硬件。我使用的是一个直接连接到主板的USB端口。我试过前后端口,这没什么区别。我没有任何USB2端口来尝试。但是正如我前面提到的:ICD3运行在同一台计算机上安装了较老的MPLAX版本。它被正确检测并按预期工作。所有的ICD在设备管理器中正确显示没有问题。但是,当运行MPLAB IPE或X版本4或更大时,设备列表是完全空的。一定有其他地方出错了…
以上来自于百度翻译
以下为原文
Sorry for replying with a delay, but I've been out of office.
I'm using Windows 7 64 Bit. My computer is pretty up to date, featuring a core i7-6950X, 16GB of ram and some other fancy hardware. I'm using a USB3 port directly connected to my Mainboard. I've tried front and rear ports, that does not make any difference. I do not have any USB2 ports to try on.
But as I mentioned before:
The ICD3 runs fine with older MPLAB X versions installed on the same computer. It is detected correctly and working as expected. All my ICDs show up correctly in device manager without issues.
However, when running MPLAB IPE or X in version 4 or greater, the device list is completely empty.
There must be something else going wrong...
以上来自于百度翻译
以下为原文
举报
