> {quote:title = peol1写道:} {quote}>嗨,>>我需要为我们的8753D配备一个3.5mm校准套件,我在犹豫是否应该买一个新的(或用过的)85033E(这是
VNA不支持 - 需要手动添加cal coeffs)或尝试从一些知名的二手经销商那里找到一个二手的85033D。
使用一年保修和有效的Keysight cal的二手85033D花多少钱?
还是值得去85033E?
我在某处看到D和E使用相同的cal系数,这是否意味着我可以使用85033E套件使用我们的VNA中预先定义的85033D校准套件进行校准?
购买二手校准套件,特别是3.5毫米,是一件很棒的事情!
我认为您不会找到具有一年保修和Keysight校准的85033D。
获得校准套件的成本非常高,在低端套件上不值得。
我认为我的85052B和85054B的成本是我的VNA校准的3倍。
你可能会发现一个带有保修的校准套件和来自$ random_lab的校准证书,这不值得写上它的论文。
85033D和E非常相似。
我认为E具有定义的短路的电感,但不是D,但是无论如何你都无法将它们输入到8753中,并且它们非常微不足道。
我会自己去找85033E。
如果不出意外,它们更新,所以不太可能被搞砸。
请给我发一封私人电子邮件给drkirkby@kirkbymicrowave.co.uk我可能会对您感兴趣。
DaveEdited:drkirkby于2014年9月17日上午11:30
以上来自于谷歌翻译
以下为原文
> {quote:title=peol1 wrote:}{quote}
> Hi,
> I am in the need for a 3.5mm cal kit for our 8753D and I am hesitating whether I should get a new (or used) 85033E (which is not supported in the VNA - need cal coeffs to be added manually) or try to find a used 85033D from some reputed second hand dealer. How much would be wise to spend on a used 85033D with one year warranty and valid Keysight cal? Or is it worth going for the 85033E? I read somewhere that the D and E uses the same cal coeffs, does that mean that I could calibrate using a 85033E kit using the pre-defined 85033D cal set already in our VNA?
Buying used cal kits, especially 3.5 mm, is a hit and miss affair!
I don't think you will find an 85033D with a one year warranty and Keysight calibration. The cost of getting cal kits calibrated is very high, and not worthwhile on low end kits. I think my 85052B and 85054B cost about 3x as much to get calibrated as my VNA.
You might find a cal kit with a warranty and a cal certificate from $random_lab, which is not worth the paper it is written on.
The 85033D and E are very similar. I think the E has the inductance of the shorts defined, but not the D, but you wont be able to enter them into the 8753 anyway, and they are pretty insignificant.
I would go for an 85033E myself. If nothing else, they are newer, so less likely to be screwed up.
Drop me a private email to drkirkby@kirkbymicrowave.co.uk I might have something of interest to you.
Dave
Edited by: drkirkby on Sep 17, 2014 11:30 AM
还是值得去85033E?
85033D和E非常相似。
我会自己去找85033E。
以上来自于谷歌翻译
以下为原文
> Hi,
Dave
举报
