电子发烧友论坛|
求助大神,毕设遇阻,救命啊
![]() 具体是这样的 我做一个直流电机的调速 用的是msp430g2553的板子 P1.4 1.5控制电机正反转 P1.6输出pwm波调速 p1.3连接槽型光耦模块测速 问题是程序写好后电机不转了。。也没法串口通讯。。。悲剧了 ![]() 求大神帮忙看看 跪谢!!! 程序如下 #include"msp430g2553.h" #include "msp430.h" #define uchar unsigned char #define uint unsigned int char js=' '; void UartPutchar(double c); unsigned char UartGetchar(); uchar flag; uint n; uint irtime; unsigned long int t; void pinlv(); //===========P1口的初始化==========// //====P1.3为中断输入口======// void initport() { P1OUT=BIT3; P1REN=BIT3; P1IE|=BIT3; P1IES|=BIT3;//触发方式选择 P1IFG=0x00; P1DIR |= BIT4+BIT5+BIT6; P1OUT|=BIT4; P1OUT&=~BIT5; P1SEL= BIT6; P1SEL = BIT1 + BIT2; // P1.1为 RXD, P1.2为TXD 接收数据引脚 发送数据引脚 P1SEL2 = BIT1 + BIT2; // P1.1为 RXD, P1.2为TXD } //===========OVER==================// //=========定时器的初始化===========// void init() { n=0; TA1CTL=TASSEL_2+MC_1;//SMCLK upmode TA1CCTL0=CCIE; TA1CCR0=800;//100us TA0CTL=TASSEL_2+TACLR+MC_1; TA0CCR0 = 10000; TA0CCTL1 = OUTMOD_7; TA0CCR1 = 3000; } //===============OVER=============// //=============main==============================// void main( void ) { WDTCTL = WDTPW + WDTHOLD; BCSCTL2 = SELM_0 + DIVM_0 + DIVS_0;//分频?SMCLK==>8MHZ BCSCTL1 = CALBC1_8MHZ; /* Set DCO to 8MHz */ DCOCTL = CALDCO_8MHZ; UCA0CTL1 |= UCSSEL_2; // 选择时钟BRCLK UCA0BR0 =65; // 8MHz 9600 UCA0BR1 = 3; // 8MHz 9600 UCA0MCTL = UCBRS1; // 波特率=BRCLK/(UBR+(M7+...0)/8) UCA0CTL1 &= ~UCSWRST; IE2 |= UCA0RXIE; // 使能接收中断 initport(); init(); _EINT(); while(1) { if(flag==1) { pinlv(); flag=0; } js=UartGetchar(); if(js=='o') { while(!(js=='o')); P1OUT^=BIT4|BIT5; } if(js=='s') { while(!(js=='s')); P1OUT^=BIT4; js=' '; } if (js=='k') { while(!(js=='k')); if (TA0CCR1>=10000) TA0CCR1=1000; else TA0CCR1+=1000; js=' '; } if (js=='m') { while(!(js=='m')); if (TA0CCR1<=1000) TA0CCR1=9000; else TA0CCR1-=1000; js=' '; } } } //==========main OVER=================// //=========100us定时中断服务函数=======// #pragma vector=TIMER1_A0_VECTOR __interrupt void timer(void) { irtime++; if(irtime==10000)//1s { irtime=0; flag=1; } } //===============接收端中断服务=================// #pragma vector=PORT1_VECTOR __interrupt void Port (void) { if(P1IFG&BIT3) { n++; t=n/2*60; P1IFG&=~BIT3; } } //============频率计===========// void pinlv() { n=0; } /**********************************UART接收中断*************************/ #pragma vector=USCIAB0RX_VECTOR __interrupt void USCI0RX_ISR(void) { while (!(IFG2&UCA0TXIFG)); // 等待发送完成 UCA0TXBUF = UCA0RXBUF; // TX ->RXed character IFG2 &=~UCA0RXIFG; //UartPutchar('a'); //temp=UCA0RXBUF; } /******************************UART发送字节函数*************************/ void UartPutchar(double c) { //while(!(IFG2 & UCA0TXIFG)); //待发送为空 UCA0TXBUF=c; //IFG2 &=~UCA0RXIFG; } /*****************************UART接收字节函数**************************/ unsigned char UartGetchar() { unsigned char c; while(!(IFG2 & UCA0RXIFG)); //等待接收完成 c=UCA0RXBUF; IFG2 &=~UCA0TXIFG; return c; } |
1个回答
pinlv()是什么?没有写函数吧
只有小组成员才能发言,加入小组>>
3327个成员聚集在这个小组
加入小组9555 浏览 1 评论
10355 浏览 1 评论
MSP430FR5994 使用库函数 定时器触发AD问题请教
10677 浏览 2 评论
请问怎么把下面51单片机的代码改成msp430 g2 pocket的代码,还有改下时间变成30秒
2657 浏览 1 评论
5114 浏览 1 评论
10677浏览 2评论
10355浏览 1评论
9556浏览 1评论
8214浏览 0评论
/9
GMT+8, 2025-12-2 02:24 , Processed in 0.432693 second(s), Total 46, Slave 38 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2194
