扫一扫,分享给好友
串口SBUF0寄存器写不进去数据
void UART0_Init (void) { U8 SFRPAGE_save = SFRPAGE; SFRPAGE = CONFIG_PAGE; value=0x60; baud(value); //波特率选择 //BAUDRATE =9600; SCON0 = 0x10; // SCON0: 8-bit variable bit rate // clear RI0 and ti0 bits // Baud Rate = [BRG Clock / (65536 - (SBRLH0:SBRLL0))] x 1/2 x 1/Prescaler if ((SYSCLK / BAUDRATE / 2 / 0xFFFF) < 1) { SBRL0 = -(SYSCLK / BAUDRATE / 2); SBCON0 |= 0x03; // Set prescaler to 1 } else if ((SYSCLK / BAUDRATE / 2 / 0xFFFF) < 4) { SBRL0 = -(SYSCLK / BAUDRATE / 2/ 4); SBCON0 &= ~0x03; SBCON0 |= 0x01; // Set prescaler to 4 } else if ((SYSCLK / BAUDRATE / 2 / 0xFFFF) < 12) { SBRL0 = -(SYSCLK / BAUDRATE / 2 / 12); SBCON0 &= ~0x03; // Set prescaler to 12 } else { SBRL0 = -(SYSCLK / BAUDRATE / 2 / 48); SBCON0 &= ~0x03; SBCON0 |= 0x02; // Set prescaler to 48 } SBCON0 |= 0x40; // Enable baud rate generator //SCON0 = 0x10; ES0 = 1; // Enable UART0 interrupts // TX_Ready = 1; // Flag showing that UART can transmit SFRPAGE = SFRPAGE_save; } //----------------------------------------------------------------------------- // 串口单字节发送函数 //---------------------------------------------------------------------------- void UART0_Send_Byte(U8 U_Data) { U8 Txdata; U8 SFRPAGE_save= SFRPAGE ; ES0=0; //关串口0中断 SFRPAGE = CONFIG_PAGE; DE=0; //串口发送 Txdata=U_Data; SBUF0 =Txdata; //SBUF0数据一直不变 while(TI0==0); //等待发送完成 程序停在此处 TI0=1; //清0发送完成中断标志位 //SFRPAGE = SFRPAGE_save; //SFRPAGE = CONFIG_PAGE; DE=1; //接收 SFRPAGE = SFRPAGE_save; } //----------------------------------------------------------------------------- // 串口发送函数 //----------------------------------------------------------------------------- void UART0_Send(int count) { U8 Txdata0; U8 SFRPAGE_save = SFRPAGE; int txdatal; for(txdatal=0;txdatal Txdata0=UART_T_Buffer[txdatal]; UART0_Send_Byte(Txdata0); } SFRPAGE = SFRPAGE_save; } //----------------------------------------------------------------------------- // 485采集 //----------------------------------------------------------------------------- void Equi_Acquisition() { Byte_order=0x02; //字节顺序 Date_type=0x02; //数据类型 UART_T_Buffer[0]=0xD3; UART_T_Buffer[1]=0x03; UART_T_Buffer[2]=0x91; UART_T_Buffer[3]=0x00; UART_T_Buffer[4]=0x00; UART_T_Buffer[5]=0x02; UART_T_Buffer[6]=0xFA; UART_T_Buffer[7]=0x85; UART0_Send(8); ES0=1; RS485_Work(); } //----------------------------------------------------------------------------- // 波特率选择函数 //----------------------------------------------------------------------------- void baud(U8 value) { switch(value) //波特率选择 {case 0x20:{BAUDRATE =115200;break; } case 0x40:{BAUDRATE =57600; break; } case 0x80:{BAUDRATE =38400; break; } case 0xCD:{BAUDRATE =19200; break; } case 0x60:{BAUDRATE =9600; break; } case 0x30:{BAUDRATE =4800; break; } case 0x18:{BAUDRATE =2400; break; } case 0x0C:{BAUDRATE =1200; break; } } } //----------------------------------------------------------------------------- // Interrupt Service Routines //----------------------------------------------------------------------------- //----------------------------------------------------------------------------- // UART0_Interrupt //----------------------------------------------------------------------------- // // This routine is invoked whenever a character is entered or displayed on the // Hyperterminal. // //----------------------------------------------------------------------------- INTERRUPT(UART0_ISR, INTERRUPT_UART0) { U8 SFRPAGE_save = SFRPAGE; //SFRPAGE=UART0_PAGE; ES0=0; if (RI0 == 1) { if( UART_Buffer_Size == 0) // If new word is entered { UART_Input_First = 0; } RI0 = 0; // Clear interrupt flag Byte = SBUF0; // Read a character from UART UART_R_Buffer[UART_Input_First] = Byte; // Store in array UART_Buffer_Size++; // Update array's size UART_Buffer_Lenth=UART_Buffer_Size; UART_Input_First++; // Update counter //SFRPAGE = TIMER01_PAGE; TH1 = (65535-24000000/BAUDRATE)/256; TL1 = (65535-24000000/BAUDRATE)%256; TR1 = 1; //开启定时器1 ET1 = 1; //开启定时器1中断 SFRPAGE=SFRPAGE_save; } RI0=0; //清除接收标志 UART_Buffer_Size=0; SFRPAGE = CONFIG_PAGE; SFRPAGE=SFRPAGE_save; } //----------------------------------------------------------------------------- // 定时器1中断 //----------------------------------------------------------------------------- INTERRUPT (TIMER1_ISR, INTERRUPT_TIMER1) { TR1 = 0;//停止定时器1 ET1 = 0;//禁止定时器1中断 ES0 = 0;//关闭串口中断 TF1 = 0;//清除定时器1标志 }
2个回答
回帖奖励 +1 分积分
你得确定你数据发送端没有问题,然后看看接收中断进去没有,一步步分析程序
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
265 浏览 0 评论
【原创】【RA4M2-SENSOR开发板评测】低功耗+USB综合测试
789 浏览 0 评论
1306 浏览 2 评论
787 浏览 0 评论
【RA4M2-SENSOR开发板评测】Analogue+Timers综合测试
1587 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
16900 浏览 31 评论
/9
GMT+8, 2025-12-2 00:47 , Processed in 0.783888 second(s), Total 72, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4686
