嗨,您使用的是vivado webpack还是ise webpack?
你可以在这里附上许可吗?webpack许可证不是节点锁定的,因此它可以在不同于生成它的机器上使用。谢谢,Deepika。
谢谢,迪皮卡.----------------------------------------------
---------------------------------------------- Google之前的问题
张贴。
如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。
如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星)
以上来自于谷歌翻译
以下为原文
Hi,
Are you using vivado webpack or ise webpack? Can you attach the license here?
The webpack licenses are not node locked hence it can be used on a different machine than the one for which it is generated for.
Thanks,
Deepika.Thanks,
Deepika.
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left)
张贴。
以上来自于谷歌翻译
以下为原文
Hi,
Thanks,
Deepika.Thanks,
Deepika.
举报
