ralink的SDK提供的uboot是支持u***相关命令的,只需要在config.mk打开相应的开关即可。一开始以为只需要这样做: RALINK_USB = ON RALINK_EHCI = ON RALINK_OHCI = ON 编译烧写后,发现u***相关命令已经出现在uboot中了,但是每次u*** reset,都扫描不到storage存储设备。 MT7620 # u***reset (Re)start USB... USB: scanning bus for devices... ## RH_GET_DESCRIPTOR ##RH_SET_ADDRESS ##RH_GET_DESCRIPTOR ##RH_GET_DESCRIPTOR ##RH_GET_DESCRIPTOR ##RH_SET_CONFIGURAtiON ##RH_GET_DESCRIPTOR ## RH_GET_DESCRIPTOR ##RH_GET_DESCRIPTOR | RH_CLASS ##RH_GET_DESCRIPTOR | RH_CLASS ## RH_GET_STATUS| RH_CLASS 1 USB Device(s)found scanning bus for storage devices... 0 Storage Device(s) found u*** info中,product和vendor id均为0,太怪异了! MT7620 # u***info 1: Hub, USB Revision 1.10 - OHCIRoot Hub - Class: Hub - PacketSize: 8 Configurations: 1 - Vendor: 0x0000 Product 0x0000 Version 0.0 Configuration: 1 - Interfaces: 1 Self Powered 0mA Interface: 0 - Alternate Settings 0, Endpoints: 1 - Class Hub - Endpoint 1 In Interrupt MaxPacket 2 Interval 255ms 并且发现uboot识别的u*** host只有12M/s的速度 MT7620 # u***tree Device Tree: 1 Hub(12 Mb/s, 0mA) OHCI Root Hub 按理说,MT7620的u***应该是2.0的高速设备,不可能是12M/s的。仔细分析了一下代码,发现只要开启了RALINK_OHCI,RALINK_EHCI就会失效。so,只打开EHCI,关闭OHCI。 RALINK_USB = ON RALINK_EHCI = ON RALINK_OHCI =OFF 编译烧录,发现问题更离奇: U-Boot 1.1.3(Jun 9 2014 - 17:38:01) MT7620 # u***reset (Re)start USB... USB: in u***_lowlevel_init Error, couldn't init Lowlevel part 看来调用u***_lowlevel_init失败!为了分析问题,在u***_lowlevel_init的代码中加入一些printf信息,: 发现,u***_lowlevel_init返回-1,于是发现u***_lowlevel_init调用了如下代码: 位于ehci-ra.c中 int ehci_hcd_init(void) { #if defined(RT3352_ASIC_BOARD) || defined(RT3883_ASIC_BOARD)|| defined(RT5350_ASIC_BOARD) leave_power_saving(); mdelay(100); rt_set_host(); mdelay(100); hccr = (struct ehci_hccr *)(0xb01c0000); hcor = (struct ehci_hcor *)((uint32_t) hccr +HC_LENGTH(ehci_readl(&hccr->cr_capbase))); printf("Mediatek/Ralink USB EHCI host inithccr %x and hcor %x hc_length %dn", (uint32_t)hccr, (uint32_t)hcor,(uint32_t)HC_LENGTH(ehci_readl(&hccr->cr_capbase))); return 0; #else return -1; #endif } 不知道问题在哪,直接屏蔽掉主控的控制,终于有东西了 MT7620 # u***reset (Re)start USB... USB: in u***_lowlevel_init Mediatek/RalinkUSB EHCI host init hccr b01c0000 and hcor b01c0010 hc_length 16 Register 1111NbrPorts 1 USB EHCI 1.00 scanning bus for devices... 2 USB Device(s) found scanning bus for storage devices... 1 Storage Device(s) found MT7620 # u***info 1: Hub, USB Revision 0.2 - u-boot EHCI Host Controller - Class: Hub - PacketSize: 64 Configurations: 1 - Vendor: 0x0000 Product 0x0000 Version 0.1 Configuration: 1 - Interfaces: 1 Self Powered 0mA Interface: 0 - Alternate Settings 0, Endpoints: 1 - Class Hub - Endpoint 1 In Interrupt MaxPacket 8 Interval 0ms 2: MassStorage, USB Revision 2.0 - HP USB 2.0 Flash 00CCCBB99999 - Class: (from Interface) Mass Storage - PacketSize: 64 Configurations: 1 - Vendor: 0x0204 Product 0x6025 Version 1.0 Configuration: 1 - Interfaces: 1 Bus Powered 100mA Interface: 0 - Alternate Settings 0, Endpoints: 2 - Class Mass Storage, Transp. SCSI, Bulk only - Endpoint 1 Out Bulk MaxPacket 512 - Endpoint 1 In Bulk MaxPacket 512 速度也正确了! MT7620 # u***tree Device Tree: 1 Hub(480 Mb/s, 0mA) | u-boot EHCI Host Controller | +-2 Mass Storage (480 Mb/s, 100mA) HP USB 2.0 Flash 00CCCBB99999 在ehci-ra.c的ehci_hcd_init中加入MT7620_ASIC_BOARD定义。 |
只有小组成员才能发言,加入小组>>
711 浏览 0 评论
【KV260视觉入门套件试用体验】四、KV260 视觉入门套件和固件更新
1154 浏览 0 评论
【KV260视觉入门套件试用体验】Vitis AI Library体验之OCR识别
808 浏览 0 评论
【KV260视觉入门套件试用体验】Vitis AI 通过迁移学习训练自定义模型
1079 浏览 0 评论
【KV260视觉入门套件试用体验】KV260系列之Petalinux镜像+Resnet 50探索
836 浏览 0 评论
【AMD KV260视觉入门开发套件试用】4、简单几步体验ubuntu 20.04.3 LTS运行人员检测应用
1533浏览 1评论
470浏览 1评论
【KV260视觉入门套件试用体验】老刘记事儿KV260初体验之Micro-SD选型提速研究(三)
737浏览 1评论
【KV260视觉入门套件试用体验】KV260部署yolov3实现车辆和行人检测
2158浏览 1评论
【KV260视觉入门套件试用体验】基于KV260的人脸识别的实现与展示
751浏览 1评论
GMT+8, 2024-9-10 13:30 , Processed in 0.673717 second(s), Total 76, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
