扫一扫,分享给好友
本人新手,按照步骤安装好quartusii11.0和modelsim后,进行到最后一步modelsim仿真时出现问题。就像这样,是在调用ROM模块进行仿真的时候出现的问题,程序按视频教程走的,作者用的10.1可以直接调用及仿真。已经弄了一天了,不知道是软件破解问题还是modelsim的调用问题,不知道该从什么方面下手了,拿 出所有积分跪求各位大神指引迷津。
程序调用MIF文件前是这样的 `timescale 1ns/1ns `define clk_period 20 module sin_bb; reg[5:0]addr; reg clk; wire[7:0]q; sin sin ( .address(addr), .clock(clk), .q(q)); initial clk=1; always #(`clk_period/2) clk=~clk; integer i; initial begin addr=0; for(i=0;i<63;i=i+1)begin #`clk_period; addr=addr+1; end #(`clk_period* 50); $stop; end endmodule 程序在调用mif文件后是这样的 LIBRARY ieee; USE ieee.std_logic_1164.all; LIBRARY altera_mf; USE altera_mf.all; ENTITY sin IS PORT ( address : IN STD_LOGIC_VECTOR (5 DOWNTO 0); clock : IN STD_LOGIC := '1'; q : OUT STD_LOGIC_VECTOR (7 DOWNTO 0) ); END sin; ARCHITECTURE SYN OF sin IS SIGNAL sub_wire0 : STD_LOGIC_VECTOR (7 DOWNTO 0); COMPONENT altsyncram GENERIC ( clock_enable_input_a : STRING; clock_enable_output_a : STRING; init_file : STRING; intended_device_family : STRING; lpm_hint : STRING; lpm_type : STRING; numwords_a : NATURAL; operation_mode : STRING; outdata_aclr_a : STRING; outdata_reg_a : STRING; widthad_a : NATURAL; width_a : NATURAL; width_byteena_a : NATURAL ); PORT ( address_a : IN STD_LOGIC_VECTOR (5 DOWNTO 0); clock0 : IN STD_LOGIC ; q_a : OUT STD_LOGIC_VECTOR (7 DOWNTO 0) ); END COMPONENT; BEGIN q <= sub_wire0(7 DOWNTO 0); altsyncram_component : altsyncram GENERIC MAP ( clock_enable_input_a => "BYPASS", clock_enable_output_a => "BYPASS", init_file => "sin.mif", intended_device_family => "Cyclone II", lpm_hint => "ENABLE_RUNTIME_MOD=NO", lpm_type => "altsyncram", numwords_a => 64, operation_mode => "ROM", outdata_aclr_a => "NONE", outdata_reg_a => "CLOCK0", widthad_a => 6, width_a => 8, width_byteena_a => 1 ) PORT MAP ( address_a => address, clock0 => clock, q_a => sub_wire0 ); END SYN; 错误是这样的 Error: Text Design File syntax error: Text Design File contains END where '(', IF, a symbolic name, or a number was expected Error: Text Design File syntax error: Text Design File contains BEGIN where END was expected Error: Text Design File syntax error: Text Design File contains END where ASSERT, CONSTANT, DEFINE, DESIGN, FUNCTION, OPTIONS, PARAMETERS, SUBDESIGN, or TITLE was expected Error: Text Design File syntax error: Text Design File contains END where ASSERT, CONSTANT, DEFINE, DESIGN, FUNCTION, OPTIONS, PARAMETERS, SUBDESIGN, or TITLE was expected Error: Text Design File syntax error: Text Design File contains END where ASSERT, CONSTANT, DEFINE, DESIGN, FUNCTION, OPTIONS, PARAMETERS, SUBDESIGN, or TITLE was expected Error: Text Design File syntax error: Text Design File contains IF where ASSERT, CONSTANT, DEFINE, DESIGN, FUNCTION, OPTIONS, PARAMETERS, SUBDESIGN, or TITLE was expected Error: Text Design File syntax error: Text Design File contains IF where ASSERT, CONSTANT, DEFINE, DESIGN, FUNCTION, OPTIONS, PARAMETERS, SUBDESIGN, or TITLE was expected Error: Text Design File syntax error: Text Design File contains END where ASSERT, CONSTANT, DEFINE, DESIGN, FUNCTION, OPTIONS, PARAMETERS, SUBDESIGN, or TITLE was expected Error: Text Design File syntax error: Text Design File contains END where ASSERT, CONSTANT, DEFINE, DESIGN, FUNCTION, OPTIONS, PARAMETERS, SUBDESIGN, or TITLE was expected Error: Text Design File syntax error: Text Design File contains END where ASSERT, CONSTANT, DEFINE, DESIGN, FUNCTION, OPTIONS, PARAMETERS, SUBDESIGN, or TITLE was expected Error: Text Design File syntax error: Text Design File contains END where ASSERT, CONSTANT, DEFINE, DESIGN, FUNCTION, OPTIONS, PARAMETERS, SUBDESIGN, or TITLE was expected Error: Text Design File syntax error: Text Design File contains IF where ASSERT, CONSTANT, DEFINE, DESIGN, FUNCTION, OPTIONS, PARAMETERS, SUBDESIGN, or TITLE was expected
4个回答
请附上你的veriolg HDL的源程序,怎么没有控制复位信号
谢谢分享
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1369 浏览 1 评论
462 浏览 0 评论
求FPGA 驱动控制ltc2271 或者 ltc2180 或者 ltc2190或者 ltc2202 的代码
2069 浏览 0 评论
521 浏览 0 评论
求助:遇见诡异问题,FPGA模块A输出端口连接模块B输入后,模块A不能正常工作的
2183 浏览 1 评论
4890 浏览 109 评论
GMT+8, 2024-9-9 17:23 , Processed in 0.600347 second(s), Total 79, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
