是德科技
直播中
刘一
7年用户 91经验值
私信 关注
[问答]
anritsu 3654B套件可以使用N5225A PNA吗
您好,我正在使用N5225A PNA,扩展混频器高达75 GHz。
带分析仪的校准套件(85056A)工作到50 GHz。
现在的问题是我有一个anritsu 3654B套件(直到70 Ghz)。
有没有办法可以用这个PNA版本?
提前致谢。
以上来自于谷歌翻译
     以下为原文
  Hello, I am using a N5225A PNA with extension mixer up to 75 GHz. The calibration kit (85056A) with the analyzer works until 50 GHz. The question now is that I have an anritsu 3654B kit (until 70 Ghz). Is there a way this can be used with this PNA version ? Thanks in advance.
回帖(1)
张博
2018-11-19 11:22:47
您好,您可以根据需要为PNA N5225A系列添加用户校准套件。
您将需要校准套件系数,例如偏移延迟,偏移损耗,开路电容建模因子和短路杂散电感因子等。该信息必须直接来自Anritsu。
获得该数据后,您可以手动输入新试剂盒或修改PNA分析仪中的现有校准试剂盒。
PNA帮助文件( http://na.support.keysight.com/pna/help/index.html [/ URL])深入研究此过程。
或者,您可以下载到PC上的+ Standalone Cal Kit Editor +,可从[URL] http://na.support.keysight.com/pna/apps#calkiteditor [/ URL]下载。
这是一个可通过PNA支持页面[URL] http://na.support.keysight.com/pna/ [/ URL]获得的实用程序。
这两种方法都需要Anritsu的参数信息用于校准套件标准。
真诚的,tsilchia
以上来自于谷歌翻译
     以下为原文
  Hello,
You can add  user calibration kits as required to the PNA N5225A family. You will need the calibration kit coefficients such as offset delay, offset loss, capacitance modeling factors for the open and stray inductance factors for the short, etc. That information will have to come directly from Anritsu.
Once you have that data you can manually enter a new kit or modify an existing calibration kit within the PNA analyzer. The PNA Help file(s) ( [URL] http://na.support.keysight.com/pna/help/index.html
)  delve into this process. Alternatively, you can download to a PC the +Standalone Cal Kit Editor+ available for download at http://na.support.keysight.com/pna/apps#calkiteditor. This is a utility available via the PNA Support page http://na.support.keysight.com/pna/
Either method requires parametric information from Anritsu for the calibration kit standards.
Sincerely,
tsilchia
举报
更多回帖
