扫一扫,分享给好友
代码如下:
#include "adc_db_sm.h" #include "sys.h" #include "STM32f10x_adc.h" #include "stm32f10x_dma.h" #include "delay.h" __IO uint32_t ADC_DualConvertedValueTab[ADC_BufferLength]; void ADC1_2_Init(void) { ADC_InitTypeDef ADC_InitStructure; DMA_InitTypeDef DMA_InitStructure; GPIO_InitTypeDef GPIO_InitStructure; RCC_ADCCLKConfig(RCC_PCLK2_Div4); RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_ADC2 | RCC_APB2Periph_GPIOA, ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_4; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; GPIO_Init(GPIOA, &GPIO_InitStructure); DMA_DeInit(DMA1_Channel1); //DMA通道1恢复到默认状态 DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC1_DR_Address; //设置数据来源地址 DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)ADC_DualConvertedValueTab; //设置copy目标地址 DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; //设置copy方向 DMA_InitStructure.DMA_BufferSize = 16; //设置数组大小 DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //数据来源不变 DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //数据保存的数组地址自增 DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Word; //DMA操作字长 32位 DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Word; //DMA操作字长 32位 DMA_InitStructure.DMA_Mode = DMA_Mode_Normal; //普通的DMA操作模式:当DMA操作转移够 数组大小 //所限定的数据总量后,则不再进行DMA操作 DMA_InitStructure.DMA_Priority = DMA_Priority_High; //DMA优先级 DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; //关闭mTM DMA_Init(DMA1_Channel1, &DMA_InitStructure); //使能dma /* Enable DMA1 Channel1 */ DMA_Cmd(DMA1_Channel1, ENABLE); /* ADC1 configuration ------------------------------------------------------*/ ADC_InitStructure.ADC_Mode = ADC_Mode_RegSimult; //ADC1同步规则组模式 ADC_InitStructure.ADC_ScanConvMode = DISABLE; //启动扫描 ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; //连续转换 ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None; //无外部触发 ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; //结果右对齐 ADC_InitStructure.ADC_NbrOfChannel = 1; //转换通道数2 ADC_Init(ADC1, &ADC_InitStructure); //配置ADC1 /* ADC1 regular channels configuration */ ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 1, ADC_SampleTime_239Cycles5); //通道配置 /* Enable ADC1 DMA */ ADC_DMACmd(ADC1, ENABLE); /* ADC2 configuration ------------------------------------------------------*/ ADC_InitStructure.ADC_Mode = ADC_Mode_RegSimult; //ADC2同步规则组模式 ADC_InitStructure.ADC_ScanConvMode = DISABLE; //启动扫描 ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; //连续转换 ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None; //无外部触发 ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; //结果右对齐 ADC_InitStructure.ADC_NbrOfChannel = 1; //转换通道数 ADC_Init(ADC2, &ADC_InitStructure); //配置ADC2 /* ADC2 regular channels configuration */ ADC_RegularChannelConfig(ADC2, ADC_Channel_4, 1, ADC_SampleTime_239Cycles5); //通道配置 /* Enable ADC2 external trigger conversion */ ADC_ExternalTrigConvCmd(ADC2, ENABLE); //使能ADC2的外部触发模式 /* Enable ADC1 */ ADC_Cmd(ADC1, ENABLE); //使能ADC1 /* Enable Vrefint channel17 */ // ADC_TempSensorVrefintCmd(ENABLE); // 使能温度传感器内部参考电压通道 /* Enable ADC1 reset calibration register */ ADC_ResetCalibration(ADC1); //ADC1的校准 /* Check the end of ADC1 reset calibration register */ while(ADC_GetResetCalibrationStatus(ADC1)); /* Start ADC1 calibration */ ADC_StartCalibration(ADC1); /* Check the end of ADC1 calibration */ while(ADC_GetCalibrationStatus(ADC1)); /* Enable ADC2 */ ADC_Cmd(ADC2, ENABLE); //使能ADC2 /* Enable ADC2 reset calibration register */ ADC_ResetCalibration(ADC2); //ADC2的校准 /* Check the end of ADC2 reset calibration register */ while(ADC_GetResetCalibrationStatus(ADC2)); /* Start ADC2 calibration */ ADC_StartCalibration(ADC2); /* Check the end of ADC2 calibration */ while(ADC_GetCalibrationStatus(ADC2)); //delay_ms(50); //ADC_SoftwareStartConvCmd(ADC2, ENABLE); /* Start ADC1 Software Conversion */ //软件启动ADC1,开始转换 ADC_SoftwareStartConvCmd(ADC1, ENABLE); /* Test on DMA1 channel1 transfer complete flag */ //等待一组DMA存储转换完成 while(!DMA_GetFlagStatus(DMA1_FLAG_TC1)); /* Clear DMA1 channel1 transfer complete flag */ DMA_ClearFlag(DMA1_FLAG_TC1); //DMA_Done = 1; } void getAD(uint16_t *adc1_val,uint16_t *adc2_val) { int i; for(i=0;i<8;i++) { adc1_val[i] = ADC_DualConvertedValueTab[i]; adc2_val[i] = ADC_DualConvertedValueTab[i]>>16; } } 串口输出的结果为: ADC1 result is 4095 4095 4095 4095 4095 4095 4095 4095 ADC2 result is 2416 4095 4095 4095 4095 4095 4095 4095 标准结果为所有数据均为4095; 将采样频率变小,ADC2结果更加差! |
1个回答
系统默然的时钟为72M,按照RCC_ADCCLKConfig(RCC_PCLK2_Div4);四分频之后时钟频率为16M,而时钟频率最大仅可为14M,所以导致采样出现问题。我将RCC_PCLK2_Div4换成RCC_PCLK2_Div6 AD采样结果明显好转。
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
651 浏览 0 评论
712 浏览 0 评论
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
4375 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
3176 浏览 1 评论
stm32用fsmc读取ad7606采集数据,数据不变,只有开发版复位才更新数据
2629 浏览 0 评论
/9
GMT+8, 2025-12-10 01:26 , Processed in 0.811676 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1613
