CC2541的头文件-IAR 头文件
* - ioCC2541.h -
* Header file with definitions for the Texas Instruments CC2541 low-power System-on-Chip:
* an 8051-based MCU with 2.4 GHz Bluetooth low energy RF transceiver, and up to 256 kB FLASH.
* This file supports the IAR Embedded Workbench for 8051.
#ifndef IOCC2541_H
#define IOCC2541_H
* Compiler Abstraction
#ifdef __IAR_SYSTEMS_ICC__
#pragma language=extended
#define SFR(name,addr) __sfr __no_init volatile unsigned char name @ addr;
#define SFRBIT(name, addr, bit7, bit6, bit5, bit4, bit3, bit2, bit1, bit0)
__sfr __no_init volatile union
unsigned char name;
struct {
unsigned char bit0 : 1;
unsigned char bit1 : 1;
unsigned char bit2 : 1;
unsigned char bit3 : 1;
unsigned char bit4 : 1;
unsigned char bit5 : 1;
unsigned char bit6 : 1;
unsigned char bit7 : 1;
} @ addr;
#define SBIT(name,addr) /* not in use for IAR C Compiler */
#define XREG(addr) ((unsigned char volatile __xdata *) 0)[addr]
#define PXREG(addr) ((unsigned char volatile __xdata *) addr)
#define VECT(num,addr) addr
#elif defined __IAR_SYSTEMS_ASM__
#define SFR(name,addr) name DEFINE addr
SFRBITMACRO MACRO t, addr, bit7 , bit6, bit5, bit4, bit3, bit2, bit1, bit0
t DEFINE addr
bit7 DEFINE addr.7
bit6 DEFINE addr.6
bit5 DEFINE addr.5
bit4 DEFINE addr.4 ;; NB: do not modify indentation of this macro
bit3 DEFINE addr.3
bit2 DEFINE addr.2
bit1 DEFINE addr.1
bit0 DEFINE addr.0
ENDM
SFRBITMACRO , , , , , , , , ,
#define SBIT(name,addr) name DEFINE addr
#define XREG(addr) addr
#define PXREG(addr) addr
/* IAR assembler uses some predefined registers. The following prevents name collisions. */
#define SP SPx
#define ACC ACCx
#define B Bx
#define PSW PSWx
#define CY CYx
#define AC ACx
#define F0 F0x
#define RS1 RS1x
#define RS0 RS0x
#define OV OVx
#define P Px
#else
#error "Unrecognized compiler."
#endif
* Interrupt Vectors
#define RFERR_VECTOR VECT( 0, 0x03 ) /* RF core error situation */
#define ADC_VECTOR VECT( 1, 0x0B ) /* ADC end of conversion */
#define URX0_VECTOR VECT( 2, 0x13 ) /* USART 0 RX complete */
#define URX1_VECTOR VECT( 3, 0x1B ) /* USART 1 RX complete */
#define ENC_VECTOR VECT( 4, 0x23 ) /* AES encryption/decryption complete */
#define ST_VECTOR VECT( 5, 0x2B ) /* Sleep Timer Compare */
#define P2INT_VECTOR VECT( 6, 0x33 ) /* Port 2 Inputs and I2C */
#define UTX0_VECTOR VECT( 7, 0x3B ) /* USART0 TX Complete */
#define DMA_VECTOR VECT( 8, 0x43 ) /* DMA Transfer Complete */
#define T1_VECTOR VECT( 9, 0x4B ) /* Timer 1 (16-bit) Capture/Compare/Overflow */
#define T2_VECTOR VECT( 10, 0x53 ) /* Timer 2 */
#define T3_VECTOR VECT( 11, 0x5B ) /* Timer 3 (8-bit) Capture/Compare/Overflow */
#define T4_VECTOR VECT( 12, 0x63 ) /* Timer 4 (8-bit) Capture/Compare/Overflow */
#define P0INT_VECTOR VECT( 13, 0x6B ) /* Port 0 Inputs */
#define UTX1_VECTOR VECT( 14, 0x73 ) /* USART1 TX Complete */
#define P1INT_VECTOR VECT( 15, 0x7B ) /* Port 1 Inputs */
#define RF_VECTOR VECT( 16, 0x83 ) /* RF General Interrupts */
#define WDT_VECTOR VECT( 17, 0x8B ) /* Watchdog Overflow in Timer Mode */
* Interrupt Alias
#define I2C_VECTOR P2INT_VECTOR /* I2C Interrupt vector, alias for P2INT_VECTOR */
* SFRs
* SFRs with an address ending with 0 or 8 are bit accessible.
* They are defined with the SFRBIT() macro that sets the name of each bit.
/* Port 0 */
SFRBIT( P0 , 0x80, P0_7, P0_6, P0_5, P0_4, P0_3, P0_2, P0_1, P0_0 )
SFR( SP , 0x81 ) /* Stack Pointer */
SFR( DPL0 , 0x82 ) /* Data Pointer 0 Low Byte */
SFR( DPH0 , 0x83 ) /* Data Pointer 0 High Byte */
SFR( DPL1 , 0x84 ) /* Data Pointer 1 Low Byte */
SFR( DPH1 , 0x85 ) /* Data Pointer 1 High Byte */
SFR( U0CSR , 0x86 ) /* USART 0 Control and Status */
SFR( PCON , 0x87 ) /* Power Mode Control */
/* Interrupt Flags */
SFRBIT( TCON , 0x88, URX1IF, _TCON6, ADCIF, _TCON4, URX0IF, IT1, RFERRIF, IT0 )
SFR( P0IFG , 0x89 ) /* Port 0 Interrupt Status Flag */
SFR( P1IFG , 0x8A ) /* Port 1 Interrupt Status Flag */
SFR( P2IFG , 0x8B ) /* Port 2 Interrupt Status Flag */
SFR( PICTL , 0x8C ) /* Port Interrupt Control */
SFR( P1IEN , 0x8D ) /* Port 1 Interrupt Mask */
SFR( _SFR8E , 0x8E ) /* not used */
SFR( P0INP , 0x8F ) /* Port 0 Input Mode */
/* Port 1 */
SFRBIT( P1 , 0x90, P1_7, P1_6, P1_5, P1_4, P1_3, P1_2, P1_1, P1_0 )
SFR( RFIRQF1 , 0x91 ) /* RF Interrupt Flags MSB */
SFR( DPS , 0x92 ) /* Data Pointer Select */
SFR( MPAGE , 0x93 ) /* Memory Page Select */
SFR( T2CTRL , 0x94 ) /* Timer2 Control Register */
SFR( ST0 , 0x95 ) /* Sleep Timer 0 */
SFR( ST1 , 0x96 ) /* Sleep Timer 1 */
SFR( ST2 , 0x97 ) /* Sleep Timer 2 */
/* Interrupt Flags 2 */
SFRBIT( S0CON , 0x98, _S0CON7, _S0CON6, _S0CON5, _S0CON4, _S0CON3, _S0CON2, ENCIF_1, ENCIF_0 )
SFR( _SFR99 , 0x99 ) /* reserved */
SFR( IEN2 , 0x9A ) /* Interrupt Enable 2 */
SFR( S1CON , 0x9B ) /* Interrupt Flags 3 */
SFR( T2CSPCFG , 0x9C ) /* Timer2 CSP Interface Configuration (legacy name) */
SFR( T2EVTCFG , 0x9C ) /* Timer2 Event Output Configuration */
SFR( SLEEPSTA , 0x9D ) /* Sleep Status */
SFR( CLKCONSTA , 0x9E ) /* Clock Control Status */
SFR( FMAP , 0x9F ) /* Flash Bank Map */
/* Port 2 */
SFRBIT( P2 , 0xA0, _P2_7, _P2_6, _P2_5, P2_4, P2_3, P2_2, P2_1, P2_0 )
SFR( T2IRQF , 0xA1 ) /* Timer2 Interrupt Flags */
SFR( T2M0 , 0xA2 ) /* Timer2 Multiplexed Register 0 */
SFR( T2M1 , 0xA3 ) /* Timer2 Multiplexed Register 1 */
SFR( T2MOVF0 , 0xA4 ) /* Timer2 Multiplexed Overflow Register 0 */
SFR( T2MOVF1 , 0xA5 ) /* Timer2 Multiplexed Overflow Register 1 */
SFR( T2MOVF2 , 0xA6 ) /* Timer2 Multiplexed Overflow Register 2 */
SFR( T2IRQM , 0xA7 ) /* Timer2 Interrupt Masks */
/* Interrupt Enable 0 */
SFRBIT( IEN0 , 0xA8, EA, _IEN06, STIE, ENCIE, URX1IE, URX0IE, ADCIE, RFERRIE )
SFR( IP0 , 0xA9 ) /* Interrupt Priority 0 */
SFR( _SFRAA , 0xAA ) /* not used */
SFR( P0IEN , 0xAB ) /* Port 0 Interrupt Mask */
SFR( P2IEN , 0xAC ) /* Port 2 Interrupt Mask */
SFR( STLOAD , 0xAD ) /* Sleep Timer Load Status */
SFR( PMUX , 0xAE ) /* Power Down Signal MUX */
SFR( T1STAT , 0xAF ) /* Timer 1 Status */
SFR( _SFRB0 , 0xB0 ) /* not used */
SFR( ENCDI , 0xB1 ) /* Encryption/Decryption Input Data */
SFR( ENCDO , 0xB2 ) /* Encryption/Decryption Output Data */
SFR( ENCCS , 0xB3 ) /* Encryption/Decryption Control and Status */
SFR( ADCCON1 , 0xB4 ) /* ADC Control 1 */
SFR( ADCCON2 , 0xB5 ) /* ADC Control 2 */
SFR( ADCCON3 , 0xB6 ) /* ADC Control 3 */
SFR( _SFRB7 , 0xB7 ) /* reserved */
/* Interrupt Enable 1 */
SFRBIT( IEN1 , 0xB8, _IEN17, _IEN16, P0IE, T4IE, T3IE, T2IE, T1IE, DMAIE )
SFR( IP1 , 0xB9 ) /* Interrupt Priority 1 */
SFR( ADCL , 0xBA ) /* ADC Data Low */
SFR( ADCH , 0xBB ) /* ADC Data High */
SFR( RNDL , 0xBC ) /* Random Number Generator Low Byte */
SFR( RNDH , 0xBD ) /* Random Number Generator High Byte */
SFR( SLEEPCMD , 0xBE ) /* Sleep Mode Control Command */
SFR( RFERRF , 0xBF ) /* RF Error Interrupt Flags */
/* Interrupt Flags 4 */
SFRBIT( IRCON , 0xC0, STIF, _IRCON6, P0IF, T4IF, T3IF, T2IF, T1IF, DMAIF )
SFR( U0DBUF , 0xC1 ) /* USART 0 Receive/Transmit Data Buffer */
SFR( U0BAUD , 0xC2 ) /* USART 0 Baud Rate Control */
SFR( T2MSEL , 0xC3 ) /* Timer2 Multiplex Select */
SFR( U0UCR , 0xC4 ) /* USART 0 UART Control */
SFR( U0GCR , 0xC5 ) /* USART 0 Generic Control */
SFR( CLKCONCMD , 0xC6 ) /* Clock Control Command */
SFR( MEMCTR , 0xC7 ) /* Memory System Control */
SFR( _SFRC8 , 0xC8 ) /* not used */
SFR( WDCTL , 0xC9 ) /* Watchdog Timer Control */
SFR( T3CNT , 0xCA ) /* Timer 3 Counter */
SFR( T3CTL , 0xCB ) /* Timer 3 Control */
SFR( T3CCTL0 , 0xCC ) /* Timer 3 Channel 0 Capture/Compare Control */
SFR( T3CC0 , 0xCD ) /* Timer 3 Channel 0 Capture/Compare Value */
SFR( T3CCTL1 , 0xCE ) /* Timer 3 Channel 1 Capture/Compare Control */
SFR( T3CC1 , 0xCF ) /* Timer 3 Channel 1 Capture/Compare Value */
/* Program Status Word */
SFRBIT( PSW , 0xD0, CY, AC, F0, RS1, RS0, OV, F1, P )
SFR( DMAIRQ , 0xD1 ) /* DMA Interrupt Flag */
SFR( DMA1CFGL , 0xD2 ) /* DMA Channel 1-4 Configuration Address Low Byte */
SFR( DMA1CFGH , 0xD3 ) /* DMA Channel 1-4 Configuration Address High Byte */
SFR( DMA0CFGL , 0xD4 ) /* DMA Channel 0 Configuration Address Low Byte */
SFR( DMA0CFGH , 0xD5 ) /* DMA Channel 0 Configuration Address High Byte */
SFR( DMAARM , 0xD6 ) /* DMA Channel Arm */
SFR( DMAREQ , 0xD7 ) /* DMA Channel Start Request and Status */
/* Timers 1/3/4 Interrupt Mask/Flag */
SFRBIT( TIMIF , 0xD8 , _TIMIF7, T1OVFIM, T4CH1IF, T4CH0IF, T4OVFIF, T3CH1IF, T3CH0IF, T3OVFIF )
SFR( RFD , 0xD9 ) /* RF Data */
SFR( T1CC0L , 0xDA ) /* Timer 1 Channel 0 Capture/Compare Value Low Byte */
SFR( T1CC0H , 0xDB ) /* Timer 1 Channel 0 Capture/Compare Value High Byte */
SFR( T1CC1L , 0xDC ) /* Timer 1 Channel 1 Capture/Compare Value Low Byte */
SFR( T1CC1H , 0xDD ) /* Timer 1 Channel 1 Capture/Compare Value High Byte */
SFR( T1CC2L , 0xDE ) /* Timer 1 Channel 2 Capture/Compare Value Low Byte */
SFR( T1CC2H , 0xDF ) /* Timer 1 Channel 2 Capture/Compare Value High Byte */
SFR( ACC , 0xE0 ) /* Accumulator */
SFR( RFST , 0xE1 ) /* RF Command Strobe */
SFR( T1CNTL , 0xE2 ) /* Timer 1 Counter Low */
SFR( T1CNTH , 0xE3 ) /* Timer 1 Counter High */
SFR( T1CTL , 0xE4 ) /* Timer 1 Control And Status */
SFR( T1CCTL0 , 0xE5 ) /* Timer 1 Channel 0 Capture/Compare Control */
SFR( T1CCTL1 , 0xE6 ) /* Timer 1 Channel 1 Capture/Compare Control */
SFR( T1CCTL2 , 0xE7 ) /* Timer 1 Channel 2 Capture/Compare Control */
/* Interrupt Flags 5 */
SFRBIT( IRCON2 , 0xE8, _IRCON27, _IRCON26, _IRCON25, WDTIF, P1IF, UTX1IF, UTX0IF, P2IF )
SFR( RFIRQF0 , 0xE9 ) /* RF Interrupt Flags LSB */
SFR( T4CNT , 0xEA ) /* Timer 4 Counter */
SFR( T4CTL , 0xEB ) /* Timer 4 Control */
SFR( T4CCTL0 , 0xEC ) /* Timer 4 Channel 0 Capture/Compare Control */
SFR( T4CC0 , 0xED ) /* Timer 4 Channel 0 Capture/Compare Value */
SFR( T4CCTL1 , 0xEE ) /* Timer 4 Channel 1 Capture/Compare Control */
SFR( T4CC1 , 0xEF ) /* Timer 4 Channel 1 Capture/Compare Value */
SFR( B , 0xF0 ) /* B Register */
SFR( PERCFG , 0xF1 ) /* Peripheral I/O Control */
SFR( ADCCFG , 0xF2 ) /* ADC Input Configuration (legacy name) */
SFR( APCFG , 0xF2 ) /* Analog Periferal I/O Configuration */
SFR( P0SEL , 0xF3 ) /* Port 0 Function Select */
SFR( P1SEL , 0xF4 ) /* Port 1 Function Select */
SFR( P2SEL , 0xF5 ) /* Port 2 Function Select */
SFR( P1INP , 0xF6 ) /* Port 1 Input Mode */
SFR( P2INP , 0xF7 ) /* Port 2 Input Mode */
/* USART 1 Control and Status */
SFRBIT( U1CSR , 0xF8, U1MODE, U1RE, U1SLAVE, U1FE, U1ERR, U1RX_BYTE, U1TX_BYTE, U1ACTIVE )
SFR( U1DBUF , 0xF9 ) /* USART 1 Receive/Transmit Data Buffer */
SFR( U1BAUD , 0xFA ) /* USART 1 Baud Rate Control */
SFR( U1UCR , 0xFB ) /* USART 1 UART Control */
SFR( U1GCR , 0xFC ) /* USART 1 Generic Control */
SFR( P0DIR , 0xFD ) /* Port 0 Direction */
SFR( P1DIR , 0xFE ) /* Port 1 Direction */
SFR( P2DIR , 0xFF ) /* Port 2 Direction */
* Xdata Radio Registers
/* RF core ram */
#define RFCORE_RAM PXREG( 0x6000 )
#define RFCORE_RAM_SZ 1024
/* RF core ram register/general memory page */
#define RFCORE_RAM_PAGE PXREG( 0x6000 )
#define RFCORE_RAM_PAGE_SZ 128
/* FIFO direct access */
#define RXFIFO PXREG( 0x6080 )
#define RXFIFO_SZ 128
#define TXFIFO PXREG( 0x6100 )
#define TXFIFO_SZ 128
/* Radio Control Registers */
#define FRMCTRL0 XREG(0x6180)
#define RFIRQM0 XREG(0x6181)
#define RFIRQM1 XREG(0x6182)
#define RFERRM XREG(0x6183)
#define FREQCTRL XREG(0x6184)
#define FREQTUNE XREG(0x6185)
#define TXPOWER XREG(0x6186)
#define TXCTRL XREG(0x6187)
#define LLESTAT XREG(0x6188)
#define _XREG6189 XREG(0x6189)
#define SEMAPHORE0 XREG(0x618A)
#define SEMAPHORE1 XREG(0x618B)
#define SEMAPHORE2 XREG(0x618C)
#define RFSTAT XREG(0x618D)
#define RSSI XREG(0x618E)
#define RFPSRND XREG(0x618F)
#define MDMCTRL0 XREG(0x6190)
#define MDMCTRL1 XREG(0x6191)
#define MDMCTRL2 XREG(0x6192)
#define MDMCTRL3 XREG(0x6193)
#define SW_CONF XREG(0x6194)
#define SW0 XREG(0x6195)
#define SW1 XREG(0x6196)
#define SW2 XREG(0x6197)
#define SW3 XREG(0x6198)
#define SW4 XREG(0x61F8)
#define SW5 XREG(0x61F9)
#define SW6 XREG(0x61FA)
#define SW7 XREG(0x61FB)
#define FREQEST XREG(0x6199)
#define RXCTRL XREG(0x619A)
#define FSCTRL XREG(0x619B)
#define _XREG619C XREG(0x619C)
#define _XREG619D XREG(0x619D)
#define _XREG619E XREG(0x619E)
#define _XREG619F XREG(0x619F)
#define LNAGAIN XREG(0x61A0)
#define AAFGAIN XREG(0x61A1)
#define ADCTEST0 XREG(0x61A2)
#define MDMTEST0 XREG(0x61A5)
#define MDMTEST1 XREG(0x61A6)
#define _XREG61A7 XREG(0x61A7)
#define _XREG61A8 XREG(0x61A8)
#define ATEST XREG(0x61A9)
#define RFC_OBS_CTRL0 XREG(0x61AE)
#define RFC_OBS_CTRL1 XREG(0x61AF)
#define RFC_OBS_CTRL2 XREG(0x61B0)
#define LLECTRL XREG(0x61B1)
#define TXFILTCFG XREG(0x61BC)
#define RFRND XREG(0x61BF)
#define RFRAMCFG XREG(0x61C0)
#define RFFDMA0 XREG(0x61C3)
#define RFFDMA1 XREG(0x61C4)
#define RFFSTATUS XREG(0x61C5)
#define RFFCFG XREG(0x61C6)
#define RFRXFLEN XREG(0x61C8)
#define RFRXFTHRS XREG(0x61C9)
#define RFRXFWR XREG(0x61CA)
#define RFRXFRD XREG(0x61CB)
#define RFRXFWP XREG(0x61CC)
#define RFRXFRP XREG(0x61CD)
#define RFRXFSWP XREG(0x61CE)
#define RFRXFSRP XREG(0x61CF)
#define RFTXFLEN XREG(0x61D0)
#define RFTXFTHRS XREG(0x61D1)
#define RFTXFWR XREG(0x61D2)
#define RFTXFRD XREG(0x61D3)
#define RFTXFWP XREG(0x61D4)
#define RFTXFRP XREG(0x61D5)
#define RFTXFSWP XREG(0x61D6)
#define RFTXFSRP XREG(0x61D7)
#define BSP_P0 XREG(0x61E0)
#define BSP_P1 XREG(0x61E1)
#define BSP_P2 XREG(0x61E2)
#define BSP_P3 XREG(0x61E3)
#define BSP_D0 XREG(0x61E4)
#define BSP_D1 XREG(0x61E5)
#define BSP_D2 XREG(0x61E6)
#define BSP_D3 XREG(0x61E7)
#define BSP_W XREG(0x61E8)
#define BSP_MODE XREG(0x61E9)
#define BSP_DATA XREG(0x61EA)
#define DC_I_L XREG(0x61FC)
#define DC_I_H XREG(0x61FD)
#define DC_Q_L XREG(0x61FE)
#define DC_Q_H XREG(0x61FF)
* Xdata Registers
/* Power-Management Registers */
#define SRCRC XREG( 0x6262 )
/* Observability Control */
#define OBSSEL0 XREG( 0x6243 )
#define OBSSEL1 XREG( 0x6244 )
#define OBSSEL2 XREG( 0x6245 )
#define OBSSEL3 XREG( 0x6246 )
#define OBSSEL4 XREG( 0x6247 )
#define OBSSEL5 XREG( 0x6248 )
#define TR0 XREG( 0x624B )
/* Chip Identification */
#define CHVER XREG( 0x6249 )
#define CHIPID XREG( 0x624A )
/* Debug Interface DMA Write to Flash */
#define DBGDATA XREG( 0x6260 )
/* Flash Controller */
#define FCTL XREG( 0x6270 )
#define FADDRL XREG( 0x6271 )
#define FADDRH XREG( 0x6272 )
#define FWDATA XREG( 0x6273 )
#define FWT_HSOSC XREG( 0x6274 )
#define FWT_XOSC XREG( 0x6275 )
/* Chip Information */
#define CHIPINFO0 XREG( 0x6276 )
#define CHIPINFO1 XREG( 0x6277 )
/* IR Generation Control */
#define IRCTL XREG( 0x6281 )
/* Clock Loss Detector */
#define CLD XREG( 0x6290 )
/* Timer 1 Channels (only mapped as XREG) */
#define T1CCTL3 XREG( 0x62A3 )
#define T1CCTL4 XREG( 0x62A4 )
#define T1CC3L XREG( 0x62AC )
#define T1CC3H XREG( 0x62AD )
#define T1CC4L XREG( 0x62AE )
#define T1CC4H XREG( 0x62AF )
/* Definition which includes channels represented in SFR (additional XREG mapping of SFR) */
#define XX_T1CCTL0 XREG( 0x62A0 )
#define XX_T1CCTL1 XREG( 0x62A1 )
#define XX_T1CCTL2 XREG( 0x62A2 )
#define XX_T1CCTL3 XREG( 0x62A3 )
#define XX_T1CCTL4 XREG( 0x62A4 )
#define XX_T1CC0L XREG( 0x62A6 )
#define XX_T1CC0H XREG( 0x62A7 )
#define XX_T1CC1L XREG( 0x62A8 )
#define XX_T1CC1H XREG( 0x62A9 )
#define XX_T1CC2L XREG( 0x62AA )
#define XX_T1CC2H XREG( 0x62AB )
#define XX_T1CC3L XREG( 0x62AC )
#define XX_T1CC3H XREG( 0x62AD )
#define XX_T1CC4L XREG( 0x62AE )
#define XX_T1CC4H XREG( 0x62AF )
/* Pointers for array access */
#define P_T1CCTL PXREG( 0x62A0 )
#define P_T1CC PXREG( 0x62A6 )
/* Sleep Timer Capture Control */
#define STCC XREG( 0x62B0 )
#define STCS XREG( 0x62B1 )
#define STCV0 XREG( 0x62B2 )
#define STCV1 XREG( 0x62B3 )
#define STCV2 XREG( 0x62B4 )
/* Op.Amp. Control */
#define OPAMPMC XREG( 0x61AD )
#define OPAMPC XREG( 0x62C0 )
#define OPAMPS XREG( 0x62C1 )
/* Analog Comparator Control */
#define CMPCTL XREG( 0x62D0 )
/* I2C */
#define I2CCFG XREG( 0x6230 )
#define I2CSTAT XREG( 0x6231 )
#define I2CDATA XREG( 0x6232 )
#define I2CADDR XREG( 0x6233 )
#define I2CWC XREG( 0x6234 )
#define I2CIO XREG( 0x6235 )
/* Other */
#define IVCTRL XREG( 0x6265 )
* Xdata Mapped SFRs
* Most SFRs are also accessible through XDATA address space. The register definitions for
* this type of access are listed below. The register names are identical to the SFR names
* but with the prefix X_ to denote an XDATA register.
* Some SFRs are not accessible through XDATA space. For clarity, entries are included for these
* registers. They have a prefix of _NA to denote "not available."
* For register descriptions, refer to the actual SFR declartions elsewhere in this file.
#define X_P0 XREG( 0x7080 ) /* Port 0. NOTE! Read-only access from XREG. */
#define _NA_SP XREG( 0x7081 )
#define _NA_DPL0 XREG( 0x7082 )
#define _NA_DPH0 XREG( 0x7083 )
#define _NA_DPL1 XREG( 0x7084 )
#define _NA_DPH1 XREG( 0x7085 )
#define X_U0CSR XREG( 0x7086 ) /* USART 0 Control and Status */
#define _NA_PCON XREG( 0x7087 )
#define _NA_TCON XREG( 0x7088 )
#define X_P0IFG XREG( 0x7089 ) /* Port 0 Interrupt Status Flag */
#define X_P1IFG XREG( 0x708A ) /* Port 1 Interrupt Status Flag */
#define X_P2IFG XREG( 0x708B ) /* Port 2 Interrupt Status Flag */
#define X_PICTL XREG( 0x708C ) /* Port Interrupt Control */
#define X_P1IEN XREG( 0x708D ) /* Port 1 Interrupt Mask */
#define _NA_SFR8E XREG( 0x708E )
#define X_P0INP XREG( 0x708F ) /* Port 0 Input Mode */
#define X_P1 XREG( 0x7090 ) /* Port 1. NOTE! Read-only access from XREG. */
#define X_RFIRQF1 XREG( 0x7091 ) /* RF Interrupt Flags MSB */
#define _NA_DPS XREG( 0x7092 )
#define X_MPAGE XREG( 0x7093 ) /* Memory Page Select */
#define X_T2CTRL XREG( 0x7094 ) /* Timer2 Control Register */
#define X_ST0 XREG( 0x7095 ) /* Sleep Timer 0 */
#define X_ST1 XREG( 0x7096 ) /* Sleep Timer 1 */
#define X_ST2 XREG( 0x7097 ) /* Sleep Timer 2 */
#define _NA_S0CON XREG( 0x7098 )
#define _NA_SFR99 XREG( 0x7099 )
#define _NA_IEN2 XREG( 0x709A )
#define _NA_S1CON XREG( 0x709B )
#define X_T2CSPCFG XREG( 0x709C ) /* Timer2 CSP Interface Configuration (legacy name) */
#define X_T2EVTCFG XREG( 0x709C ) /* Timer2 Event Output Configuration */
#define X_SLEEPSTA XREG( 0x709D ) /* Sleep Status */
#define X_CLKCONSTA XREG( 0x709E ) /* Clock Control Status */
#define X_FMAP XREG( 0x709F ) /* Flash Bank Map */
#define X_P2 XREG( 0x70A0 ) /* Port 2. NOTE! Read-only access from XREG. */
#define X_T2IRQF XREG( 0x70A1 ) /* Timer2 Interrupt Flags */
#define X_T2M0 XREG( 0x70A2 ) /* Timer2 Multiplexed Register 0 */
#define X_T2M1 XREG( 0x70A3 ) /* Timer2 Multiplexed Register 1 */
#define X_T2MOVF0 XREG( 0x70A4 ) /* Timer2 Multiplexed Overflow Register 0 */
#define X_T2MOVF1 XREG( 0x70A5 ) /* Timer2 Multiplexed Overflow Register 1 */
#define X_T2MOVF2 XREG( 0x70A6 ) /* Timer2 Multiplexed Overflow Register 2 */
#define X_T2IRQM XREG( 0x70A7 ) /* Timer2 Interrupt Mask */
#define _NA_IEN0 XREG( 0x70A8 )
#define _NA_IP0 XREG( 0x70A9 )
#define _NA_SFRAA XREG( 0x70AA )
#define X_P0IEN XREG( 0x70AB ) /* */
#define X_P2IEN XREG( 0x70AC ) /* */
#define X_STLOAD XREG( 0x70AD ) /* Sleep Timer Load Status */
#define X_PMUX XREG( 0x70AE ) /* */
#define X_T1STAT XREG( 0x70AF ) /* */
#define _NA_SFRB0 XREG( 0x70A8 )
#define X_ENCDI XREG( 0x70B1 ) /* Encryption Input Data */
#define X_ENCDO XREG( 0x70B2 ) /* Encryption Output Data */
#define X_ENCCS XREG( 0x70B3 ) /* Encryption Control and Status */
#define X_ADCCON1 XREG( 0x70B4 ) /* ADC Control 1 */
#define X_ADCCON2 XREG( 0x70B5 ) /* ADC Control 2 */
#define X_ADCCON3 XREG( 0x70B6 ) /* ADC Control 3 */
#define _NA_SFRB7 XREG( 0x70B7 )
#define _NA_IEN1 XREG( 0x70B8 )
#define _NA_IP1 XREG( 0x70B9 )
#define X_ADCL XREG( 0x70BA ) /* ADC Data Low */
#define X_ADCH XREG( 0x70BB ) /* ADC Data High */
#define X_RNDL XREG( 0x70BC ) /* Random Register Low Byte */
#define X_RNDH XREG( 0x70BD ) /* Random Register High Byte */
#define X_SLEEPCMD XREG( 0x70BE ) /* Sleep Mode Command */
#define X_RFERRF XREG( 0x70BF ) /* RF Error Interrupt Flags */
#define _NA_IRCON XREG( 0x70C0 )
#define X_U0DBUF XREG( 0x70C1 ) /* USART 0 Receive/Transmit Data Buffer */
#define X_U0BAUD XREG( 0x70C2 ) /* USART 0 Baud Rate Control */
#define X_T2MSEL XREG( 0x70C3 ) /* Timer2 Multiplex Select */
#define X_U0UCR XREG( 0x70C4 ) /* USART 0 UART Control */
#define X_U0GCR XREG( 0x70C5 ) /* USART 0 Generic Control */
#define X_CLKCONCMD XREG( 0x70C6 ) /* Clock Control Command */
#define X_MEMCTR XREG( 0x70C7 ) /* Memory Arbiter Control */
#define _NA_SFRC8 XREG( 0x70C8 )
#define X_WDCTL XREG( 0x70C9 ) /* Watchdog Timer Control */
#define X_T3CNT XREG( 0x70CA ) /* Timer 3 Counter */
#define X_T3CTL XREG( 0x70CB ) /* Timer 3 Control */
#define X_T3CCTL0 XREG( 0x70CC ) /* Timer 3 Channel 0 Capture/Compare Control */
#define X_T3CC0 XREG( 0x70CD ) /* Timer 3 Channel 0 Capture/Compare Value */
#define X_T3CCTL1 XREG( 0x70CE ) /* Timer 3 Channel 1 Capture/Compare Control */
#define X_T3CC1 XREG( 0x70CF ) /* Timer 3 Channel 1 Capture/Compare Value */
#define _NA_PSW XREG( 0x70D0 )
#define X_DMAIRQ XREG( 0x70D1 ) /* DMA Interrupt Flag */
#define X_DMA1CFGL XREG( 0x70D2 ) /* DMA Channel 1-4 Configuration Address Low Byte */
#define X_DMA1CFGH XREG( 0x70D3 ) /* DMA Channel 1-4 Configuration Address High Byte */
#define X_DMA0CFGL XREG( 0x70D4 ) /* DMA Channel 0 Configuration Address Low Byte */
#define X_DMA0CFGH XREG( 0x70D5 ) /* DMA Channel 0 Configuration Address High Byte */
#define X_DMAARM XREG( 0x70D6 ) /* DMA Channel Arm */
#define X_DMAREQ XREG( 0x70D7 ) /* DMA Channel Start Request and Status */
#define X_TIMIF XREG( 0x70D8 ) /* Timers 1/3/4 Interrupt Mask/Flag */
#define X_RFD XREG( 0x70D9 ) /* RF Data */
#define X_T1CC0L XREG( 0x70DA ) /* Timer 1 Channel 0 Capture/Compare Value Low Byte */
#define X_T1CC0H XREG( 0x70DB ) /* Timer 1 Channel 0 Capture/Compare Value High Byte */
#define X_T1CC1L XREG( 0x70DC ) /* Timer 1 Channel 1 Capture/Compare Value Low Byte */
#define X_T1CC1H XREG( 0x70DD ) /* Timer 1 Channel 1 Capture/Compare Value High Byte */
#define X_T1CC2L XREG( 0x70DE ) /* Timer 1 Channel 2 Capture/Compare Value Low Byte */
#define X_T1CC2H XREG( 0x70DF ) /* Timer 1 Channel 2 Capture/Compare Value High Byte */
#define _NA_ACC XREG( 0x70E0 )
#define X_RFST XREG( 0x70E1 ) /* RF Command Strobe */
#define X_T1CNTL XREG( 0x70E2 ) /* Timer 1 Counter Low */
#define X_T1CNTH XREG( 0x70E3 ) /* Timer 1 Counter High */
#define X_T1CTL XREG( 0x70E4 ) /* Timer 1 Control and Status */
#define X_T1CCTL0 XREG( 0x70E5 ) /* Timer 1 Channel 0 Capture/Compare Control */
#define X_T1CCTL1 XREG( 0x70E6 ) /* Timer 1 Channel 1 Capture/Compare Control */
#define X_T1CCTL2 XREG( 0x70E7 ) /* Timer 1 Channel 2 Capture/Compare Control */
#define _NA_IRCON2 XREG( 0x70E8 )
#define X_RFIRQF0 XREG( 0x70E9 ) /* RF Interrupt Flags MSB */
#define X_T4CNT XREG( 0x70EA ) /* Timer 4 Counter */
#define X_T4CTL XREG( 0x70EB ) /* Timer 4 Control */
#define X_T4CCTL0 XREG( 0x70EC ) /* Timer 4 Channel 0 Capture/Compare Control */
#define X_T4CC0 XREG( 0x70ED ) /* Timer 4 Channel 0 Capture/Compare Value */
#define X_T4CCTL1 XREG( 0x70EE ) /* Timer 4 Channel 1 Capture/Compare Control */
#define X_T4CC1 XREG( 0x70EF ) /* Timer 4 Channel 1 Capture/Compare Value */
#define _NA_B XREG( 0x70F0 )
#define X_PERCFG XREG( 0x70F1 ) /* Peripheral Control */
#define X_ADCCFG XREG( 0x70F2 ) /* ADC Input Configuration (legacy name) */
#define X_APCFG XREG( 0x70F2 ) /* Analog Periferal I/O Configuration */
#define X_P0SEL XREG( 0x70F3 ) /* Port 0 Function Select */
#define X_P1SEL XREG( 0x70F4 ) /* Port 1 Function Select */
#define X_P2SEL XREG( 0x70F5 ) /* Port 2 Function Select */
#define X_P1INP XREG( 0x70F6 ) /* Port 1 Input Mode */
#define X_P2INP XREG( 0x70F7 ) /* Port 2 Input Mode */
#define X_U1CSR XREG( 0x70F8 ) /* USART 1 Control and Status */
#define X_U1DBUF XREG( 0x70F9 ) /* USART 1 Receive/Transmit Data Buffer */
#define X_U1BAUD XREG( 0x70FA ) /* USART 1 Baud Rate Control */
#define X_U1UCR XREG( 0x70FB ) /* USART 1 UART Control */
#define X_U1GCR XREG( 0x70FC ) /* USART 1 Generic Control */
#define X_P0DIR XREG( 0x70FD ) /* Port 0 Direction */
#define X_P1DIR XREG( 0x70FE ) /* Port 1 Direction */
#define X_P2DIR XREG( 0x70FF ) /* Port 2 Direction */
* Flash
#define P_INFOPAGE PXREG( 0x7800 ) /* Pointer to Start of Flash Information Page */
#define P_XBANK PXREG( 0x8000 ) /* Pointer to Start of Selectable Flash Bank (XBANK) */
#pragma language=default
#endif
#endif
[plain] view plain copy
Filename: ioCC254x_bitdef.h
This file contains the bit definitions of registers in CC254x.
Note: The USB and Radio bit defintions are in seperate headers.
Copyright 2012 Texas Instruments, Inc.
#ifndef _IOCC254X_BITDEF_H
#define _IOCC254X_BITDEF_H
// BIT definitions.
#define BIT7 0x80
#define BIT6 0x40
#define BIT5 0x20
#define BIT4 0x10
#define BIT3 0x08
#define BIT2 0x04
#define BIT1 0x02
#define BIT0 0x01
* Memory Control Registers
// MPAGE (0x93) - Memory Page Select
// MEMCTR (0xC7) - Memory Arbiter Control
#define MEMCTR_XMAP 0x08 // Maps SRAM into the CODE Memory Space, enables code execution from RAM.
// DPH0 (0x83) ?Data Pointer-0 High Byte
// DPL0 (0x82) ?Data Pointer-0 Low Byte
// DPH1 (0x85) ?Data Pointer-1 High Byte
// DPL1 (0x84) ?Data Pointer-1 Low Byte
// DPS (0x92) ?Data-Pointer Select
#define DPS_DPS 0x01 // Data pointer selection, DPTR1 when set, DPTR0 when cleared.
// PSW (0xD0) ?Program Status Word
// ACC (0xE0) ?Accumulator
// B (0xF0) ?B Register
// SP (0x81) ?Stack Pointer
* Interrupt Control Registers
// IEN0 (0xA8) - Interrupt Enable 0 Register - bit accessible SFR register
// IEN1 (0xB8) - Interrupt Enable 1 Register - bit accessible SFR register
#define IEN1_P0IE 0x20 // Port 0 interrupt enable
#define IEN1_T4IE 0x10 // Timer 4 interrupt enable
#define IEN1_T3IE 0x08 // Timer 3 interrupt enable
#define IEN1_T2IE 0x04 // Timer 2 interrupt enable
#define IEN1_T1IE 0x02 // Timer 1 interrupt enable
#define IEN1_DMAIE 0x01 // DMA transfer interrupt enable
// IEN2 (0x9A) - Interrupt Enable 2 Register
#define IEN2_WDTIE 0x20
#define IEN2_P1IE 0x10
#if (chip == 2541)
#define IEN2_UTX1IE 0x08 // USART 1 TX interrupt enable
#elif (chip == 2543 || chip == 2545) // The chip is defined in the project options.
#define IEN2_I2CIE 0x08 // (not applicable on CC2544)
#endif
#define IEN2_UTX0IE 0x04
#define IEN2_P2IE 0x02
#define IEN2_USBIE 0x02
#define IEN2_RFIE 0x01
// TCON (0x88) - CPU Interrupt Flag 1 - bit accessible SFR register
// S0CON (0x98) - CPU Interrupt Flag 2 - bit accessible SFR register
// S1CON (0x9B) - CPU Interrupt Flag 3
#define S1CON_RFIF_1 0x02
#define S1CON_RFIF_0 0x01
// IRCON (0xC0) - CPU Interrupt Flag 4 - bit accessible SFR register
// IRCON2 (0xE8) - CPU Interrupt Flag 5 - bit accessible SFR register
// IP1 (0xB9) - Interrupt Priority 1
#define IP1_IPG5 0x20
#define IP1_IPG4 0x10
#define IP1_IPG3 0x08
#define IP1_IPG2 0x04
#define IP1_IPG1 0x02
#define IP1_IPG0 0x01
// IP0 (0xA9) - Interrupt Priority 0
#define IP0_IPG5 0x20
#define IP0_IPG4 0x10
#define IP0_IPG3 0x08
#define IP0_IPG2 0x04
#define IP0_IPG1 0x02
#define IP0_IPG0 0x01
* Power Management and Clocks
// SRCRC (0x6262) ?Sleep Reset CRC (not available on the CC2544)
#define SRCRC_FORCE_RESET 0x20 // Force watchdog reset
#define SRCRC_CRC_RESULT (0x03 << 2) // CRC value, bit mask
#define SRCRC_CRC_RESULT_PASS (0x00 << 2) // CRC of retained registers passed
#define SRCRC_CRC_RESULT_LOW (0x01 << 2) // Low CRC value failed
#define SRCRC_CRC_RESULT_HIGH (0x02 << 2) // High CRC value failed
#define SRCRC_CRC_RESULT_BOTH (0x03 << 2) // Both CRC values failed
#define SRCRC_CRC_RESET_EN 0x01 // CRC != 00 reset enable, after wakeup from PM2/PM3.
// PCON (0x87) - Power Mode Control
#define PCON_IDLE 0x01
// SLEEPCMD (0xBE) - Sleep Mode Control
#define OSC32K_CALDIS 0x80
#define SLEEPCMD_MODE (0x03) // Power mode bit mask
#define SLEEPCMD_MODE_IDLE (0x00)
#define SLEEPCMD_MODE_PM1 (0x01)
#if (chip == 2541 || chip == 2543 || chip == 2545) // (not applicable on CC2544)
#define SLEEPCMD_MODE_PM2 (0x02)
#define SLEEPCMD_MODE_PM3 (0x03)
#endif
// SLEEPSTA (0x9D) ?Sleep-Mode Control Status
#define SLEEPSTA_CLK32K_CALDIS 0x80 // Calibration disable status
#define SLEEPSTA_RST (0x03 << 3) // Cause of last reset, bit mask
#define SLEEPSTA_RST_POR_BOD (0x00 << 3) // Power-on reset, or brownout detection
#define SLEEPSTA_RST_EXT (0x01 << 3) // External reset
#define SLEEPSTA_RST_WDT (0x02 << 3) // Watchdog Timer reset
#define SLEEPSTA_RST_CLK_LOSS (0x03 << 3) // Clock loss reset
#define SLEEPSTA_CLK32K 0x01 // 32 kHz clock signal
// STLOAD (0xAD) ?Sleep Timer Load Status
#define STLOAD_LDRDY 0x01
// CLKCONCMD (0xC6) ?Clock Control Command
// and CLKCONSTA (0x9E) ?Clock Control Status
#define CLKCON_OSC32K 0x80 // 32 kHz clock source select/status
#define CLKCON_OSC 0x40 // system clock source select/status
#define CLKCON_TICKSPD (0x07 << 3) // bit mask, global timer tick speed divider
#define CLKCON_TICKSPD_32M (0x00 << 3)
#define CLKCON_TICKSPD_16M (0x01 << 3)
#define CLKCON_TICKSPD_8M (0x02 << 3)
#define CLKCON_TICKSPD_4M (0x03 << 3)
#define CLKCON_TICKSPD_2M (0x04 << 3)
#define CLKCON_TICKSPD_1M (0x05 << 3)
#define CLKCON_TICKSPD_500K (0x06 << 3)
#define CLKCON_TICKSPD_250K (0x07 << 3)
#define CLKCON_CLKSPD (0x07) // bit mask for the clock speed division
#define CLKCON_CLKSPD_32M (0x00)
#define CLKCON_CLKSPD_16M (0x01)
#define CLKCON_CLKSPD_8M (0x02)
#define CLKCON_CLKSPD_4M (0x03)
#define CLKCON_CLKSPD_2M (0x04)
#define CLKCON_CLKSPD_1M (0x05)
#define CLKCON_CLKSPD_500K (0x06)
#define CLKCON_CLKSPD_250K (0x07)
// CLD (0x6290) ?Clock-Loss Detection
#define CLD_EN 0x01 // Clock-loss detector enable
* Flash Controller
// FCTL (0x6270) - Flash Control
#define FCTL_BUSY 0x80
#define FCTL_FULL 0x40
#define FCTL_ABORT 0x20
#define FCTL_CM (0x03 << 2) // cache mode bit mask
#define FCTL_CM_DIS (0x00 << 2) // cache mode disabled
#define FCTL_CM_EN (0x01 << 2) // cache mode enabled
#define FCTL_CM_PREFETCH (0x02 << 2) // cache mode enabled, prefetch mode
#define FCTL_CM_REALTIME (0x03 << 2) // cache mode enabled, real-time mode
#define FCTL_WRITE 0x02
#define FCTL_ERASE 0x01
// FWDATA (0xAF) - Flash Write Data
// FADDRH (0xAD) - Flash Address High Byte
// FADDRL (0xAC) - Flash Address Low Byte
* I/O Ports
// *************************** CC2541 ********************************
#if (chip == 2541)
// P0 (0x80) - Port 0 - bit accessible SFR register
// P1 (0x90) - Port 1 - bit accessible SFR register
// P2 (0xA0) - Port 2 - bit accessible SFR register
// PERCFG (0xF1) - Peripheral Control
#define PERCFG_T1CFG 0x40 // Timer 1 I/O location
#define PERCFG_T3CFG 0x20 // Timer 3 I/O location
#define PERCFG_T4CFG 0x10 // Timer 4 I/O location
#define PERCFG_U1CFG 0x02 // USART 1 I/O location
#define PERCFG_U0CFG 0x01 // USART 0 I/O location
#define PERCFG_U0CFG_ALT1 0x00 // Alternative 1 location
#define PERCFG_U0CFG_ALT2 0x01 // Alternative 2 location
// APCFG (0xF2) - Analog Peripheral I/O Configuration
#define APCFG_APCFG7 0x80 // When set, analog I/O on P0_7 is enabled
#define APCFG_APCFG6 0x40
#define APCFG_APCFG5 0x20
#define APCFG_APCFG4 0x10
#define APCFG_APCFG3 0x08
#define APCFG_APCFG2 0x04
#define APCFG_APCFG1 0x02
#define APCFG_APCFG0 0x01
// P0SEL (0xF3) ?P0 Function Select
#define P0SEL_SELP0_7 0x80 // Pin function as peripheral I/O when set
#define P0SEL_SELP0_6 0x40
#define P0SEL_SELP0_5 0x20
#define P0SEL_SELP0_4 0x10
#define P0SEL_SELP0_3 0x08
#define P0SEL_SELP0_2 0x04
#define P0SEL_SELP0_1 0x02
#define P0SEL_SELP0_0 0x01
// P1SEL (0xF4) ?P1 Function Select
#define P1SEL_SELP1_7 0x80 // Pin function as peripheral I/O when set
#define P1SEL_SELP1_6 0x40
#define P1SEL_SELP1_5 0x20
#define P1SEL_SELP1_4 0x10
#define P1SEL_SELP1_3 0x08
#define P1SEL_SELP1_2 0x04
#define P1SEL_SELP1_1 0x02
#define P1SEL_SELP1_0 0x01
// P2SEL (0xF5) ?Port 2 Function Select and Port 1 Peripheral Priority Control
#define P2SEL_PRI3P1 0x40 // When set USART 1 has priotity over USART 0.
#define P2SEL_PRI2P1 0x20 // When set Timer 3 has priotity over USART 1.
#define P2SEL_PRI1P1 0x10 // When set Timer 4 has priotity over Timer 1.
#define P2SEL_PRI0P1 0x08 // When set Timer 1 has priotity over USART 0.
#define P2SEL_SELP2_4 0x04 // P2.4 function select
#define P2SEL_SELP2_3 0x02 // P2.3 function select
#define P2SEL_SELP2_0 0x01 // P2.0 function select
// P1INP (0xF6) ?Port 1 Input Mode
#define P1INP_MDP1 0xFC // P1.7 to P1.2 I/O input mode bit mask
#define P1INP_MDP1_P1_7 0x80 // When set P1.7 is 3-state, when not set pullup or pulldown (set in P2INP)
#define P1INP_MDP1_P1_6 0x40 // When set P1.6 is 3-state, when not set pullup or pulldown (set in P2INP)
#define P1INP_MDP1_P1_5 0x20 // When set P1.5 is 3-state, when not set pullup or pulldown (set in P2INP)
#define P1INP_MDP1_P1_4 0x10 // When set P1.4 is 3-state, when not set pullup or pulldown (set in P2INP)
#define P1INP_MDP1_P1_3 0x08 // When set P1.3 is 3-state, when not set pullup or pulldown (set in P2INP)
#define P1INP_MDP1_P1_2 0x04 // When set P1.2 is 3-state, when not set pullup or pulldown (set in P2INP)
// P2INP (0xF7) ?Port 1 Input Mode
#define P2INP_PDUP2 0x80 // Port 2 pullup/pulldown select. 1 - pulldown, 0- pullup.
#define P2INP_PDUP1 0x40 // Port 1 pullup/pulldown select. 1 - pulldown, 0- pullup.
#define P2INP_PDUP0 0x20 // Port 0 pullup/pulldown select. 1 - pulldown, 0- pullup.
#define P2INP_MDP2 0x1F // P2.4 to P2.0 I/O input mode bit mask.
#define P2INP_MDP2_P2_4 0x10 // P2.4 pullup/pulldown select. 1 - pulldown, 0- pullup.
#define P2INP_MDP2_P2_3 0x10 // P2.3 pullup/pulldown select. 1 - pulldown, 0- pullup.
#define P2INP_MDP2_P2_2 0x10 // P2.2 pullup/pulldown select. 1 - pulldown, 0- pullup.
#define P2INP_MDP2_P2_1 0x10 // P2.1 pullup/pulldown select. 1 - pulldown, 0- pullup.
#define P2INP_MDP2_P2_0 0x10 // P2.0 pullup/pulldown select. 1 - pulldown, 0- pullup.
// P0IFG (0x89) ?Port 0 Interrupt Status Flag
// P1IFG (0x8A) ?Port 1 Interrupt Status Flag
// P0DIR (0xFD) ?Port 0 Direction Control ( P0.7 to P0.0 ).
// P1DIR (0xFE) ?Port 1 Direction Control ( P1.7 to P1.0 ).
// P2DIR (0xFF) ?Port 2 Direction and Port 0 Peripheral Priority Control
#define P2DIR_PRIP0 0xC0 // Port 0 peripheral priority control.
#define P2DIR_PRIP0_USART0 (0x00 << 6) // USART 0 has priority, then USART 1, then Timer 1
#define P2DIR_PRIP0_USART1 (0x01 << 6) // USART 1 has priority, then USART 0, then Timer 1
#define P2DIR_PRIP0_T1_0_1 (0x02 << 6) // Timer 1 channels 0-1 has priority, then USART 1, then USART 0, then Timer 1 channels 2-3
#define P2DIR_PRIP0_T1_2_3 (0x03 << 6) // Timer 1 channels 2-3 has priority, then USART 0, then USART 1, then Timer 1 channels 0-1
#define P2DIR_DIRP2 0x1F // P2.4 to P2.0 I/O direction
// P0INP (0x8F) ?Port 0 Input Mode
// P2INP (0xF7) ?Port 2 Input Mode
#define P2INP_PDUP2 0x80 // Port 2 pullup/pulldown select. When set high -> Pullup.
#define P2INP_PDUP1 0x40 // Port 1 pullup/pulldown select. When set high -> Pullup.
#define P2INP_PDUP0 0x20 // Port 0 pullup/pulldown select. When set high -> Pullup.
#define P2INP_MDP2 0x1F // P2.4 to P2.0 I/O input mode. When set high -> 3-state.
// P2IFG (0x8B) ?Port 2 Interrupt Status Flag
// PICTL (0x8C) - Port Interrupt Control
#define PICTL_padsC 0x80 // Drive strength control for I/O pins in output mode.
#define PICTL_P2ICON 0x08 // Port 2, inputs 4 to 0 interrupt configuration. Interrupt on falling edge when set, rising edge when cleared.
#define PICTL_P1ICONH 0x04 // Port 1, inputs 7 to 4 interrupt configuration. Interrupt configuration. Interrupt on falling edge when set, rising edge when cleared.
#define PICTL_P1ICONL 0x02 // Port 1, inputs 3 to 0 interrupt configuration. Interrupt on falling edge when set, rising edge when cleared.
#define PICTL_P0ICON 0x01 // Port 0, inputs 7 to 0 interrupt configuration. Interrupt on falling edge when set, rising edge when cleared.
// P0IEN (0xAB) ?Port 0 Interrupt Mask
// P1IEN (0x8D) ?Port 1 Interrupt Mask
// P2IEN (0xAC) ?Port 2 Interrupt Mask
// PMUX (0xAE) ?Power-Down Signal Mux
#define PMUX_CKOEN 0x80 // Clock out enable, the 32 kHz clock.
#define PMUX_CKOPIN (0x07 << 4) // Selects which pin on Port 0, bit mask.
#define PMUX_DREGSTA 0x04 // Digital Regulator Status output enable.
#define PMUX_DREGSTAPIN (0x07) // Selects which pin on Port 1, bit mask.
// OBSSEL0 (0x6243) ?Observation output control register 0
// OBSSEL1 (0x6244) ?Observation output control register 1
// OBSSEL2 (0x6245) ?Observation output control register 2
// OBSSEL3 (0x6246) ?Observation output control register 3
// OBSSEL4 (0x6247) ?Observation output control register 4
// OBSSEL5 (0x6248) ?Observation output control register 5
// *************************** CC2543 ********************************
#elif (chip == 2543)
#define PERCFG_PRI0P2 (0x03 << 6) // Port 2 peripheral priority control bit mask
#define PERCFG_PRI0P2_USART0 (0x00 << 6) // USART0 has priority, then Timer 1, then Timer 4
#define PERCFG_PRI0P2_T1 (0x01 << 6) // Timer 1 has priority, then Timer 4, then USART0
#define PERCFG_PRI0P2_T4 (0x02 << 6) // Timer 4 has priority, then Timer 1, then USART0
#define PERCFG_T1CFG 0x20
#define PERCFG_T3CFG 0x10
#define PERCFG_T4CFG 0x08
#define PERCFG_I2CCFG 0x04
#define PERCFG_U0CFG (0x03) // USART0 I/O location bit mask
#define PERCFG_U0CFG_ALT1 (0x00) // Alternative 1 location
#define PERCFG_U0CFG_ALT2 (0x01) // Alternative 2 location
#define PERCFG_U0CFG_ALT3 (0x02) // Alternative 3 location
#define P1SEL_SELP1_4 0x10 // Pin function as peripheral I/O when set
// P2SEL (0xF5) ?P2 Function Select
#define P2SEL_SELP2_2 0x04 // Pin function as peripheral I/O when set
#define P2SEL_SELP2_1 0x02
// PPRI (0xFB) - Peripheral Priority Setup
#define PPRI_PRI_P1_2 0x80 // Port 1 pin 2. When set Timer 3 has priotity over Timer 1
#define PPRI_PRI_P1_1 (0x03 << 5) // Port 1 pin 1. Peripheral priority bit mask
#define PPRI_PRI_P1_1_T1 (0x00 << 5) // Timer 1 has priority, then Timer 3, then Timer 4
#define PPRI_PRI_P1_1_T3 (0x01 << 5) // Timer 3 has priority, then Timer 1, then Timer 4
#define PPRI_PRI_P1_1_T4 (0x02 << 5) // Timer 4 has priority, then Timer 1, then Timer 3
#define PPRI_PRI_P1_0 (0x03 << 3) // Port 1 pin 0. Peripheral priority bit mask
#define PPRI_PRI_P1_0_T1 (0x00 << 3) // Timer 1 has priority, then Timer 3, then Timer 4
#define PPRI_PRI_P1_0_T3 (0x01 << 3) // Timer 3 has priority, then Timer 1, then Timer 4
#define PPRI_PRI_P1_0_T4 (0x02 << 3) // Timer 4 has priority, then Timer 1, then Timer 3
#define PPRI_PRI0P1 0x04 // Port 1. When set Timer 1 has priority over USART0
#define PPRI_PRI1P0 0x02 // Port 0. When set Timer 1 has priority over I2C
#define PPRI_PRI0P0 0x01 // Port 0. When set Timer 1 has priority over USART0
// P2DIR (0xFF) ?Port 2 Direction Control
// PPULL (0xF8) ?Port Pullup/Pulldown Control
#define PPULL_PDUP2L 0x10 // P2_[2:0] pull direction, when set pulls down
#define PPULL_PDUP1H 0x08 // P1_4 pull direction
#define PPULL_PDUP1L 0x04 // P1_[3:0] pull direction
#define PPULL_PDUP0H 0x02 // P0_[7:4] pull direction
#define PPULL_PDUP0L 0x01 // P0_[3:0] pull direction
#define PICTL_PADSC 0x40 // Drive strength
#define PICTL_P2ICONL 0x10 // P2_[2:0] interrupt on falling edge when set, rising edge when cleared.
#define PICTL_P1ICONH 0x08 // P1_4
#define PICTL_P1ICONL 0x04 // P1_[3:0]
#define PICTL_P0ICONH 0x02 // P0_[7:4]
#define PICTL_P0ICONL 0x01 // P0_[3:0]
// *************************** CC2544 ********************************
#elif (chip == 2544)
// P0 (0x80) ?Port 0
// P1 (0x90) ?Port 1
// P0SEL0 (0xF3) ?P0 Function Select
#define P0SEL0_SELP0_1 0xF0
#define P0SEL0_SELP0_0 0x0F
// P0SEL1 (0xF4) ?P0 Function Select
#define P0SEL1_SELP0_3 0xF0
#define P0SEL1_SELP0_2 0x0F
// P1SEL0 (0xF5) ?P1 Function Select
#define P1SEL0_SELP1_1 0xF0
#define P1SEL0_SELP1_0 0x0F
// P1SEL1 (0xF6) ?P1 Function Select
#define P1SEL1_SELP1_3 0xF0
#define P1SEL1_SELP1_2 0x0F
// PDIR (0xFD) ?Port Direction Control
#define PDIR_DIRP1_3 0x80
#define PDIR_DIRP1_2 0x40
#define PDIR_DIRP1_1 0x20
#define PDIR_DIRP1_0 0x10
#define PDIR_DIRP0_3 0x08
#define PDIR_DIRP0_2 0x04
#define PDIR_DIRP0_1 0x02
#define PDIR_DIRP0_0 0x01
// PINP (0x8F) ?Port Input Mode
#define PINP_MDP1_3 0x80
#define PINP_MDP1_2 0x40
#define PINP_MDP0_3 0x08
#define PINP_MDP0_2 0x04
#define PINP_MDP0_1 0x02
#define PINP_MDP0_0 0x01
// PPULL (0xF7) ?Port Pullup/Pulldown Control
#define PPULL_PDUP1_3 0x80
#define PPULL_PDUP1_2 0x40
#define PPULL_PADSC 0x20
#define PPULL_PDUP0_3 0x08
#define PPULL_PDUP0_2 0x04
#define PPULL_PDUP0_1 0x02
#define PPULL_PDUP0_0 0x01
// P2IFG (0x8B) ?USB D+ Interrupt Status Flag
#define PICTL_P1ICON_3 0x80
#define PICTL_P1ICON_2 0x40
#define PICTL_P1ICON_1 0x20
#define PICTL_P1ICON_0 0x10
#define PICTL_P0ICON_3 0x08
#define PICTL_P0ICON_2 0x04
#define PICTL_P0ICON_1 0x02
#define PICTL_P0ICON_0 0x01
// P0IEN (0xAB) ?Port 0 Interrupt mask
// P1IEN (0x8D) ?Port 1 Interrupt mask
// P2IEN (0xAC) ?USB D+ Interrupt mask
// *************************** CC2545 ********************************
#elif (chip == 2545)
// P3 (0xB0) ?Port 3 - bit accessible SFR register
#define P1SEL_SELP1_6 0x40 // Pin function as peripheral I/O when set
// P2SEL (0xF3) ?P0 Function Select
#define P2SEL_SELP2_7 0x80 // Pin function as peripheral I/O when set
#define P2SEL_SELP2_6 0x40
#define P2SEL_SELP2_5 0x20
#define P2SEL_SELP2_4 0x10
#define P2SEL_SELP2_3 0x08
#define PPRI_OBSLOC 0x40 // When set OBSSEL at P3[5:0] has priority OBSSEL at P1[5:0].
#define PPRI_PRI0P2 0x20 // Port 2 peripheral priority control. When set Timer4 has priority over Timer1.
#define PPRI_PRI1P1 0x18 // Port 1 peripheral priority control.
#define PPRI_PRI1P1_USART (0x00 << 3) // USART0 has priority, then Timer3, then I2C.
#define PPRI_PRI1P1_T3 (0x01 << 3) // Timer3 has priority, then USART0, then I2C.
#define PPRI_PRI1P1_I2C (0x10 << 3) // I2C has priority, then USART0, then Timer3.
#define PPRI_PRI0P1 0x04 // Port 1 peripheral priority control. When set Timer4 has priority over Timer1.
// P3DIR (0xF9) ?Port 3 Direction Control
// P3INP (0xFA) ?Port 3 Input Mode
#define PPULL_PDUP3H 0x80
#define PPULL_PDUP3L 0x40
#define PPULL_PDUP2H 0x20
#define PICTL_P2ICONH 0x20
#define PICTL_P2ICONL 0x10 // interrupt on falling edge when set, rising edge when cleared.
#endif
* DMA Controller
// DMAARM (0xD6) - DMA Channel Arm
#define DMAARM_ABORT 0x80
#define DMAARM_DMAARM1 0x02
#define DMAARM_DMAARM0 0x01
// DMAREQ (0xD7) - DMA Channel Start Request and Status
#define DMAREQ_DMAREQ1 0x02
#define DMAREQ_DMAREQ0 0x01
// DMA0CFGH (0xD5) - DMA Channel 0 Configuration Address High Byte
// DMA0CFGL (0xD4) - DMA Channel 0 Configuration Address Low Byte
// DMA1CFGH (0xD3) - DMA Channel 1 - 4 Configuration Address High Byte
// DMA1CFGL (0xD2) - DMA Channel 1 - 4 Configuration Address Low Byte
// DMAIRQ (0xD1) - DMA Interrupt Flag
#define DMAIRQ_DMAIF1 0x02
#define DMAIRQ_DMAIF0 0x01
* Timers
// ************************* TIMER 1 *************************
// T1CNTH (0xE3) ?Timer 1 Counter High
// T1CNTL (0xE2) ?Timer 1 Counter Low
// T1CTL (0xE4) - Timer 1 Control and Status
#define T1CTL_DIV (0x0C) // Bit mask, Timer 1 tick speed divider
#define T1CTL_DIV_1 (0x00 << 2) // Divide tick frequency by 1
#define T1CTL_DIV_8 (0x01 << 2) // Divide tick frequency by 8
#define T1CTL_DIV_32 (0x02 << 2) // Divide tick frequency by 32
#define T1CTL_DIV_128 (0x03 << 2) // Divide tick frequency by 128
#define T1CTL_MODE (0x03) // Timer 1 mode select. The timer operating mode is selected as follows:
#define T1CTL_MODE_SUSPEND (0x00) // Operation is suspended.
#define T1CTL_MODE_FREERUN (0x01) // Free-running, repeatedly count from 0x0000 to 0xFFFF.
#define T1CTL_MODE_MODULO (0x02) // Modulo, repeatedly count from 0x0000 to T1CC0.
#define T1CTL_MODE_UPDOWN (0x03) // Up/down, repeatedly count from 0x0000 to T1CC0 and from T1CC0 down to 0x0000.
// T1STAT (0xAF) - Timer 1 Status
#define T1STAT_OVFIF 0x20 // Overflow interrupt flag
#define T1STAT_CH4IF 0x10 // Overflow interrupt flag
#define T1STAT_CH3IF 0x08 // Overflow interrupt flag
#define T1STAT_CH2IF 0x04 // Overflow interrupt flag
#define T1STAT_CH1IF 0x02 // Overflow interrupt flag
#define T1STAT_CH0IF 0x01 // Overflow interrupt flag
// T1CCTL0 (0xE5) - Timer 1 Channel n Capture/Compare Control
#define T1CCTLn_RFIRQ 0x80 // When set, use RF interrupt for capture instead of regular capture input.
#define T1CCTLn_IM 0x40 // Interrupt mask. Enables interrupt request when set.
#define T1CCTLn_CMP (0x07 << 3) // Compare-mode bit mask.
#define T1CCTLn_CMP_SET_ON_CMP (0x00 << 3) // Set output on compare.
#define T1CCTLn_CMP_CLR_ON_CMP (0x01 << 3) // Clear output on compare.
#define T1CCTLn_CMP_TOG_ON_CMP (0x02 << 3) // Toggle output on compare.
#define T1CCTLn_CMP_SET_CMP_UP_CLR_0 (0x03 << 3) // Set output on compare-up, clear on 0.
#define T1CCTLn_CMP_CLR_CMP_UP_SET_0 (0x04 << 3) // Clear output on compare-up, set on 0.
#define T1CCTLn_CMP_CLR_T1CC0_SET_T1CC1 (0x05 << 3) // Clear when equal T1CC0, set when equal T1CC1. Not applicable for ch0.
#define T1CCTLn_CMP_SET_T1CC0_CLR_T1CC1 (0x06 << 3) // Set when equal T1CC0, clear when equal T1CC1. Not applicable for ch0.
#define T1CCTLn_CMP_INIT_PIN (0x07 << 3) // Initialize output pin, CMP mode is not changed.
#define T1CCTLn_MODE 0x04 // Compare mode when set, capture mode when cleared
#define T1CCTLn_CAP (0x03) // Capture mode bit mask
#define T1CCTLn_CAP_NO_CAP (0x00) // No capture
#define T1CCTLn_CAP_RISE_EDGE (0x01) // Capture on rising edge
#define T1CCTLn_CAP_FALL_EDGE (0x02) // Capture on falling edge
#define T1CCTLn_CAP_BOTH_EDGE (0x03) // Capture on both edges
// T1CC0H (0xDB) ?Timer 1 Channel 0 Capture/Compare Value, High
// T1CC0L (0xDA) ?Timer 1 Channel 0 Capture/Compare Value, Low
// T1CCTL1 (0xE6) - Timer 1 Channel 1 Capture/Compare Control
// See T1CCTL0
// T1CC1H (0xDD) ?Timer 1 Channel 1 Capture/Compare Value, High
// T1CC1L (0xDC) ?Timer 1 Channel 1 Capture/Compare Value, Low
// T1CCTL2 (0xE7) - Timer 1 Channel 2 Capture/Compare Control
// See T1CCTL0
// T1CC2H (0xDF) ?Timer 1 Channel 2 Capture/Compare Value, High
// T1CC2L (0xDE) ?Timer 1 Channel 2 Capture/Compare Value, Low
// T1CCTL3 (0x62A3) - Timer 1 Channel 3 Capture/Compare Control
// See T1CCTL0
// T1CC3H (0x62AD) ?Timer 1 Channel 3 Capture/Compare Value, High
// T1CC3L (0x62AC) ?Timer 1 Channel 3 Capture/Compare Value, Low
// T1CCTL4 (0x62A4) - Timer 1 Channel 4 Capture/Compare Control
// See T1CCTL0
// T1CC4H (0x62AF) ?Timer 1 Channel 4 Capture/Compare Value, High
// T1CC4L (0x62AE) ?Timer 1 Channel 4 Capture/Compare Value, Low
// IRCTL (0x6281) ?Timer 1 IR Generation Control
#define IRCTL_IRGEN 0x01 // Used in conjuction with Timer 3 to generate modulated IR codes, see the User's Guide.
// ************************* TIMER 2 *************************
// T2MSEL (0xC3) ?Timer 2 Multiplex Select
// T2M0 (0xA2) ?Timer 2 Multiplexed Register 0
// T2M1 (0xA3) ?Timer 2 Multiplexed Register 1
// T2MOVF0 (0xA4) ?Timer 2 Multiplexed Overflow Register 0
// T2MOVF1 (0xA5 ?Timer 2 Multiplexed Overflow Register 2
// T2MOVF2 (0xA6) ?Timer 2 Multiplexed Overflow Register 2
// T2IRQF (0xA1) ?Timer 2 Interrupt Flags
#define T2IRQF_LONG_COMPARE2F 0x80
#define T2IRQF_LONG_COMPARE1F 0x40
#define T2IRQF_OVF_COMPARE2F 0x20
#define T2IRQF_OVF_COMPARE1F 0x10
#define T2IRQF_OVF_PERF 0x08
#define T2IRQF_COMPARE2F 0x04
#define T2IRQF_COMPARE1F 0x02
#define T2IRQF_PERF 0x01
// T2IRQM (0xA7) ?Timer 2 Interrupt Mask
#define T2IRQM_LONG_COMARE2M 0x80
#define T2IRQM_LONG_COMARE1M 0x40
#define T2IRQM_OVF_COMPARE2M 0x20
#define T2IRQM_OVF_COMPARE1M 0x10
#define T2IRQM_OVF_PERM 0x08
#define T2IRQM_COMPARE2M 0x04
#define T2IRQM_COMPARE1M 0x02
#define T2IRQM_PERM 0x01
// T2CTRL (0x94) ?Timer 2 Control Register
#define T2CTRL_LATCH_MODE 0x08
#define T2CTRL_STATE 0x04 // State of Timer 2
#if (chip == 2545)
#define T2CTRL_SYNC 0x02 // Syncronized start/stop with LS RCOSC when set.
#endif
#define T2CTRL_RUN 0x01 // Start/stop timer, starts when set, stops when cleared.
// T2EVTCFG (0x9C) ?Timer 2 Event Configuration
// ************************* TIMER 3 *************************
// T3CNT (0xCA) - Timer 3 Counter
// T3CTL (0xCB) - Timer 3 Control
#define T3CTL_DIV (0xE0)
#define T3CTL_DIV_1 (0x00 << 5)
#define T3CTL_DIV_2 (0x01 << 5)
#define T3CTL_DIV_4 (0x02 << 5)
#define T3CTL_DIV_8 (0x03 << 5)
#define T3CTL_DIV_16 (0x04 << 5)
#define T3CTL_DIV_32 (0x05 << 5)
#define T3CTL_DIV_64 (0x06 << 5)
#define T3CTL_DIV_128 (0x07 << 5)
#define T3CTL_START 0x10
#define T3CTL_OVFIM 0x08
#define T3CTL_CLR 0x04
#define T3CTL_MODE (0x03)
#define T3CTL_MODE_FREERUN (0x00)
#define T3CTL_MODE_DOWN (0x01)
#define T3CTL_MODE_MODULO (0x02)
#define T3CTL_MODE_UPDOWN (0x03)
// T3CCTL0 (0xCC) - Timer 3 Channel 0 Compare Control
#define T3CCTLn_IM 0x40
#define T3CCTLn_CMP (0x07 << 3) // Compare mode bit mask.
#define T3CCTLn_CMP_SET_ON_CMP (0x00 << 3) // Set output on compare.
#define T3CCTLn_CMP_CLR_ON_CMP (0x01 << 3) // Clear output on compare.
#define T3CCTLn_CMP_TOG_ON_CMP (0x02 << 3) // Toggle output on compare.
#define T3CCTLn_CMP_SET_CMP_UP_CLR_0 (0x03 << 3) // Set output on compare-up, clear on 0.
#define T3CCTLn_CMP_CLR_CMP_UP_SET_0 (0x04 << 3) // Clear output on compare-up, set on 0.
#define T3CCTLn_CMP_SET_CMP_CLR_0xFF (0x05 << 3) // Set output on compare, clear on 0xFF
#define T3CCTLn_CMP_CLR_CMP_SET_0x00 (0x06 << 3) // Clear output on compare, set on 0x00
#define T3CCTLn_CMP_INIT_PIN (0x07 << 3) // Initialize output pin, CMP mode is not changed.
#define T3CCTLn_MODE 0x04
#define T3CCTLn_CAP (0x03) // Capture mode bit mask
#define T3CCTLn_CAP_NO_CAP (0x00) // No capture
#define T3CCTLn_CAP_RISE_EDGE (0x01) // Capture on rising edge
#define T3CCTLn_CAP_FALL_EDGE (0x02) // Capture on falling edge
#define T3CCTLn_CAP_BOTH_EDGE (0x03) // Capture on both edges
// T3CC0 (0xCD) - Timer 3 Channel 0 Capture/Compare Value
// T3CCTL1 (0xCE) - Timer 3 Channel 1 Compare Control
// See T3CCTL0
// T3CC1 (0xCF) - Timer 3 Channel 1 Capture/Compare Value
// ************************* TIMER 4 *************************
// T4CNT (0xEA) - Timer 4 Counter
// T4CTL (0xEB) - Timer 4 Control
#define T4CTL_DIV (0xE0)
#define T4CTL_DIV_1 (0x00 << 5)
#define T4CTL_DIV_2 (0x01 << 5)
#define T4CTL_DIV_4 (0x02 << 5)
#define T4CTL_DIV_8 (0x03 << 5)
#define T4CTL_DIV_16 (0x04 << 5)
#define T4CTL_DIV_32 (0x05 << 5)
#define T4CTL_DIV_64 (0x06 << 5)
#define T4CTL_DIV_128 (0x07 << 5)
#define T4CTL_START 0x10
#define T4CTL_OVFIM 0x08
#define T4CTL_CLR 0x04
#define T4CTL_MODE (0x03)
#define T4CTL_MODE_FREERUN (0x00)
#define T4CTL_MODE_DOWN (0x01)
#define T4CTL_MODE_MODULO (0x02)
#define T4CTL_MODE_UPDOWN (0x03)
// T4CCTL0 (0xEC) - Timer 4 Channel 0 Compare Control
#define T4CCTLn_IM 0x40
#define T4CCTLn_CMP (0x07 << 3) // Compare mode bit mask.
#define T4CCTLn_CMP_SET_ON_CMP (0x00 << 3) // Set output on compare.
#define T4CCTLn_CMP_CLR_ON_CMP (0x01 << 3) // Clear output on compare.
#define T4CCTLn_CMP_TOG_ON_CMP (0x02 << 3) // Toggle output on compare.
#define T4CCTLn_CMP_SET_CMP_UP_CLR_0 (0x03 << 3) // Set output on compare-up, clear on 0.
#define T4CCTLn_CMP_CLR_CMP_UP_SET_0 (0x04 << 3) // Clear output on compare-up, set on 0.
#define T4CCTLn_CMP_SET_CMP_CLR_0xFF (0x05 << 3) // Set output on compare, clear on 0xFF
#define T4CCTLn_CMP_CLR_CMP_SET_0x00 (0x06 << 3) // Clear output on compare, set on 0x00
#define T4CCTLn_CMP_INIT_PIN (0x07 << 3) // Initialize output pin, CMP mode is not changed.
#define T4CCTLn_MODE 0x04
#define T4CCTLn_CAP (0x03) // Capture mode bit mask
#define T4CCTLn_CAP_NO_CAP (0x00) // No capture
#define T4CCTLn_CAP_RISE_EDGE (0x01) // Capture on rising edge
#define T4CCTLn_CAP_FALL_EDGE (0x02) // Capture on falling edge
#define T4CCTLn_CAP_BOTH_EDGE (0x03) // Capture on both edges
// T4CC0 (0xED) - Timer 4 Channel 0 Capture/Compare Value
// T4CCTL1 (0xEE) - Timer 4 Channel 1 Compare Control
// See T4CCTL0
// T4CC1 (0xEF) - Timer 4 Channel 1 Capture/Compare Value
// TIMIF (0xD8) - Timers 1/3/4 Interrupt Mask/Flag - bit accessible SFR register
* ADC
// ADCL (0xBA) - ADC Data Low (only bit 7-4 used)
// ADCH (0xBB) - ADC Data High
// ADCCON1 (0xB4) - ADC Control 1
#define ADCCON1_EOC 0x80
#define ADCCON1_ST 0x40
#define ADCCON1_STSEL (0x03 << 4) // bit mask, ADC start select
#define ADCCON1_STSEL_P2_0 (0x00 << 4) // External trigger on P2.0
#define ADCCON1_STSEL_FULL_SPEED (0x01 << 4) // Do not wait for triggers
#define ADCCON1_STSEL_T1C0_CMP_EVT (0x02 << 4) // Timer 1 ch0 compare event
#define ADCCON1_STSEL_ST (0x03 << 4) // ADCCON1.ST = 1
// ADCCON2 (0xB5) - ADC Control 2
#define ADCCON2_SREF (0x03 << 6) // bit mask, select reference voltage
#define ADCCON2_SREF_1_15V (0x00 << 6) // Internal reference 1.15 V
#define ADCCON2_SREF_P0_7 (0x01 << 6) // External reference on AIN7 pin
#define ADCCON2_SREF_AVDD (0x02 << 6) // AVDD5 pin
#define ADCCON2_SREF_P0_6_P0_7 (0x03 << 6) // External reference on AIN6-AIN7 differential input
#define ADCCON2_SDIV (0x03 << 4) // bit mask, decimation rate
#define ADCCON2_SDIV_64 (0x00 << 4) // 7 bits ENOB
#define ADCCON2_SDIV_128 (0x01 << 4) // 9 bits ENOB
#define ADCCON2_SDIV_256 (0x02 << 4) // 10 bits ENOB
#define ADCCON2_SDIV_512 (0x03 << 4) // 12 bits ENOB
#define ADCCON2_SCH (0x0F) // bit mask, sequence channel select
#define ADCCON2_SCH_AIN0 (0x00) // selects the end of a single input sequence (starts at AIN0)
#define ADCCON2_SCH_AIN1 (0x01)
#define ADCCON2_SCH_AIN2 (0x02)
#define ADCCON2_SCH_AIN3 (0x03)
#define ADCCON2_SCH_AIN4 (0x04)
#define ADCCON2_SCH_AIN5 (0x05)
#define ADCCON2_SCH_AIN6 (0x06)
#define ADCCON2_SCH_AIN7 (0x07)
#define ADCCON2_SCH_AIN0_1 (0x08) // selects the end of a differential input sequence (starts at AIN0-AIN1)
#define ADCCON2_SCH_AIN2_3 (0x09)
#define ADCCON2_SCH_AIN4_5 (0x0A)
#define ADCCON2_SCH_AIN6_7 (0x0B)
#define ADCCON2_SCH_GND (0x0C) // only one conversion is performed
#define ADCCON2_SCH_TEMPR (0x0E) // only one conversion is performed
#define ADCCON2_SCH_VDD_3 (0x0F) // only one conversion is performed
// ADCCON3 (0xB6) - ADC Control 3
#define ADCCON3_EREF 0xC0
#define ADCCON3_EREF_1_25V (0x00 << 6)
#define ADCCON3_EREF_P0_7 (0x01 << 6)
#define ADCCON3_EREF_AVDD (0x02 << 6)
#define ADCCON3_EREF_P0_6_P0_7 (0x03 << 6)
#define ADCCON3_EDIV 0x30
#define ADCCON3_EDIV_64 (0x00 << 4)
#define ADCCON3_EDIV_128 (0x01 << 4)
#define ADCCON3_EDIV_256 (0x02 << 4)
#define ADCCON3_EDIV_512 (0x03 << 4)
#define ADCCON3_ECH 0x0F
#define ADCCON3_ECH_AIN0 (0x00)
#define ADCCON3_ECH_AIN1 (0x01)
#define ADCCON3_ECH_AIN2 (0x02)
#define ADCCON3_ECH_AIN3 (0x03)
#define ADCCON3_ECH_AIN4 (0x04)
#define ADCCON3_ECH_AIN5 (0x05)
#define ADCCON3_ECH_AIN6 (0x06)
#define ADCCON3_ECH_AIN7 (0x07)
#define ADCCON3_ECH_AIN0_1 (0x08)
#define ADCCON3_ECH_AIN2_3 (0x09)
#define ADCCON3_ECH_AIN4_5 (0x0A)
#define ADCCON3_ECH_AIN6_7 (0x0B)
#define ADCCON3_ECH_GND (0x0C)
#define ADCCON3_ECH_TEMPR (0x0E)
#define ADCCON3_ECH_VDD_3 (0x0F)
// TR0 (0x624B) ?Test Register 0
#define TR0_ADCTM 0x01 // Enable temperatur sensor, see datasheet.
// *********************** Analog Comparator *************************
// CMPCTL (0x62D0) ?Analog Comparator Control and Status
#define CMPCTL_EN 0x02 // Comparator enable
#define CMPCTL_OUTPUT 0x01 // The comparator output
#endif
// ADCCON1 (0xB4) - ADC Control 1, also applicable on the CC2544
#define ADCCON1_RCTRL (0x03 << 2) // Random-number generator control, bit mask
#define ADCCON1_RCTRL_COMPLETE (0x00 << 2) // Normal operation (13x unrolling)
#define ADCCON1_RCTRL_LFSR13 (0x01 << 2) // Clock the LFSR once (13x unrolling)
#define ADCCON1_RCTRL_STOP (0x03 << 2) // Random-number generator turned off
// RNDL (0xBC) ?Random-Number-Generator Data, Low Byte
// RNDH (0xBD) ?Random-Number-Generator Data, High Byte
* Watchdog Timer
// WDCTL (0xC9) - Watchdog Timer Control
#define WDCTL_CLR 0xF0
#define WDCTL_CLR0 0x10
#define WDCTL_CLR1 0x20
#define WDCTL_CLR2 0x40
#define WDCTL_CLR3 0x80
#define WDCTL_MODE (0x03 << 2) // Selects mode, bit mask
#define WDCTL_MODE_IDLE (0x00 << 2) // Idle, when in Timer mode
#define WDCTL_MODE_WD (0x02 << 2) // Watchdog mode (when in watchdog mode writing to these bits have no effect.)
#define WDCTL_MODE_TIMER (0x03 << 2) // Timer mode
#define WDCTL_INT (0x03) // Interval select
#define WDCTL_INT_1_SEC (0x00)
#define WDCTL_INT_250_MSEC (0x01)
#define WDCTL_INT_15_MSEC (0x02)
#define WDCTL_INT_2_MSEC (0x03)
* USART
// U0CSR (0x86) - USART 0 Control and Status
#define U0CSR_MODE 0x80
#define U0CSR_RE 0x40
#define U0CSR_SLAVE 0x20
#define U0CSR_FE 0x10
#define U0CSR_ERR 0x08
#define U0CSR_RX_BYTE 0x04
#define U0CSR_TX_BYTE 0x02
#define U0CSR_ACTIVE 0x01
// U0UCR (0xC4) - USART 0 UART Control
#define U0UCR_FLUSH 0x80
#define U0UCR_FLOW 0x40
#define U0UCR_D9 0x20
#define U0UCR_BIT9 0x10
#define U0UCR_PARITY 0x08
#define U0UCR_SPB 0x04
#define U0UCR_STOP 0x02
#define U0UCR_START 0x01
// U0GCR (0xC5) - USART 0 Generic Control
#define U0GCR_CPOL 0x80
#define U0GCR_CPHA 0x40
#define U0GCR_ORDER 0x20
#define U0GCR_BAUD_E 0x1F
#define U0GCR_BAUD_E0 0x01
#define U0GCR_BAUD_E1 0x02
#define U0GCR_BAUD_E2 0x04
#define U0GCR_BAUD_E3 0x08
#define U0GCR_BAUD_E4 0x10
// U0DBUF (0xC1) - USART 0 Receive/Transmit Data Buffer
// U0BAUD (0xC2) - USART 0 Baud Rate Control
* I2C
// I2CCFG (0x6230) ?I2C Control
#define I2CCFG_CR2 0x80 // Clock rate bit 2
#define I2CCFG_ENS1 0x40 // Enable I2C
#define I2CCFG_STA 0x20 // Start condition flag
#define I2CCFG_STO 0x10 // Stop flag
#define I2CCFG_SI 0x08 // Interrupt flag
#define I2CCFG_AA 0x04 // Assert acknowledge flag
#define I2CCFG_CR1 0x02 // Clock rate bit 1
#define I2CCFG_CR0 0x01 // Clock rate bit 0
#define I2CCFG_CR (0x83) // Clock rate bit mask
#define I2CCFG_CR_DIV_256 (0x00) // 123 kHz at 32MHz system clock
#define I2CCFG_CR_DIV_244 (0x01) // 144 kHz at 32MHz system clock
#define I2CCFG_CR_DIV_192 (0x02) // 165 kHz at 32MHz system clock
#define I2CCFG_CR_DIV_160 (0x03) // 197 kHz at 32MHz system clock
#define I2CCFG_CR_DIV_960 (0x80) // 33 kHz at 32MHz system clock
#define I2CCFG_CR_DIV_120 (0x81) // 267 kHz at 32MHz system clock
#define I2CCFG_CR_DIV_60 (0x82) // 533 kHz at 32MHz system clock
// I2CSTAT (0x6231) ?I2C Status
// I2CDATA (0x6232) ?I2C Data
// I2CADDR (0x6233) ?I2C Own Slave Address
#define I2CADDR_GC 0x01 // General-call address acknowledge
#endif
#endif
Copyright 2012 Texas Instruments Incorporated. All rights reserved.
IMPORTANT: Your use of this Software is limited to those specific rights
granted under the terms of a software license agreement between the user
who downloaded the software, his/her employer (which must be your employer)
and Texas Instruments Incorporated (the "License"). You may not use this
Software unless you agree to abide by the terms of the License. The License
limits your use, and you acknowledge, that the Software may not be modified,
copied or distributed unless embedded on a Texas Instruments microcontroller
or used solely and exclusively in conjunction with a Texas Instruments radio
frequency transceiver, which is integrated into your product. Other than for
the foregoing purpose, you may not use, reproduce, copy, prepare derivative
works of, modify, distribute, perform, display or sell this Software and/or
its documentation for any purpose.
YOU FURTHER ACKNOWLEDGE AND AGREE THAT THE SOFTWARE AND DOCUMENTATION ARE
PROVIDED 揂S IS?WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED,
INCLUDING WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY, TITLE,
NON-INFRINGEMENT AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL
TEXAS INSTRUMENTS OR ITS LICENSORS BE LIABLE OR OBLIGATED UNDER CONTRACT,
NEGLIGENCE, STRICT LIABILITY, CONTRIBUTION, BREACH OF WARRANTY, OR OTHER
LEGAL EQUITABLE THEORY ANY DIRECT OR INDIRECT DAMAGES OR EXPENSES
INCLUDING BUT NOT LIMITED TO ANY INCIDENTAL, SPECIAL, INDIRECT, PUNITIVE
OR CONSEQUENTIAL DAMAGES, LOST PROFITS OR LOST DATA, COST OF PROCUREMENT
OF SUBSTITUTE GOODS, TECHNOLOGY, SERVICES, OR ANY CLAIMS BY THIRD PARTIES
(INCLUDING BUT NOT LIMITED TO ANY DEFENSE THEREOF), OR OTHER SIMILAR COSTS.
Should you have any questions regarding your right to use this Software,
contact Texas Instruments Incorporated at www.TI.com.
