General Description
The HV9961 is an average current mode control LED driver IC operating in a constant off-time mode. Unlike HV9910B, this control IC does not produce a peak-to-average error, and therefore greatly improves accuracy, line and load regulation of the LED current without any need for loop compensation or high-side current sensing. The output LED current accuracy is ±3%. The IC is equipped with a current limit comparator for hiccup-mode output short circuit protection. The HV9961 can be powered from an 8.0 - 450V supply. A PWM dimming input is provided that accepts an external control TTL compatible signal. The output current can be programmed by an internal 275mV reference, or controlled externally through a 0 - 1.5V dimming input. HV9961 is pin-to-pin compatible with HV9910B and it can be used as a drop-in replacement for many applications to improve the LED current accuracy and regulation. Features Fast average current control Programmable constant off-time switching Linear dimming input PWM dimming input Output short circuit protection with skip mode Ambient operating temperature -40OC to +125OC Pin-compatible with the HV9910B Applications DC/DC or AC/DC LED driver applications LED backlight driver for LCD displays General purpose constant current source LED signage and displays Architectural and decorative LED lighting LED street lighting |
相关推荐 |
BP86211D 12V/0.5A家用电器方案DEMO资料分析(电路原理图及BOM)
1505 浏览 0 评论
PD诱骗取电芯片_PD_Sink端芯片之XSP05实战应用电路
2515 浏览 1 评论
BLDC、PMSM电机智能栅极驱动芯片之TMC6140知识分享
1260 浏览 0 评论
国产电源芯片DP4054 软硬件兼容TP4054 规格书资料
1726 浏览 0 评论
3534 浏览 3 评论
/9
GMT+8, 2025-12-14 14:20 , Processed in 0.687447 second(s), Total 38, Slave 28 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3218
