扫一扫,分享给好友
我运行一个m文件,总是让定义当前图片,错误使用 regionGrowing (line 61)
Please define one of the current images! 请问我该如何定义呢,非常感谢! 源码是这样的:function [P, J] = regionGrowing(cIM, initPos, thresVal, maxDist, tfMean, tfFillHoles, tfSimplify) % REGIONGROWING Region growing algorithm for 2D/3D grayscale images % % Syntax: % P = regionGrowing(); % P = regionGrowing(cIM); % P = regionGrowing(cIM, initPos) % P = regionGrowing(..., thresVal, maxDist, tfMean, tfFillHoles, tfSimpl) % [P, J] = regionGrowing(...); % % Inputs: % cIM: 2D/3D grayscale matrix {current image} % initPos: Coordinates for initial seed position {ginput position} % thresVal: Absolute threshold level to be included {5% of max-min} % maxDist: Maximum distance to the initial position in [px] {Inf} % tfMean: Updates the initial value to the region mean (slow) {false} % tfFillHoles: Fills enclosed holes in the binary mask {true} % tfSimplify: Reduces the number of vertices {true, if dpsimplify exists} % % Outputs: % P: VxN array (with V number of vertices, N number of dimensions) % P is the enclosing polygon for all associated pixel/voxel % J: Binary mask (with the same size as the input image) indicating % 1 (true) for associated pixel/voxel and 0 (false) for outside % % Examples: % % 2D Example % load example % figure, imshow(cIM, [0 1500]), hold all % poly = regionGrowing(cIM, [], 300); % click somewhere inside the lungs % plot(poly(:,1), poly(:,2), 'LineWidth', 2) % % % 3D Example % load mri % poly = regionGrowing(squeeze(D), [66,55,13], 60, Inf, [], true, false); % plot3(poly(:,1), poly(:,2), poly(:,3), 'x', 'LineWidth', 2) % % Requirements: % TheMathWorks Image Processing Toolbox for bwboundaries() and axes2pix() % Optional: Line Simplification by Wolfgang Schwanghart to reduce the % number of polygon vertices (see the matlab FileExchange) % % Remarks: % The queue is not preallocated and the region mean computation is slow. % I haven't implemented a preallocation nor a queue counter yet for the % sake of clarity, however this would be of course more efficient. % % Author: % Daniel Kellner, 2011, braggpeaks{}googlemail.com % History: v1.00: 2011/08/14 % error checking on input arguments if nargin > 7 error('Wrong number of input arguments!') end if ~exist('cIM', 'var') himage = findobj('Type', 'image'); if isempty(himage) || length(himage) > 1 error('Please define one of the current images!') end cIM = get(himage, 'CData'); end if ~exist('initPos', 'var') || isempty(initPos) himage = findobj('Type', 'image'); if isempty(himage) himage = imshow(cIM, []); end % graphical user input for the initial position p = ginput(1); % get the pixel position concerning to the current axes coordinates initPos(1) = round(axes2pix(size(cIM, 2), get(himage, 'XData'), p(2))); initPos(2) = round(axes2pix(size(cIM, 1), get(himage, 'YData'), p(1))); end if ~exist('thresVal', 'var') || isempty(thresVal) thresVal = double((max(cIM(:)) - min(cIM(:)))) * 0.05; end if ~exist('maxDist', 'var') || isempty(maxDist) maxDist = Inf; end if ~exist('tfMean', 'var') || isempty(tfMean) tfMean = false; end if ~exist('tfFillHoles', 'var') tfFillHoles = true; end if isequal(ndims(cIM), 2) initPos(3) = 1; elseif isequal(ndims(cIM),1) || ndims(cIM) > 3 error('There are only 2D images and 3D image sets allowed!') end [nRow, nCol, nSli] = size(cIM); if initPos(1) < 1 || initPos(2) < 1 ||... initPos(1) > nRow || initPos(2) > nCol error('Initial position out of bounds, please try again!') end if thresVal < 0 || maxDist < 0 error('Threshold and maximum distance values must be positive!') end if ~isempty(which('dpsimplify.m')) if ~exist('tfSimplify', 'var') tfSimplify = true; end simplifyTolerance = 1; else tfSimplify = false; end % initial pixel value regVal = double(cIM(initPos(1), initPos(2), initPos(3))); % text output with initial parameters disp(['RegionGrowing Opening: Initial position (' num2str(initPos(1))... '|' num2str(initPos(2)) '|' num2str(initPos(3)) ') with '... num2str(regVal) ' as initial pixel value!']) % preallocate array J = false(nRow, nCol, nSli); % add the initial pixel to the queue queue = [initPos(1), initPos(2), initPos(3)]; %%% START OF REGION GROWING ALGORITHM while size(queue, 1) % the first queue position determines the new values xv = queue(1,1); yv = queue(1,2); zv = queue(1,3); % .. and delete the first queue position queue(1,:) = []; % check the neighbors for the current position for i = -1:1 for j = -1:1 for k = -1:1 if xv+i > 0 && xv+i <= nRow &&... % within the x-bounds? yv+j > 0 && yv+j <= nCol &&... % within the y-bounds? zv+k > 0 && zv+k <= nSli &&... % within the z-bounds? any([i, j, k]) &&... % i/j/k of (0/0/0) is redundant! ~J(xv+i, yv+j, zv+k) &&... % pixelposition already set? sqrt( (xv+i-initPos(1))^2 +... (yv+j-initPos(2))^2 +... (zv+k-initPos(3))^2 ) < maxDist &&... % within distance? cIM(xv+i, yv+j, zv+k) <= (regVal + thresVal) &&...% within range cIM(xv+i, yv+j, zv+k) >= (regVal - thresVal) % of the threshold? % current pixel is true, if all properties are fullfilled J(xv+i, yv+j, zv+k) = true; % add the current pixel to the computation queue (recursive) queue(end+1,:) = [xv+i, yv+j, zv+k]; if tfMean regVal = mean(mean(cIM(J > 0))); % --> slow! end end end end end end %%% END OF REGION GROWING ALGORITHM % loop through each slice, fill holes and extract the polygon vertices P = []; for cSli = 1:nSli if ~any(J(:,:,cSli)) continue end |
1个回答
最下面是61行
function [P, J] = regionGrowing(cIM, initPos, thresVal, maxDist, tfMean, tfFillHoles, tfSimplify) % REGIONGROWING Region growing algorithm for 2D/3D grayscale images % % Syntax: % P = regionGrowing(); % P = regionGrowing(cIM); % P = regionGrowing(cIM, initPos) % P = regionGrowing(..., thresVal, maxDist, tfMean, tfFillHoles, tfSimpl) % [P, J] = regionGrowing(...); % % Inputs: % cIM: 2D/3D grayscale matrix {current image} % initPos: Coordinates for initial seed position {ginput position} % thresVal: Absolute threshold level to be included {5% of max-min} % maxDist: Maximum distance to the initial position in [px] {Inf} % tfMean: Updates the initial value to the region mean (slow) {false} % tfFillHoles: Fills enclosed holes in the binary mask {true} % tfSimplify: Reduces the number of vertices {true, if dpsimplify exists} % % Outputs: % P: VxN array (with V number of vertices, N number of dimensions) % P is the enclosing polygon for all associated pixel/voxel % J: Binary mask (with the same size as the input image) indicating % 1 (true) for associated pixel/voxel and 0 (false) for outside % % Examples: % % 2D Example % load example % figure, imshow(cIM, [0 1500]), hold all % poly = regionGrowing(cIM, [], 300); % click somewhere inside the lungs % plot(poly(:,1), poly(:,2), 'LineWidth', 2) % % % 3D Example % load mri % poly = regionGrowing(squeeze(D), [66,55,13], 60, Inf, [], true, false); % plot3(poly(:,1), poly(:,2), poly(:,3), 'x', 'LineWidth', 2) % % Requirements: % TheMathWorks Image Processing Toolbox for bwboundaries() and axes2pix() % Optional: Line Simplification by Wolfgang Schwanghart to reduce the % number of polygon vertices (see the MATLAB FileExchange) % % Remarks: % The queue is not preallocated and the region mean computation is slow. % I haven't implemented a preallocation nor a queue counter yet for the % sake of clarity, however this would be of course more efficient. % % Author: % Daniel Kellner, 2011, braggpeaks{}googlemail.com % History: v1.00: 2011/08/14 % error checking on input arguments if nargin > 7 error('Wrong number of input arguments!') end if ~exist('cIM', 'var') himage = findobj('Type', 'image'); if isempty(himage) || length(himage) > 1 error('Please define one of the current images!') end |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1697 浏览 1 评论
200圆!求助大佬给一份VSG并网和离网模式的simulink仿真
1973 浏览 0 评论
MATLAB(3)--矩阵的引用(sub2ind、ind2sub、reshape函数使用)
2792 浏览 0 评论
3130 浏览 0 评论
4105 浏览 1 评论
GMT+8, 2024-11-27 23:02 , Processed in 0.543244 second(s), Total 73, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
