如何跳线将显示器图像旋转180度?接线端口如下: 5.1 TFT LCD MODULE Pin Name Description 1 RXO0- Negative LVDS differential data input. Channel O0 (odd) 2 RXO0+ Positive LVDS differential data input. Channel O0 (odd) 3 RXO1- Negative LVDS differential data input. Channel O1 (odd) 4 RXO1+ Positive LVDS differential data input. Channel O1 (odd) 5 RXO2- Negative LVDS differential data input. Channel O2 (odd) 6 RXO2+ Positive LVDS differential data input. Channel O2 (odd) 7 GND Ground 8 RXOC- Negative LVDS differential clock input. (odd) 9 RXOC+ Positive LVDS differential clock input. (odd) 10 RXO3- Negative LVDS differential data input. Channel O3(odd) 11 RXO3+ Positive LVDS differential data input. Channel O3 (odd) 12 RXE0- Negative LVDS differential data input. Channel E0 (even) 13 RXE0+ Positive LVDS differential data input. Channel E0 (even) 14 GND Ground 15 RXE1- Negative LVDS differential data input. Channel E1 (even) 16 RXE1+ Positive LVDS differential data input. Channel E1 (even) 17 GND Ground 18 RXE2- Negative LVDS differential data input. Channel E2 (even) 19 RXE2+ Positive LVDS differential data input. Channel E2 (even) 20 RXEC- Negative LVDS differential clock input. (even) 21 RXEC+ Positive LVDS differential clock input. (even) 22 RXE3- Negative LVDS differential data input. Channel E3 (even) 23 RXE3+ Positive LVDS differential data input. Channel E3 (even) 24 GND Ground 25 NC Not connection, should open. 26 VCOM VCOM Control, should open. 27 AGMODE AGMODE should be tied to ground or open. 28 VCC +5.0V power supply 29 VCC +5.0V power supply 30 VCC +5.0V power supply Note (1) Connector Part No.: 093G30-B0001A(STARCONN) or FI-X30SSL-HF(JAE) or EQUIVALENT. Note (2) Mating Connector Part No.:FI-X30H ; FI-X30C* ; FI-X30M* ; FI-X30HL(-T),FI-X30C*L(-T) [JAE] Note (3) The first pixel is odd. Note (4) Input signal of even and odd clock should be the same timing. 请高手帮忙,谢谢! |
相关推荐 |
摄像头模组开发,感光芯片硬触发拍照方案问题 OV系列 和 IMX系列
6061 浏览 2 评论
12165 浏览 2 评论
RK3588 HDMI in 接入设备如何获取HDMI in 传入的音频?
13087 浏览 1 评论
33421 浏览 1 评论
2038 浏览 0 评论
/9
GMT+8, 2025-12-12 05:05 , Processed in 0.825591 second(s), Total 51, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2908
