HP34970A运行简单扫描,尝试通过串口链接确认bldlPro下的基本功能。
记录的工作方式与bldl3相同。
但是,无法配置新的“事件”功能。
例如,只需在配置开始时将34970A设置为“嘟嘟”,或者在dlblPro GUI的配置结束时(手动启动或停止),就不会产生“嘟嘟”声。
34970A在硬件故障下发出“嘟嘟”声,例如在扫描期间移除互连盒 - 产生硬件不兼容故障,因此硬件可以正常工作。
如果bldlPro不会做这样简单的事情,那么如何生成具有多个扫描的更复杂的配置?
HP34970A是否有一些固件要求与Benchlink Datalogger Pro配合使用?
我正在运行评估版本,只是为了查看事件处理功能是否使这个包价值购买价格。
迄今为止,在处理任何事件处理的34901A和34907A接口时,都没有任何乐趣。
好状态机图纸,但没有功能。
RL
以上来自于谷歌翻译
以下为原文
HP34970A running simple scans, trying to confirm basic func
tion under bldlPro through the serial port link. Logging works much as it did under bldl3.
Having trouble configuring the new 'event' feature, however.
For example, just setting the 34970A to 'beep' at the start of a configuration, or at the end of a configuration (manually started or stopped) from dlblPro GUI does not produce a 'beep'.
The 34970A does 'beep' under hardware faults, such as removal of interconnection cartridge during a scan - generating a hardware incompatibility fault, so the hardware works.
If bldlPro won't do something simple like this, how will more complicated configurations with multiple scans be produced?
Is there some firmware requirement for HP34970A to work with Benchlink Datalogger Pro?
Am running the evaluation version, simply to see if the event handling function makes this package worth the purchase price. No joy from it to date in handling the 34901A and 34907A interfaces for ANY event handling. Nice state machine drawings, but no function.
RL
