赛灵思
直播中
韩凤英
8年用户 230经验值
私信 关注
[问答]
错误:放置:703自动时钟放置失败
有谁知道要查看哪个文件才能调试这个?
.mrp,syr?
我之前的构建有更多的clk /组件工作,但我的简化设计有时钟放置错误。
不知道最近发生了什么。
我基本上注释掉了我的大多数组件,它仍然有这个错误。
包括dcm / pll在内的所有资源使用率都远低于100%
以上来自于谷歌翻译
以下为原文
anyone know which file to look at in order to debug this? .mrp, syr?
my previous build with more clk/component work, but my simplified design has clock placement error.  not sure whats going on.  i basically comment out most my components and it still has this error.
all resource usage including dcm/pll are much less than 100%
回帖(1)
李富才
2018-10-11 15:21:14
时钟布局器无法为您的设计找到解决方案。
除了放置实际时钟负载之外,它还可能必须对时钟域进行布局规划以控制时钟负载布局。
根据器件系列,每个时钟区域只能支持一定数量的全局时钟域。
如果您在设计中使用区域组范围,则可能会干扰时钟布局器找到解决方案的能力。
如果要实例化BUFH,也会使时钟位置复杂化。
根据设备架构,如果您有许多本地时钟也会干扰本地时钟位置:
http://www.xilinx.com/support/answers/32528.htm
以上来自于谷歌翻译
以下为原文
The clock placer has failed to find a solution for your design. Besides placing the actual clock loads it may also have to floorplan the clock domains to control the clock load placement. Depending on the device family each clock region can only support a certain number of global clock domains.  If you are using area group ranges in your design you may be interfering with the clock placer's ability to find a solution. If you are instantiating BUFHs that can also complicate clock placement. Depending on the device architecture, If you have a lot of local clocks that can also interfere with the local clock placement:
举报
更多回帖
