最近在做超声波测距,写完代码后,把买来的模块插到单片机发现固定一个值不变,求各位大神解答!
#include unsigned int i=0; ***it tring=P2^0; ***it echo=P2^1; ***it beep=P1^5; unsigned int qian,bai,shi,ge,time,s,time1,time2,flag=0; unsigned char code DIG_CODE[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f}; bit succeed_flag; void delay_20us() { unsigned int bt ; for(bt=0;bt<100;bt++); } void delay(unsigned int x) { unsigned int y; for(;x>0;x--) for(y=110;y>0;y--); } void INT0_time() interrupt 0 //外部中断 { time1=TH1; time2=TL1; time=time1*256+time2; succeed_flag=1; EX0=0; } void T1_time() interrupt 3 //计时 { TH1=0; TL1=0; } void display() //显示 { P2=0x00; P0=DIG_CODE[ge]; delay(3); P2=0x04; P0=DIG_CODE[shi]; delay(3); P2=0x08; P0=DIG_CODE[bai]; delay(3); P2=0x0c; P0=DIG_CODE[qian]; delay(3); } void main() //主函数 { flag=0; tring=0; TMOD=0x11; TR0=1; IT0=0; ET0=0; EX0=0; EA=1; while(1) { EA=0; tring=1; delay_20us(); tring=0; //发送一个20us的高电平 while(echo==0); //检测回波信号是否为高 succeed_flag=0; TH1=0; TL1=0; TF1=0; TR1=1; while(echo==1); EA=1; EX0=1; IE0=1; EX0=0; TR1=0; if(succeed_flag==1) { s=(long)(time*0.17); qian=s/1000; bai=s/100%10; shi=s%100/10; ge=s%10; } display(); } } |
2个回答
外加一个买开发板时的例程,实在不知道错在何处,检测模块正常!
#include"reg51.h" #include bit flag =0; ***it TX=P2^0; ***it RX=P2^1; unsigned int time=0; unsigned int timer=0; unsigned char posit=0; unsigned long S=0; #define GPIO_DIG P0 ***it LSA=P2^2; ***it LSB=P2^3; ***it LSC=P2^4; unsigned char code DIG_CODE[17]={ 0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07, 0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71}; unsigned int num; unsigned char di***uff[4]={ 0,0,0,0,}; /******************************************************************************* *******************************************************************************/ void DigDisplay() { unsigned char i; unsigned int j; for(i=0;i<8;i++) { switch(i) { case(0): LSA=0;LSB=0;LSC=0; break; case(1): LSA=1;LSB=0;LSC=0; break; case(2): LSA=0;LSB=1;LSC=0; break; case(3): LSA=1;LSB=1;LSC=0; break; case(4): LSA=0;LSB=0;LSC=1; break; case(5): LSA=1;LSB=0;LSC=1; break; case(6): LSA=0;LSB=1;LSC=1; break; case(7): LSA=1;LSB=1;LSC=1; break; } GPIO_DIG=di***uff[i];ë j=10; while(j--); GPIO_DIG=0x00;//ÏûÒþ } } /********************************************************/ void Conut(void) { time=TH0*256+TL0; TH0=0; TL0=0; S= (long)(time*0.17); if((S>=4000)||flag==1) { flag=0; di***uff[0]=0x3f; di***uff[1]=0x50; di***uff[2]=0x50; di***uff[3]=0x79; } else { di***uff[3]=DIG_CODE[S/1000]; di***uff[2]=DIG_CODE[S%1000/100]; di***uff[1]=DIG_CODE[S%100/10]; di***uff[0]=DIG_CODE[S%10]; } } /********************************************************/ void zd0() interrupt 1 { flag=1; } /********************************************************/ void zd3() interrupt 3 { TH1=0xf8; TL1=0x30; DigDisplay(); timer++; if(timer>=500) { timer=0; TX=1; //800MS _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); TX=0; } } /*********************************************************/ void main( void ) { TMOD=0x11; TH0=0; TL0=0; TH1=0xf8; TL1=0x30; ET0=1; ET1=1; TR1=1; EA=1; TR0=1; while(1) { while(!RX); TR0=1; //¿ªÆô¼ÆÊý while(RX); TR0=0; Conut(); } } |
有没有人可以解答一下呀!
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
串口发送中断中对发送I/O口定义为GPIO输出,出现发送数据不完整,缺少2个字节,求解答
187 浏览 0 评论
630 浏览 0 评论
【xG24 Matter开发套件试用体验】10-Bluetooth示例1
723 浏览 0 评论
781 浏览 0 评论
【xG24 Matter开发套件试用体验】power specification电源规格参数配置
599 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
10825 浏览 31 评论
GMT+8, 2024-8-23 16:23 , Processed in 0.626902 second(s), Total 78, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
