电子发烧友论坛|
您好,我对以下内容非常好奇:背景:我执行16端口扫描,以几个.s16p文件结束。
但是,大部分数据从未使用过。 是否可以使用PNA-X(我正在使用N5225A)执行以下操作?:1)执行16端口校准2)告诉VNA执行任意数量的4端口扫描。 3)使用16端口校准中的错误术语来纠正我告诉VNA收集的4端口扫描。 这是通过使用GPIB完成的。 如果可以的话,请指导我使用我的设置执行此操作? 这很关键。 谢谢,-KTB PS - 只想说你们在为问题提供高质量的答案方面做得非常出色。 如果我在评论/调查方面有任何有意义的事情,请告诉我,因为我很乐意为您提供A +++评级。 以上来自于谷歌翻译 以下为原文 Hello, I am very curious about the following: Background: I do 16-Port sweeps ending with several .s16p files. However, much of that data is never used. Is it possible to do the following with a PNA-X (I'm using the N5225A)?: 1) Do a 16-Port Calibration 2) Tell the VNA to do an arbitrary number of 4-Port Sweeps. 3) Use the errors terms from the 16-Port Calibration to correct the 4-Port Sweeps I have told the VNA to collect. This is done through the use of GPIB. If this is possible, could you please guide me into executing this with my setup? This is crucial. Thanks, -KTB PS - Just want to say you guys have done an extremely excellent job at providing quality responses to problems. If there is something meaningful that I can do in terms of reviews/surveys/whatever for you, please let me know as I would love to give your support an A+++ rating. |
1个回答
您可以这样做,但您必须务实地更改要测量的每条迹线的校正类型,并使用4端口错误术语进行更正。
下面的链接将显示您需要应用于频道中每个跟踪的命令。 [http://na.support.keysight.com/pna/help/latest/Programming/GP-IB_Command_Finder/Calculate/Correction.htm#ErorType] 以上来自于谷歌翻译 以下为原文 you can do that, but you have to pragmatically change the correction type of each of the traces you want to measure and correct with the 4 port error terms. the link below will show you the command that you need to apply to each trace in your channel. [http://na.support.keysight.com/pna/help/latest/Programming/GP-IB_Command_Finder/Calculate/Correction.htm#ErorType] |
只有小组成员才能发言,加入小组>>
263 浏览 0 评论
1863 浏览 0 评论
2755 浏览 1 评论
2657 浏览 1 评论
2477 浏览 5 评论
1868浏览 0评论
434浏览 0评论
270浏览 0评论
/9
GMT+8, 2025-12-13 04:12 , Processed in 0.707949 second(s), Total 41, Slave 34 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1831
