关于CC26450的ADC例程
检测电池电量
用下面的代码:这个是基于SmartRF06 和 CC2640 7x7的芯片写的,用的是smartRF06上的light sensor做输入,连的是M3的DIO23. |
| 函数的输入参数是AUX的IO 7, 你就填0x80就行。 |
| 注意,如果用其他尺寸的芯片,IO的配置会不一样,得看一下TRM文档中的IO mapping和AUX的IO mapping. |
#include #include #include #include #include // Will change name to anaif // auxIo, see MUX3 Register (Offset = 3h) [reset = X] // auxIo, sensor controller engine IO, will map to M3's IO automa tilcally // for DIO23, auxIO7, the value should be 80h, 0x80 uint16_t OneShotADC(uint8_t auxIo) { static __root uint16_t retval = 0xABBA; uint32_t turnedOnClocks = 0; // Only turn on clocks that are not already enabled. Not thread-safe, obviously. turnedOnClocks |= AUXWUCClockStatus(AUX_WUC_ADC_CLOCK)?0:AUX_WUC_ADC_CLOCK; turnedOnClocks |= AUXWUCClockStatus(AUX_WUC_ADI_CLOCK)?0:AUX_WUC_ADI_CLOCK; turnedOnClocks |= AUXWUCClockStatus(AUX_WUC_SOC_CLOCK)?0:AUX_WUC_SOC_CLOCK; // Enable clocks and wait for ready AUXWUCClockEnable(turnedOnClocks); while(false == AUXWUCClockStatus(turnedOnClocks)); // Set ADC Config: Sample mode Synchronous, 3 cycles sample, Reset, Disable. HWREGB(AUX_ADI4_BASE + ADI_4_AUX_O_ADC0) = (0 << ADI_4_AUX_ADC0_SMPL_MODE_S) | (6 << ADI_4_AUX_ADC0_SMPL_CYCLE_EXP_S) | (0 << ADI_4_AUX_ADC0_RESET_N_S) | (0 << ADI_4_AUX_ADC0_EN_S ); // Set reference source: Keep powered when idle, Fixed Src 4.3V, Enable reference system HWREGB(AUX_ADI4_BASE + ADI_4_AUX_O_ADCREF0) = (1 << ADI_4_AUX_ADCREF0_REF_ON_IDLE_S) | (0 << ADI_4_AUX_ADCREF0_SRC_S) | (1 << ADI_4_AUX_ADCREF0_EN_S ); // Set TRIM values //HWREGB(AUX_ADI_BASE + ADI_4_AUX_O_ADCREF1) = (1 << ADI_4_AUX_ADCREF1_VTRIM_S) | // (0 << ADI_4_AUX_ADCREF1_ITRIM_S); // Connect the muxed AUX IO Channel, light sensor is DIO23, which is AUXIO7 on the 7x7 package //HWREGB(AUX_ADI4_BASE + ADI_4_AUX_O_MUX3) = auxIo; HWREGB(AUX_ADI4_BASE + 0x00000003) = auxIo; // Release ADC from reset and enable HWREGB(AUX_ADI4_BASE + ADI_4_AUX_O_ADC0) |= (1 << ADI_4_AUX_ADC0_RESET_N_S) | (1 << ADI_4_AUX_ADC0_EN_S ); // Control M3's Analog Interface. Set polarity for trigger, but we don't care. Set trig source to NO_EVENT. Enable ADC interface for the remaining register writes. HWREG(AUX_ANAIF_BASE + AUX_ANAIF_O_ADCCTL) = (0 << AUX_ANAIF_ADCCTL_START_POL_S) | (9 << AUX_ANAIF_ADCCTL_START_SRC_S ) | // 9 is NO_EVENT, which is what we want for software trigger (1 << AUX_ANAIF_ADCCTL_CMD_S); // // Trigger the ADC conversion HWREG(AUX_ANAIF_BASE + AUX_ANAIF_O_ADCTRIG) = (1 << AUX_ANAIF_ADCTRIG_START_S); // Wait until it's finished (when fifo is not empty) while ( 1 == (HWREG(AUX_ANAIF_BASE + AUX_ANAIF_O_ADCFIFOSTAT) & AUX_ANAIF_ADCFIFOSTAT_EMPTY) ); // Read out value from FIFO retval = HWREG(AUX_ANAIF_BASE + AUX_ANAIF_O_ADCFIFO); // Clean up. // Disable reference system HWREGB(AUX_ADI4_BASE + ADI_4_AUX_O_ADCREF0) &= ~(1 << ADI_4_AUX_ADCREF0_EN_S ); // Turn off clocks AUXWUCClockDisable(turnedOnClocks); // Turn off ADC module HWREGB(AUX_ADI4_BASE + ADI_4_AUX_O_ADC0) = (0 << ADI_4_AUX_ADC0_RESET_N_S) | (0 << ADI_4_AUX_ADC0_EN_S ); return retval; }
