我很困惑如何在N5225A上进行1000次测量。
有谁知道这种测量的申请人? 以上来自于谷歌翻译 以下为原文 i am confused about how to do the 1000 times measurements in a second on the N5225A. does anyone know the applicant for this kind of measurements? |
2个回答
我想这取决于你想要测量的东西......固定或扫除频率?
单数据采集还是多数? (也就是说,只需获得1000点并停止或重复测量)。 告诉我们您的特定应用是什么有很大帮助。 如果你希望显示器每秒更新1000次,那就不会发生; 如果你想在1秒内收集1000点并在最后看到更新,没问题; 如果您只设置点= 1000,则执行预设条件,然后进行窄扫描。 以上来自于谷歌翻译 以下为原文 I guess it depends upon what you are trying to measure... fixed or swept freqeuncy? One-data acquistion or many? (that is, just get 1000 points and stop or repeat the measurement). It helps a lot to tell us what your particular application is. If you want the display to update 1000 times a second, not gonna happen; If you want to gather 1000 points in 1 second and see the update at the end, no problem; preset condition will do it if you just set points=1000, and take a narrow sweep. |
乔尔,我相信他希望每秒进行1000次扫描; 不是1000分...... *和* ......他想把数据保存到磁盘......每次扫描! 我相信他正在使用101分并扫过1GHz的范围。 他打算尝试我的数据记录器程序,但是它设计用于较慢的长期存储,并且无法处理超过每秒几次扫描的任何事情。 我同意每秒1000次扫描不会发生。 也许使用快速CW的东西可能对他有用???? Weizhe,请尝试告诉我们您需要什么以及为什么......也许我们可以提出一些其他的方法或建议。 以上来自于谷歌翻译 以下为原文 Joel, I believe he wants to take 1000 sweeps per second; not 1000 points....*and*...he wants to save the data to disk...for each sweep! I believe he is using 101 points and sweeping over a 1GHz range. He was going to try my data logger program, but it was designed for slower longer-term storage and cannot handle anything beyond a few sweeps per second. I agree that 1000 sweeps per second is not going to happen. Maybe something using fast CW might work for him???? Weizhe, Please try to tell us what you need and why...maybe we could come up with some other method or suggestion. |
只有小组成员才能发言,加入小组>>
2102 浏览 1 评论
1860 浏览 1 评论
1715 浏览 5 评论
2584 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1564 浏览 4 评论
506浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
365浏览 0评论
1414浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
276浏览 0评论
2260浏览 0评论
GMT+8, 2024-4-29 02:26 , Processed in 1.289789 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
