英特尔
直播中
苏醒
8年用户 203经验值
私信 关注
[问答]
Intel NUC显示两个IP地址
我有Intel NUC,我手动为它分配了一个静态IP地址。
现在,当我在整个网络上运行高级IP扫描程序时,我看到2个不同的IP地址到该NUC上的同一个mac地址。
我还确保在NUC上禁用其他网络适配器。
它显示两个IP地址的具体原因是什么?
这是与IPMI有关的吗?
谢谢,
以上来自于谷歌翻译
以下为原文
I have Intel NUC and I have manually assigned it a static IP address to it. Now when I run the Advanced IP scanner on the entire network, I see 2 different IP address to the same mac address on that NUC. I have also made sure other network adapters are disabled on the NUC. Any specific reason it shows two IP addresses ? Is this something related to IPMI ?
Thanks,
回帖(1)
汤宇
2018-10-25 15:07:49
您好Pratik898,感谢您发布。
我们将此线程移至英特尔NUC社区,以加快响应速度。
为了帮助NUC社区进一步为您提供帮助,请提供系统支持工具日志。
这不会收集任何个人信息。
从上面的链接下载并运行.exe检查“所有内容”,然后单击“扫描”扫描完成后单击“下一步”保存日志并将其附加到帖子上。有关此实用程序的附加信息。
如果您有任何疑问,请随时与我们联系。最诚挚的问候,丹尼尔D.
以上来自于谷歌翻译
以下为原文
Hello Pratik898,
Thank you for posting. We will move this thread to the Intel NUC communities for faster response.  To help the NUC community further assist you please provide System Support Utility logs. This will not collect any personal information.
  • Download and run the .exe from the link above
  • Check "everything" then click "scan"
  • When scan is finished click "next"
  • Save the log and attach it to a post
The FAQs have additional information about this utility. If you have any questions please do not hesitate to contact us.
Best regards,
Daniel D
举报
更多回帖
