首先感谢电子发烧友论坛给我的这次【Landzo C1试用体验】,小车还在邮寄的路上,在期待的同时,先用landzo c1的核心控制板arduino驱动1602,等小车到了后可以增加显示模块。
本帖可以看到:
1.用arduino驱动1602显示器效果图;
2.学习arduino中的liquidcrystal显示库函数应用
3.在1602中显示英文及数字;
4.增加1602字形库中没有的文字;
1602有4线和8线接法,这里选取8线,对于c51 单片机驱动在编程上有所区别,但对于arduino 开发板来说4线和8线在编程上几乎一致,仅需要修改引脚的接线方式;
上传实例代码:
LiquidCrystal Library - Custom Characters
Demonstrates how to add custom characters on an LCD display.
The LiquidCrystal library works with all LCD displays that are
compatible with the Hitachi HD44780 driver. There are many of
them out there, and you can usually tell them by the 16-pin interface.
This sketch prints "I Arduino!" and a little dancing man
to the LCD.
The circuit:
* LCD RS pin to digital pin 12
* LCD Enable pin to digital pin 11
* LCD D4 pin to digital pin 5
* LCD D5 pin to digital pin 4
* LCD D6 pin to digital pin 3
* LCD D7 pin to digital pin 2
* LCD R/W pin to ground
* 10K potentiometer:
* ends to +5V and ground
* wiper to LCD VO pin (pin 3)
* 10K poterntiometer on pin A0
created 21 Mar 2011
by Tom Igoe
modified 11 Nov 2013
by Scott Fitzgerald
Based on Adafruit's example at
https://github.com/adafruit/SPI_VFD/blob/master/examples/createChar/createChar.pde
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/LiquidCrystal
Also useful:
http://icontexto.com/charactercreator/
// include the library code:
#include
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12,11,2,3,4,5,6,7,8,9,10);
// make some custom characters:
byte heart[8] = {
0b00000,
0b01010,
0b11111,
0b11111,
0b11111,
0b01110,
0b00100,
0b00000
byte smiley[8] = {
0b00100,
0b01110,
0b00100,
0b11111,
0b01100,
0b01110,
0b11100,
0b10111
byte frownie[8] = {
0b00000,
0b00000,
0b01010,
0b01010,
0b00100,
0b01010,
0b01010,
0b00000
byte ARMsDown[8] = {
0b00100,
0b01010,
0b00100,
0b00100,
0b01110,
0b10101,
0b00100,
0b01010
byte armsUp[8] = {
0b00100,
0b01010,
0b00100,
0b10101,
0b01110,
0b00100,
0b00100,
0b01010
void setup() {
// initialize LCD and set up the number of columns and rows:
lcd.begin(16, 2);
// create a new character
lcd.createChar(0, heart);
lcd.createChar(1, smiley);
lcd.createChar(2, frownie);
lcd.createChar(3, armsDown);
lcd.createChar(4, armsUp);
lcd.clear();
lcd.setCursor(0,0);
// Print a message to the lcd.
lcd.print("I ");
lcd.write(byte(0));
// when calling lcd.write() '0' must be cast as a byte
lcd.print(" Arduino! ");
lcd.write(byte(1));
lcd.write(byte(2));
void loop() {
// read the potentiometer on A0:
lcd.setCursor(1, 1);
// draw the little man, arms down:
lcd.write(3);
delay(200);
// draw him arms up:
lcd.write(4);
delay(200);
lcd.print(" 2016-06-09");
