一些更新。
我错误地将0-3 GHz而不是3.8-6.8 GHz应用到A3的混音器。
我的sig gen可以输出最大4 GHz,所以我试着这样做。
:D I在向混频器施加4 GHz - 0 dBm时测量RF OUT端口的信号:腔体频率= 3.8 GHz信号频率= 4 GHz RF OUT频率= 4 GHz - 3.8 GHz = 200 MHz因此调制器看起来很实用。
但是我不能用> 4 GHz的频率测试它: - 我还试图检查A3的ALC功能:通过改变VNA的SOURCE POWER,我可以看到SA的功率变化。
SA的功率水平比VNA设定水平低约2 dB。
此外,我尝试逐渐将sig gen输出电平从0 dBm更改为20 dBm,并且在SA处看不到任何RF OUT电平的变化。
所以我猜ALC运作正常。
我认为除了YTO之外,整个A3组件都能正常运行。
问题是如何在没有YTO的情况下检查其余的仪器功能?
以上来自于谷歌翻译
以下为原文
Some updates.
I mistakenly applied 0-3 GHz instead 3.8-6.8 GHz to the mixer of A3. My sig gen can output 4 GHz max, so I tried to do it. :D
I measured signal at the RF OUT port when apply 4 GHz - 0 dBm to mixer:
Cavity ocs frequency = 3.8 GHz
Sig gen frequency = 4 GHz
RF OUT freq = 4 GHz - 3.8 GHz = 200 MHz
So mixer looks functional. But I can not test it with frequency >4 GHz :-
I also tried to check ALC functionality of A3:
By changing SOURCE POWER of VNA I can see a power changes at the SA. The power level at SA is ~2 dB lower than VNA set level.
Also I tried gradually change sig gen output level from 0 dBm to 20 dBm and could not see any changing of RF OUT level at SA.
So I guess the ALC operates properly.
I think the entire A3 assembly operates properly except YTO.
The question is how to check the rest of the instrument functionality without YTO?
一些更新。
所以我猜ALC运作正常。
以上来自于谷歌翻译
以下为原文
Some updates.
举报
