串口初始化使用UART_HandleTypeDef类型的结构体。以9600波特率、8位数据、1位停止位的配置程序如下: 查看原代码
使用HAL_UART_DeInit函数将串口的配置默认,再使用HAL_UART_Init函数,将上面的结构体的配置写入到寄存器中。 |
查看原代码 UartHandle.Init.BaudRate = 9600; UartHandle.Init.WordLength = UART_WORDLENGTH_8B; UartHandle.Init.StopBits = UART_STOPBITS_1; UartHandle.Init.Parity = UART_PARITY_NONE; UartHandle.Init.HwFlowCtl = UART_HWCONTROL_NONE; UartHandle.Init.Mode = UART_MODE_TX_RX; UartHandle.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT; 使用HAL_UART_DeInit函数将串口的配置默认,再使用HAL_UART_Init函数,将上面的结构体的配置写入到寄存器中。 |
最终实现的函数如下:
查看原代码 HAL_StatusTypeDef UART_SetConfig(UART_HandleTypeDef *huart) { uint32_t tmpreg = 0x00000000U; UART_ClockSourceTypeDef clocksource = UART_CLOCKSOURCE_UNDEFINED; uint16_t brrtemp = 0x0000U; uint16_t usartdiv = 0x0000U; HAL_StatusTypeDef ret = HAL_OK; /* Check the parameters */ assert_param(IS_UART_BAUDRATE(huart->Init.BaudRate)); assert_param(IS_UART_WORD_LENGTH(huart->Init.WordLength)); assert_param(IS_UART_STOPBITS(huart->Init.StopBits)); assert_param(IS_UART_PARITY(huart->Init.Parity)); assert_param(IS_UART_MODE(huart->Init.Mode)); assert_param(IS_UART_HARDWARE_FLOW_CONTROL(huart->Init.HwFlowCtl)); assert_param(IS_UART_ONE_BIT_SAMPLE(huart->Init.OneBitSampling)); /*-------------------------- USART CR1 Configuration -----------------------*/ /* Clear M, PCE, PS, TE, RE and OVER8 bits and configure * the UART Word Length, Parity, Mode and oversampling: * set the M bits according to huart->Init.WordLength value * set PCE and PS bits according to huart->Init.Parity value * set TE and RE bits according to huart->Init.Mode value * set OVER8 bit according to huart->Init.OverSampling value */ tmpreg = (uint32_t)huart->Init.WordLength | huart->Init.Parity | huart->Init.Mode | huart->Init.OverSampling ; MODIFY_REG(huart->Instance->CR1, UART_CR1_FIELDS, tmpreg); /*-------------------------- USART CR2 Configuration -----------------------*/ /* Configure the UART Stop Bits: Set STOP[13:12] bits according * to huart->Init.StopBits value */ MODIFY_REG(huart->Instance->CR2, USART_CR2_STOP, huart->Init.StopBits); /*-------------------------- USART CR3 Configuration -----------------------*/ /* Configure * - UART HardWare Flow Control: set CTSE and RTSE bits according * to huart->Init.HwFlowCtl value * - one-bit sampling method versus three samples' majority rule according * to huart->Init.OneBitSampling */ tmpreg = (uint32_t)huart->Init.HwFlowCtl | huart->Init.OneBitSampling ; MODIFY_REG(huart->Instance->CR3, (USART_CR3_RTSE | USART_CR3_CTSE | USART_CR3_ONEBIT), tmpreg); /*-------------------------- USART BRR Configuration -----------------------*/ UART_GETCLOCKSOURCE(huart, clocksource); /* Check UART Over Sampling to set Baud Rate Register */ if (huart->Init.OverSampling == UART_OVERSAMPLING_8) { switch (clocksource) { case UART_CLOCKSOURCE_PCLK1: usartdiv = (uint16_t)(UART_DIV_SAMPLING8(HAL_RCC_GetPCLK1Freq(), huart->Init.BaudRate)); break; case UART_CLOCKSOURCE_PCLK2: usartdiv = (uint16_t)(UART_DIV_SAMPLING8(HAL_RCC_GetPCLK2Freq(), huart->Init.BaudRate)); break; case UART_CLOCKSOURCE_HSI: usartdiv = (uint16_t)(UART_DIV_SAMPLING8(HSI_VALUE, huart->Init.BaudRate)); break; case UART_CLOCKSOURCE_SYSCLK: usartdiv = (uint16_t)(UART_DIV_SAMPLING8(HAL_RCC_GetSysClockFreq(), huart->Init.BaudRate)); break; case UART_CLOCKSOURCE_LSE: usartdiv = (uint16_t)(UART_DIV_SAMPLING8(LSE_VALUE, huart->Init.BaudRate)); break; case UART_CLOCKSOURCE_UNDEFINED: default: ret = HAL_ERROR; break; } brrtemp = usartdiv & 0xFFF0U; brrtemp |= (uint16_t)((usartdiv & (uint16_t)0x000FU) >> 1U); huart->Instance->BRR = brrtemp; } else { switch (clocksource) { case UART_CLOCKSOURCE_PCLK1: huart->Instance->BRR = (uint16_t)(UART_DIV_SAMPLING16(HAL_RCC_GetPCLK1Freq(), huart->Init.BaudRate)); break; case UART_CLOCKSOURCE_PCLK2: huart->Instance->BRR = (uint16_t)(UART_DIV_SAMPLING16(HAL_RCC_GetPCLK2Freq(), huart->Init.BaudRate)); break; case UART_CLOCKSOURCE_HSI: huart->Instance->BRR = (uint16_t)(UART_DIV_SAMPLING16(HSI_VALUE, huart->Init.BaudRate)); break; case UART_CLOCKSOURCE_SYSCLK: huart->Instance->BRR = (uint16_t)(UART_DIV_SAMPLING16(HAL_RCC_GetSysClockFreq(), huart->Init.BaudRate)); break; case UART_CLOCKSOURCE_LSE: huart->Instance->BRR = (uint16_t)(UART_DIV_SAMPLING16(LSE_VALUE, huart->Init.BaudRate)); break; case UART_CLOCKSOURCE_UNDEFINED: default: ret = HAL_ERROR; break; } } return ret; } |
528 浏览 0 评论
654 浏览 0 评论
858 浏览 0 评论
837 浏览 0 评论
RT-Thread与英飞凌(infineon)合作得板子PSOC 6 板子学习
770 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
17064 浏览 31 评论
/9
GMT+8, 2025-12-14 22:47 , Processed in 1.091079 second(s), Total 75, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
