I am no FPGA expert, but i believe that LVDS is an ANSI standard. The standard depends on the differential swing of signals around a common mode voltage of ~1.2V. See datasheet excerpt below:
So if your FPGA supports this mode, then the AD9467 should be able to send data to your FPGA.
答案来源:
The output of the AD9467 is LVDS level standard... | EngineerZone
答案来源:
举报
