是德科技
直播中
王文霞
8年用户 192经验值
私信 关注
[问答]
34970A上电时NVram错误
在进行了一系列长时间的测试后,没有硬件或程序改变,34970A开始发出哔哔声并不断闪烁其前面板。
从测试设置中删除后,它在上电时报告错误913“模块报告的非易失性存储器故障”。
无论安装了哪个模块,重复上电时都会出现此错误。
较长的开机自检会发出“通过”消息,同时显示相同的错误信号。
最重要的是,该装置现在无法通过RS232通信 - 不会返回具有已知良好串行端口连接和线束的ID。
闪烁的前面板和蜂鸣声尚未复制,因为原始测试情况仅用于测试目的 - 不适用于测试设备维修。
到目前为止,在擦除启动错误或其他情况后,使用手动输入值的前面板功能看似正常。
34901A模块中的继电器控制似乎是常规的。
34907A模块上的电源电压似乎正常,安装后,两个输入端口字节的数据均可读取。
我将处理串口作为硬件修复问题。
错误913 ....这可能是其他地方损坏的结果?
以上来自于谷歌翻译
     以下为原文
  After running a long series of tests, with no hardware or program alterations, the 34970A started beeping and flashing its front panel continually.
On removal from the test setup, it reported an error 913 "Module reported nonvolatile memory fault" at power-up.
This error at power-on is repeated, regardless of module(s) installed. The longer power-on self-test issues a 'PASS' message, while presenting the same error signal.
On top of this, the unit now fails RS232 communication - will not return ID with a known-good serial port connection and harness.
The flashing front panel and beeping have yet to be reproduced, as the original test situation is only available for testing purposes - not for test equipment repair.
So far, function from the front panel, using manually-entered values seem normal, after the start-up error is erased, or otherwise. Relay control in the 34901A modules seems regular. Supply voltages on a 34907A module seem normal, when installed and data is readable on both input port bytes.
I'll deal with the serial port as a hardware repair issue.
The error 913 .... is this likely the result of damage elsewhere?
回帖(5)
王文霞
2018-11-22 10:59:08
我成功找到了913错误的所有者 - 这是测试失败时出现的34907A多功能模块。
NVRam在那里吗?
如果未安装,则开机时没有错误消息。
没有第二个已知良好的07型模块来比较它。
仍在尝试重新获得串口通信。
在确定MC145407接口集成电路的范围时,它似乎可以毫无问题地接收和传输输入数据,而PC16550则无需向外传输任何数据。
以上来自于谷歌翻译
     以下为原文
  I've managed to track down the owner of the 913 error - it's the 34907A multifunction module that was present in the test failure. Is NVRam in there?
If it's not installed, then there is no error message at power-on. There isn't a second known-good 07 type module to compare this to.
Still trying to regain serial port communications. Scoping the MC145407 interface IC, it seems to receive and transmit incoming data without issues, there's just nothing coming back from the PC16550 for transmission outwards.
举报
郝汉
2018-11-22 11:04:29
NVRam在那里吗?
如果未安装,则开机时没有错误消息。
34907A确实包含非易失性RAM。
您可以尝试校准34907A以查看是否可以解决问题。
该程序位于34970A / 72A服务指南中,您可以在Agilent网站上找到该指南。
以上来自于谷歌翻译
     以下为原文
  The 34907A does contain non volatile RAM.  You could try calibrating the 34907A to see if that fixes the problem.  The procedure is in the 34970A/72A Service Guide which you can find on the Agilent web site.
举报
王文霞
2018-11-22 11:18:55
引用: lanziji 发表于 2018-11-22 10:04
34907A确实包含非易失性RAM。
34907模块校准仅适用于DAC输出。
当编程为10.0时,我从ch4得到10.6,从ch5得到9.99。
不安全的,10.6和-0.6之间的任何输入,作为ch4的校准输入,都会产生706错误 - “校准值超出范围”。
要走了。
以上来自于谷歌翻译
     以下为原文
  The 34907 module calibration applies to the DAC outputs only. I'm getting 10.6 from ch4 and 9.99 from ch5, when programmed to 10.0.
Unsecured, any input between 10.6 and -0.6, as a calibration input for ch4, gets a 706 error - 'Calibration value out of range'.
got to go.
举报
王文霞
2018-11-22 11:36:32
34970A的重复闪烁显示和蜂鸣声由34901模块拥有,该模块在事件发生时位于插槽1中。
该模块主要是在3通道瓦特计的背板连接器上读取低压模拟信号,信号以安全接地框为参考。
检查回来,这就是它所做的一切。
无论如何,它继续引起同样的行为,因此没有明显的损坏或供应不规则,它可以坐在架子上一段时间,直到有更多的时间来弄明白。
RL
以上来自于谷歌翻译
     以下为原文
  The repeated flashing display and beeping of the 34970A is owned by the 34901 module that was present in slot one at the time of the event. This module was mostly reading low voltage analog signals on a 3-channel wattmeter's  back-panel connector, with signals referenced to the safety earth frame. Checking back, that was ALL that it was doing.
Anyways, it continues to evoke this same behavior, so without visible damage or supply irregularities, it can sit on the shelf for a while until there's more time to figure it out.
RL
举报
更多回帖
