扫一扫,分享给好友
代码的一部分贴上,问题在代码下面:process(reset,clkMuxx,mdi,filterok,filterok_delay,mdi_r,mdi_r_filterok,rxf,rxf_r,mdi_xor_active,s_data_active)
begin if rising_edge(clk) then -- filter data rxf <= rxf(2 downto 0) & mdi; if ((rxf(3) & rxf(3) & rxf(3)) = rxf(2 downto 0)) then filterok <= rxf(3); end if; --消息是前6位同步头111000,或者000111这样的,然后是32位的消息体 --以上看起来是同步头过滤的作用,但我不理解了,rxf初始值是0000的话,永远不会出现1111啊!--曼彻斯特码除了同步头,内部消息不可能再出现3个以上连起来的111或者000了,这样filterok就永远不变 rxf_r <= rxf_r(2 downto 0) & mdi_r; if ((rxf_r(3) & rxf_r(3) & rxf_r(3)) = rxf_r(2 downto 0)) then r_filterok <= rxf_r(3); end if; rxf_xor <= rxf_xor(0) & mdi_xor_active; if ((rxf_xor(1) & rxf_xor(1)) = rxf_xor(1 downto 0)) then xor_filterok <= rxf_xor(1); end if; s_data_active <= s_data_active(6 downto 0) & xor_filterok; line_active <= '0'; if(( (s_data_active(7) xor s_data_active(6)) or (s_data_active(7) xor s_data_active(5)) or (s_data_active(7) xor s_data_active(4)) or (s_data_active(7) xor s_data_active(3)) or (s_data_active(7) xor s_data_active(1)) or (s_data_active(7) xor s_data_active(0)) ) = '1') or (s_data_active(7) = '1') then line_active <= '1'; end if; filterok_delay <= filterok;--filterok因为没值,filterok_delay也不会有值 end if; tick <= filterok xor filterok_delay; --这个看来是脉冲边沿检测,但看来是值不会变了??? if reset = '0' then line_active <= '0'; rxf <= (others => '0'); rxf_r <= (others => '0'); filterok <= '0'; r_filterok <= '0'; s_data_active <= (others => '0'); xor_filterok <= '0'; rxf_xor <= (others => '0'); end if; end process; -- decode1m decode_proc: process(tick,clk,filterok,filterok_delay,line_active,reset, clk_1m,DataBit_cnt_width, decode_word_flag,bit_cnt_recv,decode_state,dout_wr_cnt_delay,HalfBit_cnt_width) variable parity_v : std_logic; begin if rising_edge(clkMuxx) then HalfBit_cnt_width <= 0; if (tick ) = '0' then --record bit gap time HalfBit_cnt_width <= HalfBit_cnt_width + 1; --最终问题来了,这个Halbit将会一直+1了,因为tick永远是初值0.。。。求哪位大神给我解惑 end if; |
2个回答
没仔细看,本人用的是Verilog,但是前面的clk速率应该是Manchester带宽的4倍,这样只是为了更加精准的采样,filterok才和Manchester编码后发出的波形一样
最佳答案
我的妈,VHDL真是复杂
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
397 浏览 0 评论
求FPGA 驱动控制ltc2271 或者 ltc2180 或者 ltc2190或者 ltc2202 的代码
1703 浏览 0 评论
469 浏览 0 评论
求助:遇见诡异问题,FPGA模块A输出端口连接模块B输入后,模块A不能正常工作的
1824 浏览 1 评论
518 浏览 0 评论
4584 浏览 102 评论
GMT+8, 2024-8-29 01:28 , Processed in 0.511884 second(s), Total 73, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
