STC12C5A60S2 智能车
一段基于STC12C5A60S2的手柄控制小车的程序,其他案件都可以控制,但是加减速度两个按键按下去只是加减一瞬间。就回到原来的速度。。。。求助大神啊,瞎摆弄好几天了。。。直接用宏定义小车加速没反应,单独写又只加速一瞬间。
#include "STC12C5A60S2.h"
#include "stdio.h"
//#include "uart_printf.h"
#include "ps2.h"
#define SPIF (SPSTAT&0X80)
#define ON 1 //使能LED
#define OFF 0 //禁止LED
//unsigned char SPI_Buffer=0;
//定义电机引脚
***it Left_motor_go=P2^1; //左电机前进AIN2
***it Left_motor_back=P2^2; //左电机后退AIN1
***it Right_motor_go=P2^4; //右电机前进BIN2
***it Right_motor_back=P2^3; //右电机后退BIN1
***it Left_motor_pwm=P2^0; //左电机控速PWMA
***it Right_motor_pwm=P2^5; //右电机控速PWMB
unsigned char pwm_val_left =0;//变量定义
unsigned char pwm_val_right =0;
//速度调节变量 0-20,0最小,20最大
unsigned char push_val_left =5;// 左电机占空比push_val_left/20
unsigned char push_val_right=5;// 右电机占空比push_val_right/20
***it FM=P2^7; //蜂鸣器
***it LED_B=P3^4;
***it LED_G=P3^2;
***it LED_R=P3^3;
bit Left_PWM_ON=1;
bit Right_PWM_ON=1;
//unsigned char SPI_Rec_flag;
unsigned char time;
//unsigned char scan[9];
unsigned char FIRE;
//小车运行状态枚举
enum{
enSTOP = 0,
enRUN,
enBACK,
enLEFT,
enRIGHT,
enUPLEFT,
enUPRIGHT,
enDOWNLEFT,
enDOWNRIGHT,
enSPINLEFT,
enSPINRIGHT
}enCarState;
#define enMinMin() {push_val_left =20;push_val_right =20;}
#define enMin() {push_val_left =24;push_val_right =24;}
#define enMidle() {push_val_left =28;push_val_right =28;}
#define enMax() {push_val_left =32;push_val_right =32;}
#define enMinMin() do{
push_val_left =5;
push_val_right =5;
}while(0)
#define enMin() do{
push_val_left =10;
push_val_right =10;
}while(0)
#define enMidle() do{
push_val_left =15;
push_val_right =15;
}while(0)
#define enMax() do{
push_val_left =20;
push_val_right =20;
}while(0)
//uchar g_volume=0;
int g_volume = 0;
int g_carstate = 0;
//延时函数
void delay(unsigned int xms)
unsigned int i,j;
for(i=xms;i>0;i--)
for(j=850;j>0;j--);
void pwm_out_left_motor(void) //左电机调速
if(Left_PWM_ON)
if(pwm_val_left<=push_val_left)
Left_motor_pwm =1;
else
Left_motor_pwm=0;
if(pwm_val_left>=20) //这里的20代表的是pwm为20ms即50hz
pwm_val_left=0;
else
Left_motor_pwm=0; //若未开启PWM则PWMA=0 左电机停止
void pwm_out_right_motor(void) //右电机调速
if(Right_PWM_ON)
if(pwm_val_right<=push_val_right)
Right_motor_pwm=1;
else
Right_motor_pwm=0;
if(pwm_val_right>=20) //这里的20代表的是pwm为20ms即50hz
pwm_val_right=0;
else
Right_motor_pwm=0; //若未开启PWM则PWMB=0右电机停止
// 小车前进
void run(unsigned int time)
//左电机前进
Left_motor_go = 1; //左电机前进使能
Left_motor_back = 0; //左电机后退禁止
//更新指定管脚的PWM值,更改可实现控速(0-20)
//push_val_left=10;
//右电机前进
Right_motor_go=1; //右电机前进使能
Right_motor_back=0; //右电机后退禁止
//push_val_right=10;
//延时
delay(time * 100);
return;
// 小车停止
void brake(unsigned int time)
//左电机停止
Left_motor_go = 0; //左电机前进禁止
//右电机停止
Right_motor_go=0; //右电机前进禁止
//延时
delay(time * 100);
return;
// 小车左转 左转(左轮不动,右轮前进)
void left(unsigned int time)
//左电机停止
push_val_left=0;
//右电机前进
push_val_right=10;
//延时
delay(time * 100);
return;
// 小车右转 (左轮前进,右轮不动)
void right(unsigned int time)
//左电机前进
push_val_left=10;
//printf("PSB_motor_right !n");
//右电机停止
push_val_right=0;
//延时
delay(time * 100);
return;
void spin_left(unsigned int time)
//左电机后退
Left_motor_back = 1; //左电机后退使能
push_val_left=18;
//右电机前进
push_val_right=18;
//延时
delay(time * 100);
return;
void spin_right(unsigned int time)
//左电机前进
push_val_left=18;
//右电机后退
Right_motor_back=1; //右电机后退使能
push_val_right=18;
//延时
delay(time * 100);
return;
void up_right(unsigned int time) //右上
Left_motor_go=1;
Left_motor_back=0;
push_val_left=18;
Right_motor_go=1;
Right_motor_back=0;
push_val_right=10;
delay(time * 100);
return;
void down_right(unsigned int time) //右下
Left_motor_go=0;
Left_motor_back=1;
push_val_left=18;
Right_motor_go=0;
Right_motor_back=1;
push_val_right=10;
delay(time * 100);
return;
void up_left(unsigned int time) //左上
Left_motor_back=0;
push_val_left=10;
Right_motor_go=1;
Right_motor_back=0;
push_val_right=18;
delay(time * 100);
return;
void down_left(unsigned int time) //左下
//Left_moto_back;
//Right_moto_back;
//push_val_left = 10;
//push_val_right = 25;
Left_motor_go=0;
Left_motor_back=1;
push_val_left=10;
Right_motor_go=0;
Right_motor_back=1;
push_val_right=18;
delay(time * 100);
return;
// 小车后退
void back(unsigned int time)
//左电机后退
push_val_left=10;
//右电机后退
push_val_right=10;
//延时
delay(time * 100);
return;
void setspeed()
switch(g_volume)
case 1: enMinMin();break;
case 2: enMin();break;
case 3: enMidle();break;
case 4: enMax();break;
//default:enMidle();break;
// TIMER0中断服务子函数产生PWM信号,
void timer0()interrupt 1
TH0=0XFC; //1Ms定时
TL0=0X66;
pwm_val_left++;
pwm_val_right++;
pwm_out_left_motor();
pwm_out_right_motor();
//pwm初始化 利用定时器0
void pwm_Init(void)
TMOD |=0X01; //定时器工作方式1
TH0= 0XFC; //1ms定时
TL0= 0X66;
TR0= 1; //启动T0工作
ET0= 1; //允许T0中断
EA = 1; //开总中断
void UartInit(void) //初始化波特率为9600
SCON=0x50;
TMOD=0x20;
TCON=0x40;
TH1=0xfd;
TI=1;
TR1=1;
void color_led(int v_iRed, int v_iGreen, int v_iBlue)
//红色LED
v_iRed == ON ? (LED_R = 1): (LED_R = 0);
//绿色LED
v_iGreen == ON ? (LED_G = 1): (LED_G = 0);
//蓝色LED
v_iBlue == ON ? (LED_B = 1): (LED_B = 0);
void main()
//printf("PS:%xn", PS2->FunBtn);
stPS2KeyValue * PS2;
UartInit();
P2=0XC0; //关电机
P1 = 0xff; //关闭所有LED和风扇
FIRE = 0;
pwm_Init();
printf("PS:fdsgfdsrn");
/*while(1)
Left_motor_go = 0;
delayms(1);
Left_motor_go = 1;
delayms(1);
PS2_Init();
while(1) //无限循环
PS2 = ReadPS2KeyValue();
if((PS2->FunBtn & PSB_SELECT) == 0)
// uart_sendbyte("start3");
printf("PSB_SELECT!n");
if((PS2->FunBtn & PSB_START) == 0)
printf("PSB_START!n");
if((PS2->FunBtn & PSB_L3) == 0)
printf("PSB_L3!n");
g_carstate = enSTOP;
if((PS2->FunBtn & PSB_R3) == 0)
printf("PSB_R3!n");
//方向控制
if((PS2->FunBtn & PSB_PAD_UP) == 0)
printf("PSB_PAD_UP!n");
g_carstate = enRUN;
else if((PS2->FunBtn & PSB_PAD_RIGHT) == 0)
printf("PSB_PAD_RIGHT!n");
g_carstate = enRIGHT;
else if((PS2->FunBtn & PSB_PAD_DOWN) == 0)
printf("PSB_PAD_DOWN!n");
g_carstate = enBACK;
else if((PS2->FunBtn & PSB_PAD_LEFT) == 0)
printf("PSB_PAD_LEFT!n");
g_carstate = enLEFT;
else //去掉则按下一直执行,加此段则放开停止
//SendBuf("Stop!n");
if((PS2->FunBtn & PSB_L2) == 0)
printf("PSB_L2!n");
//g_volume++;
g_volume++;
printf("PSB_L2_1 !n");
if(g_volume>=4)
g_volume = 4;
printf("PSB_L2_1_1 !n");
switch(g_volume)
case 1:
printf("push_val_left = %dn",push_val_left);
//enMinMin();
push_val_left=12;push_val_right=12;
printf("PSB_l2_4 !n");
break;
case 2:
// enMin();
push_val_left=15;push_val_right=15;
printf("PSB_l2_4_1 !n");
break;
case 3:
//enMidle();
push_val_left=18;push_val_right=18;
printf("PSB_l2_4_2 !n");
break;
case 4:
//enMax();
push_val_left=20;push_val_right=20;
printf("PSB_l2_4_3 !n");
break;
default:enMidle();
break;
printf("PSB_L2_5 !n");
if((PS2->FunBtn & PSB_R2) == 0)
printf("PSB_R2!n");
g_volume--;
if(g_volume<=0)
g_volume = 1;
switch(g_volume)
case 1:
enMinMin();
break;
//case 1:push_val_left=10;push_val_right=10;break;
case 2:
enMin();
//push_val_left=14;push_val_right=14;
break;
case 3:
enMidle();
//push_val_left=17;push_val_right=17;
break;
case 4:
enMax();
//push_val_left=20;push_val_right=20;
break;
if((PS2->FunBtn & PSB_L1) == 0)
printf("PSB_L1!n");
//左摇杆*
if (PS2->Y1 < 5 && PS2->X1 > 80 && PS2->X1 < 180) //上
g_carstate = enRUN;
printf("enRUNn");
else if (PS2->Y1 > 230 && PS2->X1 > 80 && PS2->X1 < 180) //下
printf("enBACKn");
else if (PS2->X1 < 5 && PS2->Y1 > 80 && PS2->Y1 < 180) //左
printf("enLEFTn");
else if (PS2->Y1 > 80 && PS2->Y1 < 180 && PS2->X1 > 230)//右
printf("enRIGHTn");
else if (PS2->Y1 <= 80 && PS2->X1 <= 80) //左上
g_carstate = enUPLEFT;
printf("enUPLEFTn");
else if (PS2->Y1 <= 80 && PS2->X1 >= 180) //右上
g_carstate = enUPRIGHT;
printf("enUPRIGHTn");
else if (PS2->X1 <= 80 && PS2->Y1 >= 180) // 左下
g_carstate = enDOWNLEFT;
printf("enDOWNLEFTn");
else if (PS2->Y1 >= 180 && PS2->X1 >= 180) //右下
g_carstate = enDOWNRIGHT;
printf("enDOWNRIGHTn");
else//停
if((PS2->FunBtn & PSB_R1) == 0)
printf("PSB_L1!n");
//左摇杆*
if (PS2->Y2 < 5 && PS2->X2 > 80 && PS2->X2< 180) //上
g_carstate = enRUN;
printf("enRUNn");
else if (PS2->Y2 > 230 && PS2->X2 > 80 && PS2->X2 < 180) //下
printf("enBACKn");
else if (PS2->X2 < 5 && PS2->Y2 > 80 && PS2->Y2< 180) //左
printf("enLEFTn");
else if (PS2->Y2 > 80 && PS2->Y2 < 180 && PS2->X2 > 230)//右
printf("enRIGHTn");
else if (PS2->Y2 <= 80 && PS2->X2 <= 80) //左上
else if (PS2->Y2 <= 80 && PS2->X2 >= 180) //右上
else if (PS2->X2 <= 80 && PS2->Y2 >= 180) // 左下
else if (PS2->Y2 >= 180 && PS2->X2 >= 180) //右下
else//停
if((PS2->FunBtn & PSB_TRIANGLE) == 0) //△ 控制红灯
printf("PSB_TRIANGLE!n");
//FIRE = (FIRE == 1)?0:1;
color_led(ON, OFF, OFF);
delay(2000);
ReadPS2KeyValue();
if((PS2->FunBtn & PSB_CIRCLE) == 0) // o控制蓝灯
printf("PSB_CIRCLE!n");
color_led(OFF, OFF, ON);
delay(2000);
ReadPS2KeyValue();
if((PS2->FunBtn & PSB_CROSS) == 0) // × 鸣笛
printf("PSB_CROSS!n");
FM = 0;
delay(2000);
FM = 1;
ReadPS2KeyValue();
if((PS2->FunBtn & PSB_SQUARE) == 0) //控制绿灯
printf("PSB_SQUARE!n");
color_led(OFF ,ON, OFF);
delay(2000);
ReadPS2KeyValue();
switch(g_carstate)
case enSTOP:
brake(2);
TR0= 0;
break;
case enRUN:
run(2);
TR0= 1;
break;
case enLEFT:
left(2);
TR0= 1;
break;
case enRIGHT:
right(2);
TR0= 1;
break;
case enBACK:
back(2);
TR0= 1;
break;
case enUPLEFT:
up_left(2);
TR0= 1;
break;
case enUPRIGHT:
up_right(2);
TR0= 1;
break;
case enDOWNLEFT:
down_left(2);
TR0= 1;
break;
case enDOWNRIGHT:
down_right(2);
TR0= 1;
break;
case enSPINLEFT:
spin_left(2);
TR0 = 1;
break;
case enSPINRIGHT:
spin_right(2);
TR0 = 1;
break;
default:
break;
delay(50);
更多回帖
